Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit 853deb85 authored by Andrei Paskevich's avatar Andrei Paskevich
Ity: effect instantiation
parent e017894d
......@@ -720,53 +720,38 @@ let refresh_of_effect e =
Mtv.fold add_rfr sbst rfr) e.eff_writes Mreg.empty in
{ e with eff_resets = Mreg.union merge_covers e.eff_resets rfr }
exception IllegalAlias of region
let eff_full_inst sbs e =
(* modified or reset regions in e *)
let wrt = Mreg.map (Util.const ()) e.eff_writes in
let rst = Mreg.map (Util.const ()) e.eff_resets in
let wrt = Sreg.union wrt rst in
let aff = Sreg.fold (fun r acc ->
Sreg.add (ity_full_inst sbs r) acc) wrt Sreg.empty in
let check_inst v ity acc =
let i = ity_var_unsafe v in
match i.ity_node with
| Ityvar _ -> Sreg.iter (fun r ->
if ity_r_occurs r ity then raise (IllegalAlias r)) aff
(* read-only regions in e *)
let ro = Sreg.diff (Mreg.map (Util.const ()) s) wr in
(* all modified or reset regions are instantiated into distinct regions *)
let add_affected reg acc =
let reg = ity_full_inst sbs reg in
Sreg.add_new (IllegalAlias reg) reg acc in
let wrt = Sreg.fold add_affected wrt Sreg.empty in
(* all read-only regions are instantiated outside wr *)
let add_readonly r =
let r = Mreg.find r s in if Sreg.mem r wr then raise (IllegalAlias r) in
Sreg.iter add_readonly ro;
(* calculate instantiated effect *)
let add_sreg r acc = Sreg.add (Mreg.find r s) acc in
let add_mreg r v acc =
Mreg.add (Mreg.find r s) (Opt.map (fun v -> Mreg.find v s) v) acc in
(* compute compared type variables *)
let add_stv tv acc =
let ity = Mtv.find tv sbs.ity_subst_tv in
let check () _ = raise (IllegalCompar (tv,ity)) in
ity_s_fold check (fun () _ -> ()) () ity;
Stv.union acc ity.ity_vars.vars_tv in
{ e with
eff_writes = Sreg.fold add_sreg e.eff_writes Sreg.empty;
eff_ghostw = Sreg.fold add_sreg e.eff_ghostw Sreg.empty;
eff_resets = Mreg.fold add_mreg e.eff_resets Mreg.empty;
eff_compar = Stv.fold add_stv e.eff_compar Stv.empty;
(* all modified or reset regions in e must be instantiated
let inst fn src = Mreg.fold (fun r v acc ->
let r = ity_full_inst sbs r in
Mreg.add_new (IllegalAlias r) r (fn v) acc) src Mreg.empty in
let writes = inst (fun fld -> fld) e.eff_writes in
let resets = inst (inst (fun () -> ())) e.eff_resets in
let impact = Mreg.merge (fun r fld cvr -> match fld, cvr with
| Some _, Some _ -> raise (IllegalAlias r)
| _ -> Some ()) writes resets in
(* all type variables must be instantiated into types that are
not affected by the effect, and all unaffected regions must
be instantiated into regions outside [impact].
Now, every region in the instantiated execution is either
brought in by the type substitution and thus is unaffected,
or instantiates one of the original regions and is affected
if and only if the original one is. *)
let check_inst v dst = match ity_var_unsafe v with
| {ity_node = Ityvar _} -> Sreg.iter (fun r ->
if ity_r_occurs r dst then raise (IllegalAlias r)) impact
| reg when Mreg.mem reg e.eff_writes -> ()
| reg when Mreg.mem reg e.eff_resets -> ()
| _ when Sreg.mem dst impact -> raise (IllegalAlias dst)
| _ -> () in
Mtv.iter check_inst sbs;
{ e with eff_writes = writes; eff_resets = resets }
let eff_filter vars e =
let check r = reg_occurs r vars in
let reset r = function
......@@ -229,14 +229,11 @@ val eff_assign : effect -> (region * pvsymbol * ity) list -> effect
val refresh_of_effect : effect -> effect
val eff_stale_region : effect -> varset -> bool
exception GhostDiverg
val eff_full_inst : ity Mtv.t -> effect -> effect
(** {2 Specification} *)
type pre = term (** precondition: pre_fmla *)
