GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
841b97b2
841b97b2
MARCHE Claude
Improved monitoring of running proofs
39918c7e
3
3 changed files
21 additions
14 deletions
+21
-14
src/ide/gmain.ml
src/ide/gmain.ml
+1
-1
src/ide/replay.ml
src/ide/replay.ml
+3
-1
src/ide/session.ml
src/ide/session.ml
+17
-12
src/ide/gmain.ml
841b97b2
@@ -230,7 +230,7 @@ let cleaning_box =
packing
cleaning_frame
add
packing
cleaning_frame
add
let
monitor_frame
let
monitor_frame
GBin
frame
label
Monitor
GBin
frame
label
Proof monitoring
packing
tools_window_vbox
pack
expand
false
packing
tools_window_vbox
pack
expand
false
let
monitor_box
let
monitor_box
src/ide/replay.ml
841b97b2
@@ -119,7 +119,8 @@ module M = Session.Make
None
timeout_handler
Some
float
ms
1000
f
None
timeout_handler
Some
float
ms
1000
f
Some
_
failwith
"Replay.timeout: already one handler installed"
Some
_
failwith
let
notify_timer_state
_
_
_
let
notify_timer_state
w
s
r
Printf
eprintf
"Progress: %d/%d/%d
\r
w
s
r
@@ -484,6 +485,7 @@ let () =
if
opt_latex2
then
print_latex_statistics
2
opt_latex2
if
opt_latex2
then
2
opt_latex2
else
else
let
callback
report
let
callback
report
eprintf
let
files
n
m
let
files
n
m
fold_left
file_statistics
get_all_files
fold_left
file_statistics
get_all_files
in
in
src/ide/session.ml
841b97b2
@@ -447,9 +447,9 @@ let timeout_handler () =
let
continue
let
continue
match
l
match
l
eprintf "Info: timeout_handler stopped@.";
false
false
_
true
_
true
in
in
@@ -464,9 +464,9 @@ let run_timeout_handler () =
if
timeout_handler_activated
then
else
if
then
else
begin
begin
true
true
eprintf "Info: timeout_handler started@.";
O
timeout
ms
100
timeout_handler
O
timeout
ms
100
timeout_handler
@@ -506,9 +506,9 @@ let idle_handler () =
true
true
Queue
Empty
Queue
Empty
idle_handler_activated
false
false
eprintf "Info: idle_handler stopped@.";
false
false
e
e
Format
eprintf
"@[Exception raise in Session.idle_handler:@ %a@.@]"
Format
eprintf
@@ -521,9 +521,9 @@ let run_idle_handler () =
if
then
else
if
then
else
begin
begin
true
true
eprintf "Info: idle_handler started@.";
O
idle
idle_handler
O
idle
idle_handler
@@ -548,14 +548,15 @@ let cancel_scheduled_proofs () =
callback
Interrupted
callback
Interrupted
done
done
Queue
Empty
Queue
Empty
O
notify_timer_state
length
running_proofs
let
schedule_proof_attempt
debug
timelimit
memlimit
old
let
debug
timelimit
memlimit
old
command
driver
callback
goal
command
driver
callback
goal
eprintf
"Scheduling a new proof attempt@."
eprintf "Scheduling a new proof attempt@.";
Queue
push
Queue
push
Action_proof_attempt
debug
timelimit
memlimit
old
command
driver
debug
timelimit
memlimit
old
command
driver
callback
goal
callback
goal
@@ -1762,10 +1763,14 @@ let check_all ~callback =
file
theories
file
theories
all_files
all_files
let
timeout
let
timeout
Printf.eprintf "Progress: %d/%d\r%!" !proofs_done !proofs_to_do;
if
proofs_done
proofs_to_do
then
if
proofs_done
proofs_to_do
then
begin
begin
Printf.eprintf "\n%!";
decr
maximum_running_proofs
decr
callback
reports
callback
reports
false
false
