GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
83bd9430
83bd9430
Jean-Christophe Filliâtre
yet another paragraph of documentation
2cc3c176
2
doc/syntax.tex
83bd9430
@@ -80,6 +80,18 @@ containing theory \texttt{Int}. Theories referred to without prefix
either appear earlier in the current file,
\eg\ \texttt
, or are
predefined.
The next declaration defines a recursive function,
\emph
length
which computes the length of a list. The
\texttt
logic
keyword is
used to introduce or define both function and predicate symbols.
\why\
checks every recursive, or mutually recursive, definition for
termination. Basically, we require a lexicographic and structural
descent for every recursive call for some reordering of arguments.
Note that matching must be exhaustive and that every
\texttt
match
expression must be terminated by the
\texttt
keyword.
The last declaration in theory
\texttt
Length
is a lemma stating that
the length of a list is non-negative.
% \section{Terms and Formulas} *)
% \section{Declarations, Theories} *)
tests/test-jcf.why
83bd9430
@@ -4,11 +4,6 @@ theory List
type list 'a = Nil | Cons 'a (list 'a)
use import bool.Bool
logic x : int = match 1,2 with X u,y -> 3 end
theory Length
