Commit 841b97b2 authored by MARCHE Claude's avatar MARCHE Claude
Improved monitoring of running proofs
parent 39918c7e
......@@ -230,7 +230,7 @@ let cleaning_box =
~packing:cleaning_frame#add ()
let monitor_frame =
GBin.frame ~label:"Monitor"
GBin.frame ~label:"Proof monitoring"
~packing:(tools_window_vbox#pack ~expand:false) ()
let monitor_box =
......@@ -119,7 +119,8 @@ module M = Session.Make
| None -> timeout_handler := Some(float ms /. 1000.0 ,f);
| Some _ -> failwith "Replay.timeout: already one handler installed"
let notify_timer_state _ _ _ = ()
let notify_timer_state w s r =
Printf.eprintf "Progress: %d/%d/%d \r%!" w s r
end)
......@@ -484,6 +485,7 @@ let () =
if !opt_latex2 <> "" then print_latex_statistics 2 !opt_latex2
else
let callback report =
eprintf "@.";
let files,n,m =
List.fold_left file_statistics ([],0,0) (M.get_all_files ())
in
......@@ -447,9 +447,9 @@ let timeout_handler () =
let continue =
match l with
eprintf "Info: timeout_handler stopped@.";
false
| _ -> true
in
......@@ -464,9 +464,9 @@ let run_timeout_handler () =
if !timeout_handler_activated then () else
begin
timeout_handler_activated := true;
eprintf "Info: timeout_handler started@.";
O.timeout ~ms:100 timeout_handler
......@@ -506,9 +506,9 @@ let idle_handler () =
true
with Queue.Empty ->
idle_handler_activated := false;
eprintf "Info: idle_handler stopped@.";
false
| e ->
Format.eprintf "@[Exception raise in Session.idle_handler:@ %a@.@]"
......@@ -521,9 +521,9 @@ let run_idle_handler () =
if !idle_handler_activated then () else
begin
idle_handler_activated := true;
eprintf "Info: idle_handler started@.";
O.idle idle_handler
......@@ -548,14 +548,15 @@ let cancel_scheduled_proofs () =
callback Interrupted
done
| Queue.Empty -> ()
| Queue.Empty ->
O.notify_timer_state 0 0 (List.length !running_proofs)
let schedule_proof_attempt ~debug ~timelimit ~memlimit ?old
~command ~driver ~callback goal =
eprintf "Scheduling a new proof attempt@.";
Queue.push
(Action_proof_attempt(debug,timelimit,memlimit,old,command,driver,
callback,goal))
......@@ -1762,10 +1763,14 @@ let check_all ~callback =
file.theories)
!all_files;
let timeout () =
Printf.eprintf "Progress: %d/%d\r%!" !proofs_done !proofs_to_do;
if !proofs_done = !proofs_to_do then
begin
Printf.eprintf "\n%!";
decr maximum_running_proofs;
callback !reports;
false
