Commit 7ea7e37d authored by Andrei Paskevich's avatar Andrei Paskevich
check positivity condition for type definitions (for real now!)
also, export Ty.ty_v_* traversal functions
parent 8e62fc12
theory Main
type t 'a
type test1 'a = Test1 (t (test1 'a))
theory Main
type id 'a = 'a
type test2 'a = Test2 (id (test2 'a))
theory Main
type shell 'a = Shell 'a
type test3 'a = Test3 (shell (test3 'a))
theory Main
type option 'a = Some 'a | None
type test4 'a = Test4 (option (test4 'a))
theory Test
type t 'a
type test 'a = Test (t (test 'a))
theory Main
type id 'a = 'a
clone Test as T1 with type t = id
clone Test as T2 with type t = shell
clone Test as T3 with type t = option
...@@ -372,7 +372,7 @@ exception EmptyDecl ...@@ -372,7 +372,7 @@ exception EmptyDecl
exception EmptyAlgDecl of tysymbol exception EmptyAlgDecl of tysymbol
exception EmptyIndDecl of lsymbol exception EmptyIndDecl of lsymbol
exception NonPositiveTypeDecl of tysymbol * lsymbol * tysymbol exception NonPositiveTypeDecl of tysymbol * lsymbol * ty
let news_id s id = Sid.add_new id (ClashIdent id) s let news_id s id = Sid.add_new id (ClashIdent id) s
...@@ -399,7 +399,7 @@ let create_ty_decl tdl = ...@@ -399,7 +399,7 @@ let create_ty_decl tdl =
| Tyapp (ts,_) -> | Tyapp (ts,_) ->
let now = Sts.mem ts tss in let now = Sts.mem ts tss in
if seen && now then if seen && now then
raise (NonPositiveTypeDecl (tys,fs,ts)) raise (NonPositiveTypeDecl (tys,fs,ty))
else else
let s = ty_fold (check (seen || now)) s ty in let s = ty_fold (check (seen || now)) s ty in
Sid.add ts.ts_name s Sid.add ts.ts_name s
...@@ -669,8 +669,55 @@ let rec check_foundness kn d = ...@@ -669,8 +669,55 @@ let rec check_foundness kn d =
List.fold_left check () tdl List.fold_left check () tdl
| _ -> () | _ -> ()
let rec ts_extract_pos kn sts ts =
if ts_equal ts ts_func then [false;true] else
if ts_equal ts ts_pred then [false] else
if Sts.mem ts sts then List.map Util.ttrue ts.ts_args else
match (Mid.find ts.ts_name kn).d_node with
| Dtype tdl -> begin match List.assq ts tdl with
| Tabstract -> List.map Util.ffalse ts.ts_args
| Talgebraic csl ->
let sts = Sts.add ts sts in
let rec get_ty stv ty = match ty.ty_node with
| Tyvar _ -> stv
| Tyapp (ts,tl) ->
let get acc pos =
if pos then get_ty acc else ty_freevars Stv.empty in
List.fold_left2 get stv (ts_extract_pos kn sts ts) tl
in
let get_cs acc ls = List.fold_left get_ty acc ls.ls_args in
let negs = List.fold_left get_cs Stv.empty csl in
List.map (fun v -> not (Stv.mem v negs)) ts.ts_args
| _ -> assert false
let check_positivity kn d = match d.d_node with
| Dtype tdl ->
let add s (ts,_) = Sts.add ts s in
let tss = List.fold_left add Sts.empty tdl in
let check_constr tys cs =
let rec check_ty ty = match ty.ty_node with
| Tyvar _ -> ()
| Tyapp (ts,tl) ->
let check pos ty =
if pos then check_ty ty else
if ty_s_any (fun ts -> Sts.mem ts tss) ty
then raise (NonPositiveTypeDecl (tys,cs,ty))
in
List.iter2 check (ts_extract_pos kn Sts.empty ts) tl
in
List.iter check_ty cs.ls_args
in
let check_decl (ts,td) = match td with
| Tabstract -> ()
| Talgebraic cl -> List.iter (check_constr ts) cl
in
List.iter check_decl tdl
| _ -> ()
let known_add_decl kn d = let known_add_decl kn d =
let kn = known_add_decl kn d in let kn = known_add_decl kn d in
check_positivity kn d;
check_foundness kn d; check_foundness kn d;
check_match kn d; check_match kn d;
kn kn
...@@ -116,7 +116,7 @@ val create_prop_decl : prop_kind -> prsymbol -> term -> decl ...@@ -116,7 +116,7 @@ val create_prop_decl : prop_kind -> prsymbol -> term -> decl
(* exceptions *) (* exceptions *)
exception IllegalTypeAlias of tysymbol exception IllegalTypeAlias of tysymbol
exception InvalidIndDecl of lsymbol * prsymbol exception InvalidIndDecl of lsymbol * prsymbol
exception NonPositiveIndDecl of lsymbol * prsymbol * lsymbol exception NonPositiveIndDecl of lsymbol * prsymbol * lsymbol
...@@ -498,10 +498,10 @@ let () = Exn_printer.register ...@@ -498,10 +498,10 @@ let () = Exn_printer.register
print_ts ts print_ts ts
| Decl.NonFoundedTypeDecl ts -> | Decl.NonFoundedTypeDecl ts ->
fprintf fmt "Cannot construct a value of type %a" print_ts ts fprintf fmt "Cannot construct a value of type %a" print_ts ts
| Decl.NonPositiveTypeDecl (_ts, ls, ts1) -> | Decl.NonPositiveTypeDecl (_ts, ls, ty) ->
fprintf fmt "Constructor %a \ fprintf fmt "Constructor %a \
contains a non strictly positive occurrence of type symbol %a" contains a non strictly positive occurrence of type %a"
print_ls ls print_ts ts1 print_ls ls print_ty ty
| Decl.InvalidIndDecl (_ls, pr) -> | Decl.InvalidIndDecl (_ls, pr) ->
fprintf fmt "Ill-formed inductive clause %a" fprintf fmt "Ill-formed inductive clause %a"
print_pr pr print_pr pr
...@@ -75,13 +75,11 @@ let ts_hash ts = id_hash ts.ts_name ...@@ -75,13 +75,11 @@ let ts_hash ts = id_hash ts.ts_name
let ty_hash ty = Hashweak.tag_hash ty.ty_tag let ty_hash ty = Hashweak.tag_hash ty.ty_tag
let mk_ts name args def = { let mk_ts name args def = {
ts_name = name; ts_name = id_register name;
ts_args = args; ts_args = args;
ts_def = def; ts_def = def;
let create_tysymbol name args def = mk_ts (id_register name) args def
module Hsty = Hashcons.Make (struct module Hsty = Hashcons.Make (struct
type t = ty type t = ty
...@@ -132,6 +130,26 @@ let ty_all pr ty = ...@@ -132,6 +130,26 @@ let ty_all pr ty =
let ty_any pr ty = let ty_any pr ty =
try ty_fold (any_fn pr) false ty with FoldSkip -> true try ty_fold (any_fn pr) false ty with FoldSkip -> true
(* traversal functions on type variables *)
let rec ty_v_map fn ty = match ty.ty_node with
| Tyvar v -> fn v
| Tyapp (f, tl) -> ty_app f (List.map (ty_v_map fn) tl)
let rec ty_v_fold fn acc ty = match ty.ty_node with
| Tyvar v -> fn acc v
| Tyapp (_, tl) -> List.fold_left (ty_v_fold fn) acc tl
let ty_v_all pr ty =
try ty_v_fold (all_fn pr) true ty with FoldSkip -> false
let ty_v_any pr ty =
try ty_v_fold (any_fn pr) false ty with FoldSkip -> true
let ty_full_inst m ty = ty_v_map (fun v -> Mtv.find v m) ty
let ty_freevars s ty = ty_v_fold (fun s v -> Stv.add v s) s ty
let ty_closed ty = ty_v_all Util.ffalse ty
(* smart constructors *) (* smart constructors *)
exception BadTypeArity of tysymbol * int * int exception BadTypeArity of tysymbol * int * int
...@@ -141,20 +159,9 @@ exception UnboundTypeVar of tvsymbol ...@@ -141,20 +159,9 @@ exception UnboundTypeVar of tvsymbol
let create_tysymbol name args def = let create_tysymbol name args def =
let add s v = Stv.add_new v (DuplicateTypeVar v) s in let add s v = Stv.add_new v (DuplicateTypeVar v) s in
let s = List.fold_left add Stv.empty args in let s = List.fold_left add Stv.empty args in
let rec vars () ty = match ty.ty_node with let check v = Stv.mem v s || raise (UnboundTypeVar v) in
| Tyvar v when not (Stv.mem v s) -> raise (UnboundTypeVar v) ignore (option_map (ty_v_all check) def);
| _ -> ty_fold vars () ty mk_ts name args def
in
option_iter (vars ()) def;
let rec tv_inst m ty = match ty.ty_node with
| Tyvar n -> Mtv.find n m
| _ -> ty_map (tv_inst m) ty
let rec ty_freevars s ty = match ty.ty_node with
| Tyvar n -> Stv.add n s
| _ -> ty_fold ty_freevars s ty
let ty_app s tl = let ty_app s tl =
let tll = List.length tl in let tll = List.length tl in
...@@ -164,7 +171,7 @@ let ty_app s tl = ...@@ -164,7 +171,7 @@ let ty_app s tl =
| Some ty -> | Some ty ->
let add m v t = Mtv.add v t m in let add m v t = Mtv.add v t m in
let m = List.fold_left2 add Mtv.empty s.ts_args tl in let m = List.fold_left2 add Mtv.empty s.ts_args tl in
tv_inst m ty ty_full_inst m ty
| _ -> | _ ->
ty_app s tl ty_app s tl
...@@ -86,6 +86,13 @@ val ty_fold : ('a -> ty -> 'a) -> 'a -> ty -> 'a ...@@ -86,6 +86,13 @@ val ty_fold : ('a -> ty -> 'a) -> 'a -> ty -> 'a
val ty_all : (ty -> bool) -> ty -> bool val ty_all : (ty -> bool) -> ty -> bool
val ty_any : (ty -> bool) -> ty -> bool val ty_any : (ty -> bool) -> ty -> bool
(** {3 variable-wise map/fold} *)
(** visits every variable of the type *)
val ty_v_map : (tvsymbol -> ty) -> ty -> ty
val ty_v_fold : ('a -> tvsymbol -> 'a) -> 'a -> ty -> 'a
val ty_v_all : (tvsymbol -> bool) -> ty -> bool
val ty_v_any : (tvsymbol -> bool) -> ty -> bool
(** {3 symbol-wise map/fold} *) (** {3 symbol-wise map/fold} *)
(** visits every symbol of the type *) (** visits every symbol of the type *)
val ty_s_map : (tysymbol -> tysymbol) -> ty -> ty val ty_s_map : (tysymbol -> tysymbol) -> ty -> ty
...@@ -98,6 +105,7 @@ exception TypeMismatch of ty * ty ...@@ -98,6 +105,7 @@ exception TypeMismatch of ty * ty
val ty_match : ty Mtv.t -> ty -> ty -> ty Mtv.t val ty_match : ty Mtv.t -> ty -> ty -> ty Mtv.t
val ty_inst : ty Mtv.t -> ty -> ty val ty_inst : ty Mtv.t -> ty -> ty
val ty_freevars : Stv.t -> ty -> Stv.t val ty_freevars : Stv.t -> ty -> Stv.t
val ty_closed : ty -> bool
val ty_equal_check : ty -> ty -> unit val ty_equal_check : ty -> ty -> unit
