Commit 86d1bc0f authored by Andrei Paskevich's avatar Andrei Paskevich
whyml: value tracking (in progress)
parent ba85effc
......@@ -388,22 +388,35 @@ let empty_state kn = {
let next_point state =
let res = !(state.next) in incr state.next; res
let get_ts = function
| Some { ty_node = Tyapp (ts,_) } -> ts
| _ -> assert false
let make_value state csl =
let make_value state ty =
let get_p _ = next_point state in
let new_cs cs = List.map get_p cs.ls_args in
let add_cs m (cs,_) = Mls.add cs (new_cs cs) m in
let csl = match ty.ty_node with
| Tyapp (ts,_) -> Decl.find_constructors state.kn ts
| _ -> assert false in
List.fold_left add_cs Mls.empty csl
let match_point state csl p =
let match_point state ty p =
try Hashtbl.find state.memory p with Not_found ->
let value = make_value state csl in
let value = make_value state ty in
Hashtbl.replace state.memory p value;
value
let rec open_pattern state names value p pat = match pat.pat_node with
| Pwild -> names
| Pvar vs -> Mvs.add vs p names
| Papp (cs,patl) ->
let add_pat names p pat =
let value = match_point state pat.pat_ty p in
open_pattern state names value p pat in
List.fold_left2 add_pat names (Mls.find cs value) patl
| Por _ ->
let add_vs vs s = Mvs.add vs (next_point state) s in
Svs.fold add_vs pat.pat_vars names
| Pas (pat,vs) ->
open_pattern state (Mvs.add vs p names) value p pat
let rec point_of_term state names t = match t.t_node with
| Tvar vs ->
Mvs.find vs names
......@@ -418,28 +431,58 @@ let rec point_of_term state names t = match t.t_node with
| _ -> next_point state
| Tlet (t1, bt) ->
let p = point_of_term state names t1 in
let p1 = point_of_term state names t1 in
let v, t2 = t_open_bound bt in
let names = Mvs.add v p names in
let names = Mvs.add v p1 names in
point_of_term state names t2
| Tcase (t1,[br]) ->
let pat, t2 = t_open_branch br in
let value = match_point state pat.pat_ty p1 in
let names = open_pattern state names value p1 pat in
(* | Tcase _ when Slab.mem update_lab t.t_label -> *)
| Tcase (_t1,[_b]) -> assert false (* TODO *)
| Tconst _ | Tif _ | Tcase _ | Teps _ -> next_point state
| Tcase (t1,bl) ->
(* we treat here the case of a value update: the value
of each branch must be a distinct constructor *)
let p = next_point state in
let ty = of_option t.t_ty in
let value = match_point state (of_option t1.t_ty) p1 in
let branch acc br =
let ls = match t2.t_node with
| Tapp (ls,_) -> ls | _ -> raise Exit in
let p2 = point_of_term state names t2 in
let v2 = match_point state ty p2 in
Mls.add_new Exit ls (Mls.find_exn Exit ls v2) acc
in
begin try
let value = List.fold_left branch Mls.empty bl in
let value = Mls.set_union value (make_value state ty) in
with Exit -> () end;
p
| Tconst _ | Tif _ | Teps _ -> next_point state
| Tquant _ | Tbinop _ | Tnot _ | Ttrue | Tfalse -> assert false
and point_of_constructor state names ls tl =
let csl = Decl.find_constructors state.kn (get_ts ls.ls_value) in
let pl = List.map (point_of_term state names) tl in
let value = Mls.add ls pl (make_value state csl) in
let value = make_value state (of_option ls.ls_value) in
let value = Mls.add ls pl value in
p
and point_of_projection state names ls t1 =
match Decl.find_constructors state.kn (get_ts t1.t_ty) with
| [cs,pjl] as csl ->
let ty = of_option t1.t_ty in
match csl with
| [cs,pjl] ->
let value = match_point state csl p1 in
let value = match_point state ty p1 in
let rec find_p pjl pl = match pjl, pl with
| Some pj::_, p::_ when ls_equal ls pj -> p
| _::pjl, _::pl -> find_p pjl pl
