Commit 8d448d00 authored by Andrei Paskevich's avatar Andrei Paskevich
revert the last interface change, using a separate printer is enough
parent 4cec11a6
printer "coq-realize"
filename "%f_%t_%g.v"
valid 0
unknown "Error: \\(.*\\)$" "\\1"
fail "Syntax error: \\(.*\\)$" "\\1"
time "why3cpulimit time : %s s"
prelude "(* This file is generated by Why3's Coq driver *)"
prelude "(* Beware! Only edit allowed sections below *)"
(* À discuter *)
(*transformation "simplify_recursive_definition"*)
transformation "inline_trivial"
transformation "eliminate_builtin"
transformation "eliminate_non_struct_recursion"
transformation "eliminate_if"
transformation "simplify_formula"
(*transformation "simplify_trivial_quantification_in_goal"*)
theory BuiltIn
prelude "Require Import ZArith."
prelude "Require Import Rbase."
syntax type int "Z"
syntax type real "R"
syntax predicate (=) "(%1 = %2)"
theory bool.Bool
syntax type bool "bool"
syntax function True "true"
syntax function False "false"
syntax function andb "(andb %1 %2)"
syntax function orb "(orb %1 %2)"
syntax function xorb "(xorb %1 %2)"
syntax function notb "(negb %1)"
theory int.Int
syntax function zero "0%Z"
syntax function one "1%Z"
syntax function (+) "(%1 + %2)%Z"
syntax function (-) "(%1 - %2)%Z"
syntax function (*) "(%1 * %2)%Z"
syntax function (-_) "(-%1)%Z"
syntax predicate (<=) "(%1 <= %2)%Z"
syntax predicate (<) "(%1 < %2)%Z"
syntax predicate (>=) "(%1 >= %2)%Z"
syntax predicate (>) "(%1 > %2)%Z"
remove prop CommutativeGroup.Comm.Comm
remove prop CommutativeGroup.Assoc.Assoc
remove prop CommutativeGroup.Unit_def
remove prop CommutativeGroup.Inv_def
remove prop Assoc.Assoc
remove prop Mul_distr
remove prop Comm.Comm
remove prop Unitary
remove prop Refl
remove prop Trans
remove prop Antisymm
remove prop Total
remove prop NonTrivialRing
remove prop CompatOrderAdd
remove prop CompatOrderMult
theory int.Abs
syntax function abs "(Zabs %1)"
remove prop Abs_pos
theory int.MinMax
syntax function min "(Zmin %1 %2)"
syntax function max "(Zmax %1 %2)"
(* removed: Coq Zdiv is NOT true Euclidean division:
Zmod can be negative, in fact (Zmod x y) has the same sign as y,
which is not the usual convention of programming language either.
theory int.EuclideanDivision
prelude "Require Import Zdiv."
syntax function div "(Zdiv %1 %2)"
syntax function mod "(Zmod %1 %2)"
remove prop Div_mod
remove prop Div_bound
remove prop Mod_bound
remove prop Mod_1
remove prop Div_1
theory int.ComputerDivision
(* Coq Z0div provides the division and modulo operators
with the same convention as mainstream programming language
such C, Java, OCaml *)
prelude "Require Import ZOdiv."
syntax function div "(ZOdiv %1 %2)"
syntax function mod "(ZOmod %1 %2)"
remove prop Div_mod
remove prop Div_sign_pos
remove prop Div_sign_neg
remove prop Mod_sign_pos
remove prop Mod_sign_neg
remove prop Rounds_toward_zero
remove prop Div_1
remove prop Mod_1
remove prop Div_inf
remove prop Mod_inf
remove prop Div_mult
remove prop Mod_mult
theory real.Real
syntax function zero "0%R"
syntax function one "1%R"
syntax function (+) "(%1 + %2)%R"
syntax function (-) "(%1 - %2)%R"
syntax function (-_) "(-%1)%R"
syntax function (*) "(%1 * %2)%R"
syntax function (/) "(Rdiv %1 %2)%R"
syntax function inv "(Rinv %1)"
syntax predicate (<=) "(%1 <= %2)%R"
syntax predicate (<) "(%1 < %2)%R"
syntax predicate (>=) "(%1 >= %2)%R"
syntax predicate (>) "(%1 > %2)%R"
remove prop Unitary
remove prop Inverse
remove prop Refl
remove prop Trans
remove prop Total
remove prop assoc_mul_div
remove prop assoc_div_mul
remove prop assoc_div_div
theory real.RealInfix
syntax function (+.) "(%1 + %2)%R"
syntax function (-.) "(%1 - %2)%R"
syntax function (-._) "(-%1)%R"
syntax function ( *.) "(%1 * %2)%R"
syntax function (/.) "(%1 / %2)%R"
syntax predicate (<=.) "(%1 <= %2)%R"
syntax predicate (<.) "(%1 < %2)%R"
syntax predicate (>=.) "(%1 >= %2)%R"
syntax predicate (>.) "(%1 > %2)%R"
theory real.Abs
prelude "Require Import Rbasic_fun."
syntax function abs "(Rabs %1)"
remove prop Abs_le
remove prop Abs_pos
theory real.FromInt
syntax function from_int "(IZR %1)"
remove prop Zero
remove prop One
remove prop Add
remove prop Sub
remove prop Mul
remove prop Neg
theory real.Square
prelude "Require Import R_sqrt."
syntax function sqr "(Rsqr %1)"
syntax function sqrt "(sqrt %1)" (* and not Rsqrt *)
remove prop Sqrt_positive
remove prop Sqrt_square
remove prop Square_sqrt
theory real.ExpLog
prelude "Require Import Rtrigo_def."
prelude "Require Import Rpower."
syntax function exp "(exp %1)"
syntax function log "(ln %1)"
remove prop Exp_zero
remove prop Exp_sum
remove prop Log_one
remove prop Log_mul
remove prop Log_exp
remove prop Exp_log
theory real.Power
(* no power: R -> R -> R in Coq ? (only powerRZ: R -> Z -> R) *)
theory real.Trigonometry
prelude "Require Import Rtrigo."
prelude "Require Import AltSeries. (* for def of pi *)"
syntax function cos "(Rtrigo_def.cos %1)"
syntax function sin "(Rtrigo_def.sin %1)"
syntax function pi "PI"
syntax function tan "(Rtrigo.tan %1)"
(* syntax function atan "atan not defined in Coq ?" *)
remove prop Pythagorean_identity
remove prop Cos_le_one
remove prop Sin_le_one
remove prop Cos_0
remove prop Sin_0
remove prop Cos_pi
remove prop Sin_pi
remove prop Cos_pi2
remove prop Sin_pi2
...@@ -33,7 +33,7 @@ type prelude_map = prelude Mid.t ...@@ -33,7 +33,7 @@ type prelude_map = prelude Mid.t
type 'a pp = formatter -> 'a -> unit type 'a pp = formatter -> 'a -> unit
type printer = Env.env -> prelude -> prelude_map -> ?realize:bool -> ?old:in_channel -> task pp type printer = Env.env -> prelude -> prelude_map -> ?old:in_channel -> task pp
let printers : (string, printer) Hashtbl.t = Hashtbl.create 17 let printers : (string, printer) Hashtbl.t = Hashtbl.create 17
...@@ -50,7 +50,7 @@ let lookup_printer s = ...@@ -50,7 +50,7 @@ let lookup_printer s =
let list_printers () = Hashtbl.fold (fun k _ acc -> k::acc) printers [] let list_printers () = Hashtbl.fold (fun k _ acc -> k::acc) printers []
let () = register_printer "(null)" (fun _ _ _ ?realize:_ ?old:_ _ _ -> ()) let () = register_printer "(null)" (fun _ _ _ ?old:_ _ _ -> ())
(** Syntax substitutions *) (** Syntax substitutions *)
...@@ -31,7 +31,7 @@ type prelude_map = prelude Mid.t ...@@ -31,7 +31,7 @@ type prelude_map = prelude Mid.t
type 'a pp = Format.formatter -> 'a -> unit type 'a pp = Format.formatter -> 'a -> unit
val register_printer : string -> printer -> unit val register_printer : string -> printer -> unit
...@@ -280,7 +280,7 @@ let prepare_task drv task = ...@@ -280,7 +280,7 @@ let prepare_task drv task =
let task = update_task drv task in let task = update_task drv task in
List.fold_left apply task transl List.fold_left apply task transl
let print_task_prepared ?realize ?old drv fmt task = let print_task_prepared ?old drv fmt task =
let p = match drv.drv_printer with let p = match drv.drv_printer with
| None -> raise NoPrinter | None -> raise NoPrinter
| Some p -> p | Some p -> p
...@@ -288,15 +288,15 @@ let print_task_prepared ?realize ?old drv fmt task = ...@@ -288,15 +288,15 @@ let print_task_prepared ?realize ?old drv fmt task =
let printer = let printer =
lookup_printer p drv.drv_env drv.drv_prelude drv.drv_thprelude lookup_printer p drv.drv_env drv.drv_prelude drv.drv_thprelude
in in
fprintf fmt "@[%a@]@?" (printer ?realize ?old) task fprintf fmt "@[%a@]@?" (printer ?old) task
let print_task ?realize ?old drv fmt task = let print_task ?old drv fmt task =
let task = prepare_task drv task in let task = prepare_task drv task in
print_task_prepared ?realize ?old drv fmt task print_task_prepared ?old drv fmt task
let print_theory ?old drv fmt th = let print_theory ?old drv fmt th =
let task = Task.use_export None th in let task = Task.use_export None th in
print_task ~realize:true ?old drv fmt task print_task ?old drv fmt task
let prove_task_prepared ~command ?timelimit ?memlimit ?old drv task = let prove_task_prepared ~command ?timelimit ?memlimit ?old drv task =
let buf = Buffer.create 1024 in let buf = Buffer.create 1024 in
...@@ -45,7 +45,6 @@ val call_on_buffer : ...@@ -45,7 +45,6 @@ val call_on_buffer :
val print_task : val print_task :
?realize : bool ->
?old : in_channel -> ?old : in_channel ->
driver -> Format.formatter -> Task.task -> unit driver -> Format.formatter -> Task.task -> unit
...@@ -65,7 +64,6 @@ val prove_task : ...@@ -65,7 +64,6 @@ val prove_task :
val prepare_task : driver -> Task.task -> Task.task val prepare_task : driver -> Task.task -> Task.task
val print_task_prepared : val print_task_prepared :
?realize : bool ->
...@@ -248,7 +248,7 @@ let print_task_old pr thpr fmt task = ...@@ -248,7 +248,7 @@ let print_task_old pr thpr fmt task =
fprintf fmt "%a@." (print_list nothing (print_decl info)) decls fprintf fmt "%a@." (print_list nothing (print_decl info)) decls
let () = register_printer "alt-ergo-old" let () = register_printer "alt-ergo-old"
(fun _env pr thpr ?realize:_ ?old:_ fmt task -> (fun _env pr thpr ?old:_ fmt task ->
forget_all ident_printer; forget_all ident_printer;
print_task_old pr thpr fmt task) print_task_old pr thpr fmt task)
...@@ -261,7 +261,7 @@ let print_decls = ...@@ -261,7 +261,7 @@ let print_decls =
Trans.on_tagged_ls meta_ac (fun ac -> Trans.on_tagged_ls meta_ac (fun ac ->
Printer.sprint_decls (print ac)) Printer.sprint_decls (print ac))
let print_task _env pr thpr ?realize:_ ?old:_ fmt task = let print_task _env pr thpr ?old:_ fmt task =
(* In trans-based p-printing [forget_all] is a no-no *) (* In trans-based p-printing [forget_all] is a no-no *)
(* forget_all ident_printer; *) (* forget_all ident_printer; *)
print_prelude fmt pr; print_prelude fmt pr;
...@@ -376,11 +376,11 @@ let context_end = "(* DO NOT EDIT BELOW *)" ...@@ -376,11 +376,11 @@ let context_end = "(* DO NOT EDIT BELOW *)"
(* current kind of script in an old file *) (* current kind of script in an old file *)
type old_file_state = InContext | InProof | NoWhere type old_file_state = InContext | InProof | NoWhere
let copy_proof s ch fmt = let copy_proof s ch fmt =
copy_user_script proof_begin proof_end ch fmt; copy_user_script proof_begin proof_end ch fmt;
s := NoWhere s := NoWhere
let copy_context s ch fmt = let copy_context s ch fmt =
copy_user_script context_begin context_end ch fmt; copy_user_script context_begin context_end ch fmt;
...@@ -665,19 +665,19 @@ let init_printer th = ...@@ -665,19 +665,19 @@ let init_printer th =
Sid.iter (fun id -> ignore (id_unique pr id)) th.Theory.th_local; Sid.iter (fun id -> ignore (id_unique pr id)) th.Theory.th_local;
pr pr
let print_task _env pr thpr ?realize ?old fmt task = let print_task _env pr thpr realize ?old fmt task =
forget_all (); forget_all ();
print_th_prelude task fmt thpr; print_th_prelude task fmt thpr;
let realization,decls = let realization,decls =
if realize = Some true then if realize then
let used = Task.used_theories task in let used = Task.used_theories task in
(* 2 cases: goal is clone T with [] or goal is a real goal *) (* 2 cases: goal is clone T with [] or goal is a real goal *)
let used = match task with let used = match task with
| None -> assert false | None -> assert false
| Some { Task.task_decl = { Theory.td_node = Theory.Clone (th,_) }} -> | Some { Task.task_decl = { Theory.td_node = Theory.Clone (th,_) }} ->
Sid.iter (fun id -> ignore (id_unique iprinter id)) th.Theory.th_local; Sid.iter (fun id -> ignore (id_unique iprinter id)) th.Theory.th_local;
Mid.remove th.Theory.th_name used Mid.remove th.Theory.th_name used
| _ -> used | _ -> used
in in
let symbols = Task.used_symbols used in let symbols = Task.used_symbols used in
...@@ -703,9 +703,14 @@ let print_task _env pr thpr ?realize ?old fmt task = ...@@ -703,9 +703,14 @@ let print_task _env pr thpr ?realize ?old fmt task =
in in
print_decls ~old info fmt decls print_decls ~old info fmt decls
let () = register_printer "coq" print_task let print_task_full env pr thpr ?old fmt task =
print_task env pr thpr false ?old fmt task
let print_task_real env pr thpr ?old fmt task =
print_task env pr thpr true ?old fmt task
let () = register_printer "coq" print_task_full
let () = register_printer "coq-realize" print_task_real
(* specific printer for realization of theories *) (* specific printer for realization of theories *)
(* OBSOLETE (* OBSOLETE
...@@ -331,6 +331,6 @@ let print_task pr thpr fmt task = ...@@ -331,6 +331,6 @@ let print_task pr thpr fmt task =
ignore (print_list_opt (add_flush newline2) (print_decl info) fmt decls) ignore (print_list_opt (add_flush newline2) (print_decl info) fmt decls)
let () = register_printer "cvc3" let () = register_printer "cvc3"
print_task pr thpr fmt task) print_task pr thpr fmt task)
...@@ -407,7 +407,7 @@ let print_goal info fmt g = ...@@ -407,7 +407,7 @@ let print_goal info fmt g =
fprintf fmt "# (no goal at all ??)@\n"; fprintf fmt "# (no goal at all ??)@\n";
fprintf fmt "1 in [0,0]@\n" fprintf fmt "1 in [0,0]@\n"
let print_task env pr thpr ?realize:_ ?old:_ fmt task = let print_task env pr thpr ?old:_ fmt task =
let info = get_info env task in let info = get_info env task in
...@@ -179,7 +179,7 @@ let print_task pr thpr fmt task = ...@@ -179,7 +179,7 @@ let print_task pr thpr fmt task =
let () = register_printer "simplify" let () = register_printer "simplify"
...@@ -242,6 +242,6 @@ let print_task pr thpr fmt task = ...@@ -242,6 +242,6 @@ let print_task pr thpr fmt task =
fprintf fmt "@\n)@." fprintf fmt "@\n)@."
let () = register_printer "smtv1" let () = register_printer "smtv1"
...@@ -338,7 +338,7 @@ let print_task_old pr thpr fmt task = ...@@ -338,7 +338,7 @@ let print_task_old pr thpr fmt task =
let () = register_printer "smtv2" let () = register_printer "smtv2"
...@@ -357,7 +357,7 @@ let print_decls = ...@@ -357,7 +357,7 @@ let print_decls =
Trans.on_meta Discriminate.meta_lsinst (fun dls -> Trans.on_meta Discriminate.meta_lsinst (fun dls ->
Printer.sprint_decls (print dls)) Printer.sprint_decls (print dls))
(* In trans-based p-printing [forget_all] is taboo *) (* In trans-based p-printing [forget_all] is taboo *)
...@@ -147,7 +147,7 @@ let print_task pr thpr fmt task = ...@@ -147,7 +147,7 @@ let print_task pr thpr fmt task =
(print_decl info) fmt (Task.task_decls task)) (print_decl info) fmt (Task.task_decls task))
let () = register_printer "tptp" let () = register_printer "tptp"
...@@ -372,7 +372,7 @@ let print_tdecl fmt td = match td.td_node with ...@@ -372,7 +372,7 @@ let print_tdecl fmt td = match td.td_node with
fprintf fmt "@[<hov 2>(* meta %s %a *)@]@\n@\n" fprintf fmt "@[<hov 2>(* meta %s %a *)@]@\n@\n"
m.meta_name (print_list comma print_meta_arg) al m.meta_name (print_list comma print_meta_arg) al
let print_task_old _env pr thpr ?realize:_ ?old:_ fmt task = let print_task_old _env pr thpr ?old:_ fmt task =
...@@ -386,7 +386,7 @@ let print_tdecls = ...@@ -386,7 +386,7 @@ let print_tdecls =
print_tdecl fmt td in print_tdecl fmt td in
Printer.sprint_tdecls print Printer.sprint_tdecls print
(* In trans-based p-printing [forget_all] IST STRENG VERBOTEN *) (* In trans-based p-printing [forget_all] IST STRENG VERBOTEN *)
(* forget_all (); *) (* forget_all (); *)
