GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
842f07fb
842f07fb
Andrei Paskevich
Pmodule: check function effects on cloning
6df22605
3
3 changed files
48 additions
13 deletions
+48
-13
bench/typing/bad/42_ghost_subst.mlw
+0
src/mlw/ity.mli
src/mlw/ity.mli
+2
src/mlw/pmodule.ml
src/mlw/pmodule.ml
+46
-13
bench/typing/
x-
842f07fb
File moved
src/mlw/ity.mli
842f07fb
@@ -233,6 +233,8 @@ val reg_r_reachable : region -> region -> bool
val
ity_r_stale
Sreg
t
Sreg
t
ity
bool
val
reg_r_stale
Sreg
t
Sreg
t
region
bool
val
ity_frz_regs
Sreg
t
ity
Sreg
t
(** {2 Built-in types} *)
val
ts_unit
tysymbol
(** the same as [Ty.ts_tuple 0] *)
src/mlw/pmodule.ml
842f07fb
@@ -496,7 +496,7 @@ let empty_clones m = {
xs_table
Mxs
empty
exception
CloneDivergence
of
ident
ident
(* exception CloneDivergence of ident * ident *)
(* populate the clone structure *)
@@ -769,24 +769,40 @@ let clone_cty cl sm ?(drop_decr=false) cty =
let
reads
Spv
fold
add_read
cty_reads
cty
Spv
empty
in
let
reads
fold_right
add_read
cty
cty_args
reads
in
let
reads
Spv
union
reads
Mpv
domain
olds
in
let
add_write
reg
fs
m
(* add new mutable fields to functions effect *)
let
add_frz
v
frz
ity_frz_regs
frz
v
pv_ity
in
let
frz
Spv
fold
add_frz
reads
Sreg
empty
in
let
add_write
reg
fs
m
let
add_fd
fd
s
Spv
add
Mpv
find_def
fd
fd
cl
fd_table
s
in
let
reg'
clone_reg
cl
reg
in
let
smf_reg'
Spv
of_list
reg'
reg_its
its_mfields
in
(* add old mutable fields to the effect *)
let
fs
Spv
fold
add_fd
fs
Spv
empty
in
(* add new mutable fields to the effect *)
let
reg_its
s'
as
reg'
clone_reg
cl
reg
in
let
smf_reg'
Spv
of_list
s'
its_mfields
in
let
smf_reg
Spv
of_list
reg
reg_its
its_mfields
in
let
smf_ref
Spv
fold
add_fd
smf_reg
Spv
empty
in
let
smf_new
Spv
diff
smf_reg'
smf_ref
in
let
fs
Spv
fold
add_fd
fs
Spv
empty
in
Mreg
add
reg'
Spv
union
fs
smf_new
m
in
let
fs
Spv
union
fs
Spv
diff
smf_reg'
smf_ref
in
let
m
if
Spv
is_empty
fs
not
s'
its_private
then
m
else
Mreg
add
reg'
fs
m
in
(* add new non-mutable fields to the effect *)
let
sof_reg'
Spv
of_list
s'
its_ofields
in
let
sof_reg
Spv
of_list
reg
reg_its
its_ofields
in
let
sof_ref
Spv
fold
add_fd
sof_reg
Spv
empty
in
let
sbs
its_match_regs
s'
reg'
reg_args
reg'
reg_regs
in
let
add_reg
m
r
if
Sreg
mem
r
frz
then
m
else
Mreg
add
r
Spv
of_list
r
reg_its
its_mfields
m
in
let
add_fd
f
m
ity_exp_fold
add_reg
m
ity_full_inst
sbs
f
pv_ity
in
Spv
fold
add_fd
Spv
diff
sof_reg'
sof_ref
m
in
let
writes
Mreg
fold
add_write
cty
cty_effect
eff_writes
Mreg
empty
in
let
add_reset
reg
s
Sreg
add
clone_reg
cl
reg
s
in
let
resets
Sreg
fold
add_reset
cty
cty_effect
eff_resets
Sreg
empty
in
let
eff
eff_reset
eff_write
reads
writes
resets
in
let
eff
eff_reset
eff_reset_overwritten
eff_write
reads
writes
resets
in
let
add_spoil
tv
eff
eff_spoil
eff
ity_var
tv
in
let
eff
Stv
fold
add_spoil
cty
cty_effect
eff_spoils
eff
in
let
add_raise
xs
eff
eff_raise
eff
sm_find_xs
sm
xs
in
let
eff
Sxs
fold
add_raise
cty
cty_effect
eff_raises
eff
in
let
eff
if
partial
cty
cty_effect
eff_oneway
then
eff_partial
eff
else
eff
in
let
eff
if
diverges
cty
cty_effect
eff_oneway
then
eff_diverge
eff
else
eff
in
let
cty
create_cty
mask
cty
cty_mask
args
pre
post
xpost
olds
eff
res
in
let
cty
create_cty
_defensive
mask
cty
cty_mask
args
pre
post
xpost
olds
eff
res
in
cty_ghostify
cty_ghost
cty
cty
let
sm_save_args
sm
c
c'
@@ -1138,25 +1154,40 @@ let clone_pdecl inst cl uc d = match d.pd_node with
RLlemma
RKlemma
in
let
cty
clone_cty
cl
sm_of_cl
cl
cty
in
let
rs'
Mrs
find
rs
inst
mi_rs
in
(* arity and types will be checked when refinement VC is generated *)
(* types are checked during c_app below *)
if
length
cty
cty_args
length
rs'
rs_cty
cty_args
then
raise
BadInstance
BadI
rs
rs_name
begin
match
rs
rs_logic
rs'
rs_logic
RLnone
RLnone
RLls
_
RLlemma
RLlemma
RLlemma
RLls
ls
RLls
ls'
cl
ls_table
Mls
add
ls
ls'
cl
ls_table
_
raise
BadInstance
BadI
rs
rs_name
(* TODO: this is subsumed by eff_equal below, except for the error
begin
match cty.cty_effect.eff_oneway, rs'.rs_cty.cty_effect.eff_oneway with
| _, Total | Diverges, _ | Partial, Partial -> ()
| _ -> raise (CloneDivergence (rs.rs_name, rs'.rs_name))
end;
cl
rs_table
Mrs
add
rs
rs'
cl
rs_table
let
e
e_exec
c_app
rs'
cty
cty_args
cty
cty_result
in
let
cexp
c_fun
mask
cty
cty_mask
cty
cty_args
cty
cty_pre
cty
cty_post
cty
cty_xpost
cty
cty_oldies
e
in
let
id
id_clone
rs
rs_name
in
(* FIXME better name *)
let
ld
_
let_sym
id
ghost
rs_ghost
rs
kind
cexp
in
(* FIXME check ghost status and mask of cexp/ld wrt rs *)
(* FIXME check effects of cexp/ld wrt rs *)
(* add a fake call based on the cloned cty for the right effects *)
let
_
fake
let_sym
id
ghost
rs_ghost
rs
c_any
cty
in
let
fake
e_exec
c_app
fake
cty
cty_args
cty
cty_result
in
let
fake
c_fun
mask
cty
cty_mask
cty
cty_args
cty
cty_pre
cty
cty_post
cty
cty_xpost
cty
cty_oldies
e_if
e_true
e
fake
in
let
_
ss
let_sym
id
ghost
rs_ghost
rs
kind
fake
in
if
not
cty_ghost
rs
rs_cty
cty_ghost
ss
rs_cty
then
raise
BadInstance
BadI
rs
rs_name
if
not
mask_equal
rs
rs_cty
cty_mask
ss
rs_cty
cty_mask
then
raise
BadInstance
BadI
rs
rs_name
let
eff
eff_ghostify
rs_ghost
rs
cty
cty_effect
in
if
not
eff_equal
eff
ss
rs_cty
cty_effect
then
raise
BadInstance
BadI
rs
rs_name
(* FIXME add correspondance for "let lemma" to cl.pr_table *)
let
dl
mk_vc
uc
create_let_decl
ld
in
fold_left
add_pdecl_raw
warn
false
uc
dl
@@ -1326,15 +1357,17 @@ let print_module fmt m = Format.fprintf fmt
"@[<hov 2>module %s@
\n
%a@]@
\n
end"
m
mod_theory
th_name
id_string
Pp
print_list
Pp
newline2
print_unit
m
mod_units
let
print_id
fmt
id
Ident
print_decoded
fmt
id
id_string
let
_
print_id
fmt
id
Ident
print_decoded
fmt
id
id_string
let
Exn_printer
fun
fmt
e
match
e
IncompatibleNotation
nm
Format
fprintf
fmt
"Incombatible type signatures for notation '%a'"
Ident
print_decoded
nm
ModuleNotFound
sl
s
Format
fprintf
fmt
"Module %s not found in library %a"
s
print_path
sl
(* TODO: reuse later for a proper error message
| CloneDivergence (iv, il) -> Format.fprintf fmt
"Cannot instantiate symbol %a with symbol %a \
that has worse termination status"
print_id iv print_id il
_
raise
e
