Commit 8ba51cf2 authored by Andrei Paskevich's avatar Andrei Paskevich
whyml: fix invariant computation for recursive functions
parent dce120fa
...@@ -984,14 +984,6 @@ let reset_vars eff pvs = ...@@ -984,14 +984,6 @@ let reset_vars eff pvs =
if Mreg.is_empty eff.eff_resets then Svs.empty else if Mreg.is_empty eff.eff_resets then Svs.empty else
Spv.fold add pvs Svs.empty Spv.fold add pvs Svs.empty
(* add dummy postconditions for uncovered exceptions *)
let complete_xpost eff xq =
let dummy { xs_ity = ity } () =
let v = create_vsymbol (id_fresh "dummy") (ty_of_ity ity) in
Mlw_ty.create_post v t_true in
let xe = Sexn.union eff.eff_raises eff.eff_ghostx in
Mexn.set_union xq (Mexn.mapi dummy (Mexn.set_diff xe xq))
let spec_invariant lenv pvs vty spec = let spec_invariant lenv pvs vty spec =
let ity = ity_of_vty vty in let ity = ity_of_vty vty in
let pvs = spec_pvset pvs spec in let pvs = spec_pvset pvs spec in
...@@ -1004,23 +996,17 @@ let spec_invariant lenv pvs vty spec = ...@@ -1004,23 +996,17 @@ let spec_invariant lenv pvs vty spec =
c_xpost = Mexn.mapi xpost_inv spec.c_xpost } c_xpost = Mexn.mapi xpost_inv spec.c_xpost }
let abstr_invariant lenv e spec0 = let abstr_invariant lenv e spec0 =
let pvs = e.e_syms.syms_pv in let pvs = spec_pvset e.e_syms.syms_pv spec0 in
let spec = { spec0 with c_effect = e.e_effect } in let spec = { spec0 with c_effect = e.e_effect } in
let spec = spec_invariant lenv pvs e.e_vty spec in let spec = spec_invariant lenv pvs e.e_vty spec in
(* we do not require invariants on free variables *) (* we do not require invariants on free variables *)
{ spec with c_pre = spec0.c_pre } { spec with c_pre = spec0.c_pre }
let lambda_invariant lenv pvs eff lam = let lambda_invariant lenv lam =
let pvs = List.fold_right Spv.add lam.l_args pvs in let { l_spec = spec; l_expr = e } = lam in
let spec = { lam.l_spec with c_effect = eff } in let pvs = spec_pvset e.e_syms.syms_pv spec in
let spec = spec_invariant lenv pvs lam.l_expr.e_vty spec in let spec = spec_invariant lenv pvs e.e_vty spec in
(* we add dummy xposts for uncovered exceptions to silence { lam with l_spec = { spec with c_letrec = 0 }}
Mlw_ty.spec_check, but we do another proper check later
in check_user_effect, which will give us a precise
location of the exception-raising sub-expression *)
let xpost = complete_xpost eff spec.c_xpost in
let spec = { spec with c_xpost = xpost } in
{ lam with l_spec = spec }
(* specification handling *) (* specification handling *)
...@@ -1494,15 +1480,8 @@ and expr_rec lenv dfdl = ...@@ -1494,15 +1480,8 @@ and expr_rec lenv dfdl =
add_local id.id (LetA ps) lenv, (ps, gh, pvl, tr) in add_local id.id (LetA ps) lenv, (ps, gh, pvl, tr) in
let lenv, fdl = Lists.map_fold_left step1 lenv dfdl in let lenv, fdl = Lists.map_fold_left step1 lenv dfdl in
let step2 (ps, gh, pvl, tr) = ps, expr_lam lenv gh pvl tr in let step2 (ps, gh, pvl, tr) = ps, expr_lam lenv gh pvl tr in
let fdl = List.map step2 fdl in let fdl = create_rec_defn (List.map step2 fdl) in
let rd_pvset pvs (_, lam) = let step3 fd = fd.fun_ps, lambda_invariant lenv fd.fun_lambda in
let s = spec_pvset lam.l_expr.e_syms.syms_pv lam.l_spec in
let s = List.fold_right Spv.remove lam.l_args s in
Spv.union pvs s in
let pvs = List.fold_left rd_pvset Spv.empty fdl in
let rd_effect eff (_, lam) = eff_union eff lam.l_expr.e_effect in
let eff = List.fold_left rd_effect eff_empty fdl in
let step3 (ps, lam) = ps, lambda_invariant lenv pvs eff lam in
let fdl = create_rec_defn (List.map step3 fdl) in let fdl = create_rec_defn (List.map step3 fdl) in
let step4 fd (_,_,_,bl,(de,dsp)) = let step4 fd (_,_,_,bl,(de,dsp)) =
Loc.try4 de.de_loc check_lambda_effect lenv fd bl dsp in Loc.try4 de.de_loc check_lambda_effect lenv fd bl dsp in
...@@ -1525,9 +1504,7 @@ and expr_fun lenv x gh bl (de, dsp as tr) = ...@@ -1525,9 +1504,7 @@ and expr_fun lenv x gh bl (de, dsp as tr) =
let post = Mlw_ty.create_post vs f in let post = Mlw_ty.create_post vs f in
let spec = { lam.l_spec with c_post = post } in let spec = { lam.l_spec with c_post = post } in
{ lam with l_spec = spec } in { lam with l_spec = spec } in
let pvs = spec_pvset lam.l_expr.e_syms.syms_pv lam.l_spec in let lam = lambda_invariant lenv lam in
let pvs = List.fold_right Spv.remove lam.l_args pvs in
let lam = lambda_invariant lenv pvs lam.l_expr.e_effect lam in
let fd = create_fun_defn (Denv.create_user_id x) lam in let fd = create_fun_defn (Denv.create_user_id x) lam in
Loc.try4 de.de_loc check_lambda_effect lenv fd bl dsp; Loc.try4 de.de_loc check_lambda_effect lenv fd bl dsp;
fd fd
