Commit 82362868 authored by Andrei Paskevich's avatar Andrei Paskevich
t_s_map/t_ty_subst preserve the bound variables
This permits using them in transformations, as they also
preserve the term structure.
Export Term.t_ty_map and Term.t_app_map. We can generalize
t_s_map to cover t_app_map, but this requires computing the
list of types for every application, which we rarely need.
parent 66efe794
...@@ -215,6 +215,13 @@ let pat_or p q = ...@@ -215,6 +215,13 @@ let pat_or p q =
ty_equal_check p.pat_ty q.pat_ty; ty_equal_check p.pat_ty q.pat_ty;
pat_or p q pat_or p q
(* rename all variables in a pattern *)
let rec pat_rename_all m p = match p.pat_node with
| Pvar v -> pat_var (Mvs.find v m)
| Pas (p, v) -> pat_as (pat_rename_all m p) (Mvs.find v m)
| _ -> pat_map (pat_rename_all m) p
(* symbol-wise map/fold *) (* symbol-wise map/fold *)
let rec pat_gen_map fnT fnL m pat = let rec pat_gen_map fnT fnL m pat =
...@@ -313,6 +320,8 @@ let t_ty_check t ty = match ty, t.t_ty with ...@@ -313,6 +320,8 @@ let t_ty_check t ty = match ty, t.t_ty with
| None, Some _ -> raise (FmlaExpected t) | None, Some _ -> raise (FmlaExpected t)
| None, None -> () | None, None -> ()
let vs_check v t = ty_equal_check v.vs_ty (t_type t)
(* trigger equality and traversal *) (* trigger equality and traversal *)
let tr_equal = list_all2 (list_all2 t_equal) let tr_equal = list_all2 (list_all2 t_equal)
...@@ -607,27 +616,22 @@ let t_close_quant vl tl f = ...@@ -607,27 +616,22 @@ let t_close_quant vl tl f =
(* open bindings *) (* open bindings *)
let gen_fresh_vsymbol fnT v = let fresh_vsymbol v =
create_vsymbol (id_clone v.vs_name) (fnT v.vs_ty) create_vsymbol (id_clone v.vs_name) v.vs_ty
let gen_vs_rename fnT h v = let vs_rename h v =
let u = gen_fresh_vsymbol fnT v in let u = fresh_vsymbol v in
Mvs.add v (t_var u) h, u Mvs.add v (t_var u) h, u
let gen_vl_rename fnT h vl = let vl_rename h vl =
Util.map_fold_left (gen_vs_rename fnT) h vl Util.map_fold_left vs_rename h vl
let gen_pat_rename fnT fnL h p = let pat_rename h p =
let add_vs v () = gen_fresh_vsymbol fnT v in let add_vs v () = fresh_vsymbol v in
let m = Mvs.mapi add_vs p.pat_vars in let m = Mvs.mapi add_vs p.pat_vars in
let p = pat_gen_map fnT fnL m p in let p = pat_rename_all m p in
Mvs.union (fun _ _ t -> Some t) h (Mvs.map t_var m), p Mvs.union (fun _ _ t -> Some t) h (Mvs.map t_var m), p
let fresh_vsymbol = gen_fresh_vsymbol (fun ty -> ty)
let vs_rename = gen_vs_rename (fun ty -> ty)
let vl_rename = gen_vl_rename (fun ty -> ty)
let pat_rename = gen_pat_rename (fun ty -> ty) (fun ls -> ls)
let t_open_bound (v,b,t) = let t_open_bound (v,b,t) =
let m,v = vs_rename b.bv_subst v in let m,v = vs_rename b.bv_subst v in
v, t_subst_unsafe m t v, t_subst_unsafe m t
...@@ -699,7 +703,7 @@ let t_if f t1 t2 = ...@@ -699,7 +703,7 @@ let t_if f t1 t2 =
t_if (t_prop f) t1 t2 t_if (t_prop f) t1 t2
let t_let t1 ((v,_,t2) as bt) = let t_let t1 ((v,_,t2) as bt) =
ty_equal_check v.vs_ty (t_type t1); vs_check v t1;
t_let t1 bt t2.t_ty t_let t1 bt t2.t_ty
exception EmptyCase exception EmptyCase
...@@ -789,16 +793,41 @@ let t_pred_app_l pr tl = match List.rev tl with ...@@ -789,16 +793,41 @@ let t_pred_app_l pr tl = match List.rev tl with
(* generic map over types, symbols and variables *) (* generic map over types, symbols and variables *)
let gen_bnd_combine fn m { bv_subst = h } = let gen_fresh_vsymbol fnT v =
Mvs.union (fun _ _ t -> Some t) m (Mvs.map fn h) let ty = fnT v.vs_ty in
if ty_equal ty v.vs_ty then v else
create_vsymbol (id_clone v.vs_name) ty
Mvs.add v u h, u
Mvs.union (fun _ _ t -> Some t) h m, p
let gen_bnd_rename fnT fnE h b =
let add_bv v n m = Mvs.add (Mvs.find v h) n m in
let bvs = Mvs.fold add_bv b.bv_vars Mvs.empty in
let add_bs v t (nh, m) =
let nh,v = gen_vs_rename fnT nh v in
nh, Mvs.add v (fnE t) m
in
let h,bsb = Mvs.fold add_bs b.bv_subst (h,Mvs.empty) in
h, { bv_vars = bvs ; bv_subst = bsb }
let rec t_gen_map fnT fnL m t = let rec t_gen_map fnT fnL m t =
let fn = t_gen_map fnT fnL m in let fn = t_gen_map fnT fnL m in
t_label_copy t (match t.t_node with t_label_copy t (match t.t_node with
| Tvar v -> | Tvar v ->
let r = Mvs.find_default v t m in let u = Mvs.find_default v v m in
ty_equal_check (fnT (t_type t)) (t_type r); ty_equal_check (fnT v.vs_ty) u.vs_ty;
r t_var u
| Tconst _ -> | Tconst _ ->
t t
| Tapp (fs, tl) -> | Tapp (fs, tl) ->
...@@ -806,25 +835,25 @@ let rec t_gen_map fnT fnL m t = ...@@ -806,25 +835,25 @@ let rec t_gen_map fnT fnL m t =
| Tif (f, t1, t2) -> | Tif (f, t1, t2) ->
t_if (fn f) (fn t1) (fn t2) t_if (fn f) (fn t1) (fn t2)
| Tlet (t1, (u,b,t2)) -> | Tlet (t1, (u,b,t2)) ->
let m = gen_bnd_combine fn m b in let m,b = gen_bnd_rename fnT fn m b in
let m,v = gen_vs_rename fnT m u in let m,u = gen_vs_rename fnT m u in
t_let_close v (fn t1) (t_gen_map fnT fnL m t2) t_let (fn t1) (u, b, t_gen_map fnT fnL m t2)
| Tcase (t1, bl) -> | Tcase (t1, bl) ->
let fn_br (p,b,t2) = let fn_br (p,b,t2) =
let m,p = gen_pat_rename fnT fnL m p in let m,p = gen_pat_rename fnT fnL m p in
t_close_branch p (t_gen_map fnT fnL m t2) (p, b, t_gen_map fnT fnL m t2)
in in
t_case (fn t1) (List.map fn_br bl) t_case (fn t1) (List.map fn_br bl)
| Teps (u,b,f) -> | Teps (u,b,f) ->
t_eps_close v (t_gen_map fnT fnL m f) t_eps (u, b, t_gen_map fnT fnL m f)
| Tquant (q, (vl,b,tl,f1)) -> | Tquant (q, (vl,b,tl,f)) ->
let m,vl = gen_vl_rename fnT m vl in let m,vl = gen_vl_rename fnT m vl in
t_quant_close q vl (tr_map fn tl) (fn f1) t_quant q (vl, b, tr_map fn tl, fn f)
| Tbinop (op, f1, f2) -> | Tbinop (op, f1, f2) ->
t_binary op (fn f1) (fn f2) t_binary op (fn f1) (fn f2)
| Tnot f1 -> | Tnot f1 ->
...@@ -836,13 +865,19 @@ let t_gen_map fnT fnL mapV t = t_gen_map (Wty.memoize 17 fnT) fnL mapV t ...@@ -836,13 +865,19 @@ let t_gen_map fnT fnL mapV t = t_gen_map (Wty.memoize 17 fnT) fnL mapV t
(* map over type and logic symbols *) (* map over type and logic symbols *)
let gen_mapV fnT = Mvs.mapi (fun v _ -> t_var (gen_fresh_vsymbol fnT v)) let gen_mapV fnT = Mvs.mapi (fun v _ -> gen_fresh_vsymbol fnT v)
let t_s_map fnT fnL t = t_gen_map fnT fnL (gen_mapV fnT t.t_vars) t let t_s_map fnT fnL t = t_gen_map fnT fnL (gen_mapV fnT t.t_vars) t
(* simultaneous substitution into types and terms *) (* simultaneous substitution into types and terms *)
let t_ty_subst mapT mapV t = t_gen_map (ty_inst mapT) (fun ls -> ls) mapV t let t_ty_subst mapT mapV t =
let fnT = ty_inst mapT in
let m = gen_mapV fnT t.t_vars in
let t = t_gen_map fnT (fun ls -> ls) m t in
let add _ v t m = vs_check v t; Mvs.add v t m in
let m = Mvs.fold2_inter add m mapV Mvs.empty in
t_subst_unsafe m t
(* fold over symbols *) (* fold over symbols *)
...@@ -875,13 +910,23 @@ let t_s_all prT prL t = ...@@ -875,13 +910,23 @@ let t_s_all prT prL t =
let t_s_any prT prL t = let t_s_any prT prL t =
try t_s_fold (any_fn prT) (any_fn prL) false t with FoldSkip -> true try t_s_fold (any_fn prT) (any_fn prL) false t with FoldSkip -> true
(* fold over types in terms and formulas *) (* map/fold over types in terms and formulas *)
let t_ty_map fn t = t_s_map fn (fun ls -> ls) t
let t_ty_fold fn acc t = t_gen_fold fn Util.const acc t let t_ty_fold fn acc t = t_s_fold fn Util.const acc t
let t_ty_freevars = t_ty_fold ty_freevars let t_ty_freevars = t_ty_fold ty_freevars
(* fold over applications in terms and formulas (but not in patterns!) *) (* map/fold over applications in terms and formulas (but not in patterns!) *)
let rec t_app_map fn t =
let t = t_map_unsafe (t_app_map fn) t in
match t.t_node with
| Tapp (ls,tl) ->
let ls = fn ls (List.map t_type tl) t.t_ty in
t_label_copy t (t_app ls tl t.t_ty)
| _ -> t
let rec t_app_fold fn acc t = let rec t_app_fold fn acc t =
let acc = t_fold_unsafe (t_app_fold fn) acc t in let acc = t_fold_unsafe (t_app_fold fn) acc t in
...@@ -1039,8 +1084,7 @@ let t_map_cont fn = t_map_cont (fun cont t -> ...@@ -1039,8 +1084,7 @@ let t_map_cont fn = t_map_cont (fun cont t ->
(* map/fold over free variables *) (* map/fold over free variables *)
let t_v_map fn t = let t_v_map fn t =
let fn v _ = let fn v _ = let res = fn v in vs_check v res; res in
let res = fn v in ty_equal_check v.vs_ty (t_type res); res in
t_subst_unsafe (Mvs.mapi fn t.t_vars) t t_subst_unsafe (Mvs.mapi fn t.t_vars) t
let t_v_fold fn acc t = Mvs.fold (fun v _ a -> fn a v) t.t_vars acc let t_v_fold fn acc t = Mvs.fold (fun v _ a -> fn a v) t.t_vars acc
...@@ -1050,9 +1094,7 @@ let t_v_any pr t = Mvs.exists (fun v _ -> pr v) t.t_vars ...@@ -1050,9 +1094,7 @@ let t_v_any pr t = Mvs.exists (fun v _ -> pr v) t.t_vars
(* replaces variables with terms in term [t] using map [m] *) (* replaces variables with terms in term [t] using map [m] *)
let t_subst m t = let t_subst m t = Mvs.iter vs_check m; t_subst_unsafe m t
Mvs.iter (fun v t -> ty_equal_check v.vs_ty (t_type t)) m;
t_subst_unsafe m t
let t_subst_single v t1 t = t_subst (Mvs.singleton v t1) t let t_subst_single v t1 t = t_subst (Mvs.singleton v t1) t
...@@ -1329,7 +1371,7 @@ let t_let_simp e ((v,b,t) as bt) = ...@@ -1329,7 +1371,7 @@ let t_let_simp e ((v,b,t) as bt) =
if n = 0 then if n = 0 then
t_subst_unsafe b.bv_subst t else t_subst_unsafe b.bv_subst t else
if n = 1 || small e then begin if n = 1 || small e then begin
ty_equal_check v.vs_ty (t_type e); vs_check v e;
t_subst_unsafe (Mvs.add v e b.bv_subst) t t_subst_unsafe (Mvs.add v e b.bv_subst) t
end else end else
t_let e bt t_let e bt
...@@ -378,7 +378,7 @@ val t_ty_subst : ty Mtv.t -> term Mvs.t -> term -> term ...@@ -378,7 +378,7 @@ val t_ty_subst : ty Mtv.t -> term Mvs.t -> term -> term
val t_freevars : int Mvs.t -> term -> int Mvs.t val t_freevars : int Mvs.t -> term -> int Mvs.t
val t_ty_freevars : Stv.t -> term -> Stv.t val t_ty_freevars : Stv.t -> term -> Stv.t
(** Map/fold over types and logical symbols *) (** Map/fold over types and logical symbols in terms and patterns *)
val t_s_map : (ty -> ty) -> (lsymbol -> lsymbol) -> term -> term val t_s_map : (ty -> ty) -> (lsymbol -> lsymbol) -> term -> term
val t_s_fold : ('a -> ty -> 'a) -> ('a -> lsymbol -> 'a) -> 'a -> term -> 'a val t_s_fold : ('a -> ty -> 'a) -> ('a -> lsymbol -> 'a) -> 'a -> term -> 'a
...@@ -386,9 +386,13 @@ val t_s_fold : ('a -> ty -> 'a) -> ('a -> lsymbol -> 'a) -> 'a -> term -> 'a ...@@ -386,9 +386,13 @@ val t_s_fold : ('a -> ty -> 'a) -> ('a -> lsymbol -> 'a) -> 'a -> term -> 'a
val t_s_all : (ty -> bool) -> (lsymbol -> bool) -> term -> bool val t_s_all : (ty -> bool) -> (lsymbol -> bool) -> term -> bool
val t_s_any : (ty -> bool) -> (lsymbol -> bool) -> term -> bool val t_s_any : (ty -> bool) -> (lsymbol -> bool) -> term -> bool
val t_ty_map : (ty -> ty) -> term -> term
val t_ty_fold : ('a -> ty -> 'a) -> 'a -> term -> 'a val t_ty_fold : ('a -> ty -> 'a) -> 'a -> term -> 'a
(* Fold over applications in terms (but not in patterns!) *) (* Map/fold over applications in terms (but not in patterns!) *)
val t_app_map :
(lsymbol -> ty list -> ty option -> lsymbol) -> term -> term
val t_app_fold : val t_app_fold :
('a -> lsymbol -> ty list -> ty option -> 'a) -> 'a -> term -> 'a ('a -> lsymbol -> ty list -> ty option -> 'a) -> 'a -> term -> 'a
