Commit 8a9f03dc authored by Andrei Paskevich's avatar Andrei Paskevich
whyml: patterns in postconditions
parent 4f85613e
......@@ -148,9 +148,9 @@ end
{ pe_reads = r1 @ r2; pe_writes = w1 @ w2; pe_raises = x1 @ x2 }
let spec p (q,xq) ef vl = {
sp_pre = [p];
sp_post = [q];
sp_xpost = [xq];
sp_pre = p;
sp_post = q;
sp_xpost = xq;
sp_effect = ef;
sp_variant = vl;
......@@ -1138,7 +1138,7 @@ expr:
| GHOST expr
{ mk_expr (Eghost $2) }
| ABSTRACT expr post
{ mk_expr (Eabstract($2, spec (mk_pp PPtrue) $3 empty_effect [])) }
{ mk_expr (Eabstract($2, spec [] $3 empty_effect [])) }
| label expr %prec prec_named
{ mk_expr (Enamed ($1, $2)) }
......@@ -1148,7 +1148,7 @@ triple:
{ (* add_init_label *) $2, spec $1 $3 empty_effect [] }
| expr %prec prec_triple
{ (* add_init_label *) $1,
spec (mk_pp PPtrue) (mk_pp PPtrue, []) empty_effect [] }
spec [] ([], []) empty_effect [] }
expr_arg:
......@@ -1303,7 +1303,7 @@ simple_type_v:
type_c:
| type_v
{ $1, spec (mk_pp PPtrue) (mk_pp PPtrue, []) empty_effect [] }
{ $1, spec [] ([], []) empty_effect [] }
| pre type_v effects post
{ $2, spec $1 $4 $3 [] }
......@@ -1311,7 +1311,7 @@ type_c:
/* for ANY */
simple_type_c:
| simple_type_v
......@@ -1322,11 +1322,16 @@ annotation:
pre:
| annotation { $1 }
| annotation { [$1] }
post:
| annotation list0_post_exn { $1, $2 }
| normal_post list0_post_exn { [floc_i 1, [$1]], [floc_i 2, $2] }
normal_post:
| annotation
{ mk_pat (PPpvar (mk_id "result" (floc ()))), $1 }
list0_post_exn:
......@@ -1340,7 +1345,8 @@ list1_post_exn:
post_exn:
| BAR uqualid ARROW annotation { $2, $4 }
{ $2, mk_pat (PPpvar (mk_id "result" (floc_i 2))), $4 }
effects:
......@@ -196,14 +196,14 @@ type effect = {
pe_raises : qualid list;
type pre = lexpr list
type post = lexpr list
type xpost = (qualid * lexpr) list list
type pre = lexpr
type post = loc * (pattern * lexpr) list
type xpost = loc * (qualid * pattern * lexpr) list
type spec = {
sp_pre : pre;
sp_post : post;
sp_xpost : xpost;
sp_pre : pre list;
sp_post : post list;
sp_xpost : xpost list;
sp_effect : effect;
sp_variant : variant list;
......@@ -310,12 +310,26 @@ let rec lexpr_conj = function
| [l] -> l
| l :: ll -> { l with pp_desc = PPbinop (l, PPand, lexpr_conj ll) }
let get_post l =
let conv = function
| _, [{pat_desc = PPpvar { id = "result" }}, le] -> le
| loc, _ -> Loc.errorm ~loc "Patterns in postconditions \
are not supported in this version of WhyML" in
lexpr_conj (List.map conv l)
let get_xpost = function
| [l] -> l
| [loc, l] ->
let conv (xs, p, le) = match p.pat_desc with
| PPpvar { id = "result" } -> xs, le
List.map conv l
| _ :: _ -> Loc.errorm "Multiple exceptional postconditions \
let dpost uc sp = dpost uc (get_post sp.sp_post, get_xpost sp.sp_xpost)
let rec dutype_v env = function
| Ptree.Tpure pt ->
DUTpure (dtype ~user:true env pt)
......@@ -328,8 +342,7 @@ and dutype_c env (ty,sp) =
{ duc_result_type = dutype_v env ty;
duc_effect = dueffect env sp.Ptree.sp_effect;
duc_pre = lexpr_conj sp.Ptree.sp_pre;
duc_post = dpost env.uc
(lexpr_conj sp.Ptree.sp_post, get_xpost sp.Ptree.sp_xpost);
duc_post = dpost env.uc sp;
and dubinder env ({id=x; id_loc=loc} as id, gh, v) =
......@@ -748,7 +761,7 @@ and dexpr_desc ~ghost ~userloc env loc = function
DEany c, dpurify_utype_v c.duc_result_type
| Ptree.Eabstract(e1,q) ->
let e1 = dexpr ~ghost ~userloc env e1 in
let q = dpost env.uc (lexpr_conj q.sp_post, get_xpost q.sp_xpost) in
let q = dpost env.uc q in
DEabstract(e1, q), e1.dexpr_type
| Ptree.Eghost _ ->
no_ghost true;
......@@ -782,7 +795,7 @@ and dletrec ~ghost ~userloc env dl =
and dtriple ~ghost ~userloc env (e, sp) =
let v = dvariants env sp.sp_variant in
let e = dexpr ~ghost ~userloc env e in
let q = dpost env.uc (lexpr_conj sp.sp_post, get_xpost sp.sp_xpost) in
let q = dpost env.uc sp in
v, (lexpr_conj sp.sp_pre, e, q)
(*** regions tables ********************************************************)
......@@ -28,8 +28,8 @@ type ident = Ptree.ident
type ghost = bool
type dpre = Ptree.pre
type dpost = Ptree.post
type dpre = Ptree.lexpr list
type dpost = (string * Ptree.lexpr) list
type dxpost = dpost Mexn.t
type dvariant = Ptree.lexpr * Term.lsymbol option
type dinvariant = Ptree.lexpr list
......@@ -370,13 +370,26 @@ let deff_of_peff uc pe =
deff_writes = pe.pe_writes;
deff_raises = List.map (find_xsymbol uc) pe.pe_raises; }
exception DuplicateException of xsymbol
let mk_dpost loc = function
| [] -> assert false
| [{ pat_desc = PPpvar { id = x }}, f] -> x, f
| l ->
let x = "result" in
let v = { id = x; id_loc = loc; id_lab = [] } in
let v = { pp_desc = Ptree.PPvar (Qident v); pp_loc = loc } in
x, { pp_desc = PPmatch (v,l); pp_loc = loc }
let dpost ql = List.map (fun (loc, ql) -> mk_dpost loc ql) ql
let dxpost uc ql =
let add_exn m (q,f) =
let add_exn (q,pat,f) m =
let xs = find_xsymbol uc q in
Mexn.add_new (DuplicateException xs) xs [f] m in
let exn_map ql = List.fold_left add_exn Mexn.empty ql in
Mexn.change (function
| Some l -> Some ((pat,f) :: l)
| None -> Some ((pat,f) :: [])) xs m in
let exn_map (loc,ql) =
let m = List.fold_right add_exn ql Mexn.empty in
Mexn.map (fun ql -> [mk_dpost loc ql]) m in
let add_map ql m =
Mexn.union (fun _ l r -> Some (l @ r)) (exn_map ql) m in
List.fold_right add_map ql Mexn.empty
......@@ -386,7 +399,7 @@ let dvariant uc var =
let dspec uc sp = {
ds_pre = sp.sp_pre;
ds_post = sp.sp_post;
ds_post = dpost sp.sp_post;
ds_xpost = dxpost uc sp.sp_xpost;
ds_effect = deff_of_peff uc sp.sp_effect;
ds_variant = dvariant uc sp.sp_variant;
......@@ -778,7 +791,9 @@ let create_assert lenv f =
let create_pre lenv fs = t_and_simp_l (List.map (create_assert lenv) fs)
let create_post lenv log_denv log_vars f =
let create_post lenv res dty x f =
let log_vars = Mstr.add x res lenv.log_vars in
let log_denv = Typing.add_var x dty lenv.log_denv in
let f = Typing.type_fmla lenv.th_old log_denv log_vars f in
let f = t_label_add Split_goal.stop_split f in
let f = remove_old f in
......@@ -786,18 +801,19 @@ let create_post lenv log_denv log_vars f =
check_at f;
f
let create_post lenv x ty fs =
let create_post lenv ty fs =
let dty = dty_of_ty ty in
let x = match fs with (x,_)::_ -> x | [] -> "result" in
let res = create_vsymbol (id_fresh x) ty in
let log_denv = Typing.add_var x (dty_of_ty ty) lenv.log_denv in
let f = t_and_simp_l (List.map (create_post lenv log_denv log_vars) fs) in
let post (x,f) = create_post lenv res dty x f in
let f = t_and_simp_l (List.map post fs) in
Mlw_ty.create_post res f
let create_xpost lenv x xs fs = create_post lenv x (ty_of_ity xs.xs_ity) fs
let create_xpost lenv xs fs = create_post lenv (ty_of_ity xs.xs_ity) fs
let create_post lenv x vty fs = create_post lenv x (ty_of_vty vty) fs
let create_post lenv vty fs = create_post lenv (ty_of_vty vty) fs
let create_xpost lenv x xq = Mexn.mapi (create_xpost lenv x) xq
let create_xpost lenv xq = Mexn.mapi (create_xpost lenv) xq
let add_local x lv lenv = match lv with
| LetA _ ->
......@@ -926,8 +942,8 @@ let check_user_effect lenv e dsp =
let spec_of_dspec lenv eff vty dsp = {
c_pre = create_pre lenv dsp.ds_pre;
c_post = create_post lenv "result" vty dsp.ds_post;
c_xpost = create_xpost lenv "result" dsp.ds_xpost;
c_post = create_post lenv vty dsp.ds_post;
c_xpost = create_xpost lenv dsp.ds_xpost;
c_effect = eff;
c_variant = List.map (create_variant lenv) dsp.ds_variant;
c_letrec = 0;
