GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
8c721d48
8c721d48
MARCHE Claude
ML example exposing bug 12244
383157bb
4
4 changed files
87 additions
9 deletions
+87
-9
Makefile.in
Makefile.in
+3
examples/bts12244.ml
+74
src/ide/session.ml
src/ide/session.ml
+8
-9
tests/test-claude.why
+2
Makefile.in
8c721d48
@@ -933,6 +933,9 @@ test-api: src/why.cma
ocaml
$(EXTCMA)
src/why.cma
-I
src examples/use_api.ml
ocaml
$(EXTCMA)
src/why.cma
-I
printf
"Test of Why API calls failed. Please fix it"
exit
2
printf
exit
2
bts12244
src/why.cma
ocaml
$(EXTCMA)
src/why.cma
-I
src examples/bts12244.ml
## Examples : Plugins ##
8c721d48
(* Copyright (C) 2010- *)
(* François Bobot *)
(* Jean-Christophe Filliâtre *)
(* Claude Marché *)
(* Andrei Paskevich *)
(* This software is free software; you can redistribute it and/or *)
(* modify it under the terms of the GNU Library General Public *)
(* License version 2.1, with the special exception on linking *)
(* described in file LICENSE. *)
(* This software is distributed in the hope that it will be useful, *)
(* but WITHOUT ANY WARRANTY; without even the implied warranty of *)
(* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. *)
This file exposes bug 12244 directly using the API
open
Why
open
Format
(* reads the config file *)
let
config
Whyconf
config
Whyconf
read_config
None
(* the [main] section of the config file *)
let
main
Whyconf
main
Whyconf
get_main
config
(* builds the environment from the [loadpath] *)
let
env
Env
env
Lexer
create_env
Whyconf
loadpath
main
let
int_theory
Theory
theory
Env
find_theory
env
"int"
"Int"
An arithmetic goal: 1 = 2
let
one
Term
term
Term
t_const
Term
ConstInt
"1"
let
two
Term
term
Term
t_const
Term
ConstInt
"2"
let
fmla
Term
term
Term
t_equ
one
two
let
task
Task
use_export
None
int_theory
let
goal_id
Decl
create_prsymbol
Ident
id_fresh
"G"
let
task
Task
add_prop_decl
task
Decl
Pgoal
goal_id
fmla
let () = printf "@[task:@\n%a@]@." Pretty.print_task task
let
inline
Trans
lookup_transform
"inline_goal"
env
let
split
Trans
lookup_transform_l
"split_goal"
env
let
task_inline
Trans
apply
inline
task
let
printf
"@[task == task_inline ? %b@]@."
task
task_inline
let
task_split
match
Trans
apply
split
task
t
t
_
assert
false
let
printf
"@[task == task_split ? %b@]@."
task
task_split
src/ide/session.ml
8c721d48
@@ -1486,16 +1486,15 @@ let transformation_on_goal g tr =
let
b
let
b
match
subgoals
match
subgoals
task
task
let
s1
task_checksum
get_task
g
in
(* let s1 = task_checksum (get_task g) in *)
let
s2
task_checksum
task
in
(* let s2 = task_checksum task in *)
eprintf "Transformation returned only one task. sum before = %s, sum after = %s@." (task_checksum g.task) (task_checksum task);
(* eprintf "Transformation returned only one task. sum before = %s, sum after = %s@." (task_checksum g.task) (task_checksum task); *)
eprintf "addresses: %x %x@." (Obj.magic g.task) (Obj.magic task);
(* eprintf "addresses: %x %x@." (Obj.magic g.task) (Obj.magic task); *)
s1
s2
(* s1 <> s2 *)
task
get_task
g
task
get_task
g
_
true
_
true
in
in
if
b
then
if
b
then
8c721d48
@@ -159,6 +159,8 @@ theory TestInline
use import int.Int
use import int.Int
goal T : 1 = 2
logic p (x:int) (y:int) = x <= 3 and y <= 7
goal G : p 4 4
goal G : p 4 4
