GitLab
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
7d681280
7d681280
Jean-Christophe Filliâtre
simplified typing of use/clone declarations
2f34052b
15
Makefile.in
7d681280
@@ -390,12 +390,12 @@ $(PGMCMO) $(PGMCMX): INCLUDES += -I src/programs
byte
bin/why3ml.byte
byte
bin/why3ml.byte
opt
bin/why3ml.opt
opt
bin/why3ml.opt
bin/why3ml.opt
src/why3.cmxa $(PGMCMX) src/main.cmx
bin/why3ml.opt
$(MLWCMX)
src/main.cmx
if
$(QUIET)
, @echo
'Linking $@'
if
$(QUIET)
, @echo
'Linking $@'
$(OCAMLOPT)
$(OFLAGS)
-o
$(EXTCMXA)
$(OCAMLOPT)
$(OFLAGS)
-o
$(EXTCMXA)
$(STRIP)
$(STRIP)
bin/why3ml.byte
src/why3.cma $(PGMCMO) src/main.cmo
bin/why3ml.byte
$(MLWCMO)
src/main.cmo
if
$(QUIET)
,@echo
'Linking $@'
if
$(QUIET)
,@echo
'Linking $@'
$(OCAMLC)
$(BFLAGS)
-o
$(EXTCMA)
$(OCAMLC)
$(BFLAGS)
-o
$(EXTCMA)
@@ -573,12 +573,12 @@ bin/why3ide.opt bin/why3ide.byte: INCLUDES += -I @LABLGTK2LIB@
EXTOBJS +=
EXTOBJS +=
EXTLIBS += lablgtk lablgtksourceview2
bin/why3ide.opt
src/why3.cmxa $(PGMCMX) $(IDECMX)
bin/why3ide.opt
$(MLWCMX)
$(IDECMX)
if
$(QUIET)
, @echo
'Linking $@'
if
$(QUIET)
, @echo
'Linking $@'
$(OCAMLOPT)
$(OFLAGS)
-o
$(EXTCMXA)
$(OCAMLOPT)
$(OFLAGS)
-o
$(EXTCMXA)
$(STRIP)
$(STRIP)
bin/why3ide.byte
src/why3.cma $(PGMCMO) $(IDECMO)
bin/why3ide.byte
$(MLWCMO)
$(IDECMO)
if
$(QUIET)
,@echo
'Linking $@'
if
$(QUIET)
,@echo
'Linking $@'
$(OCAMLC)
$(BFLAGS)
-o
$(EXTCMA)
$(OCAMLC)
$(BFLAGS)
-o
$(EXTCMA)
src/core/env.ml
7d681280
@@ -179,8 +179,6 @@ let read_lib_theory lib path th =
try
Mstr
find
th
mth
Not_found
try
Mstr
find
th
mth
Not_found
raise
TheoryNotFound
path
th
raise
TheoryNotFound
path
th
let
read_lib_file
lib
path
fst
read_lib_file
lib
path
let
register_format
name
exts
read
let
register_format
name
exts
read
if
Hashtbl
mem
read_format_table
name
then
raise
KnownFormat
name
if
Hashtbl
mem
read_format_table
name
then
raise
KnownFormat
name
let
getlib
Wenv
memoize
5
mk_library
read
exts
in
let
getlib
Wenv
memoize
5
mk_library
read
exts
in
src/core/env.mli
7d681280
@@ -114,7 +114,7 @@ val env_of_library : 'a library -> env
val
list_formats
unit
fformat
extension
list
list
val
list_formats
unit
fformat
extension
list
list
(** [list_formats ()] returns the list of registered formats *)
val
read_lib_file
a
library
pathname
a
val
read_lib_file
a
library
pathname
a
theory
Mstr
t
(** [read_lib_file lib path] retrieves the contents of a library file
@raise LibFileNotFound [path] if the library file was not found *)
src/core/theory.ml
7d681280
@@ -663,7 +663,6 @@ let is_empty_sm sm =
Mls
is_empty
sm
sm_ls
Mls
is_empty
sm
sm_ls
Mpr
is_empty
sm
sm_pr
Mpr
is_empty
sm
sm_pr
(** Meta properties *)
let
get_meta_arg_type
function
let
get_meta_arg_type
function
src/core/theory.mli
7d681280
@@ -124,6 +124,7 @@ val close_theory : theory_uc -> theory
val
open_namespace
theory_uc
theory_uc
val
open_namespace
theory_uc
theory_uc
val
close_namespace
theory_uc
bool
string
option
theory_uc
val
close_namespace
theory_uc
bool
string
option
theory_uc
(* the Boolean indicates [import]; the string option indicates [as T] *)
val
get_namespace
theory_uc
namespace
val
get_namespace
theory_uc
namespace
val
get_known
theory_uc
known_map
val
get_known
theory_uc
known_map
src/parser/parser.mly
7d681280
@@ -62,6 +62,7 @@ module Incremental = struct
let
new_use_clone
d
let
new_use_clone
d
let
env
ref_get
env_ref
in
let
lenv
ref_get
lenv_ref
in
let
env
ref_get
env_ref
in
let
lenv
ref_get
lenv_ref
in
ref_set
uc_ref
Typing
add_use_clone
env
lenv
ref_get
uc_ref
d
ref_set
uc_ref
Typing
add_use_clone
env
lenv
ref_get
uc_ref
d
open
Ptree
open
Ptree
@@ -184,6 +185,9 @@ end
Term
IConstBinary
s
int_of_string
"0b"
s
Term
IConstBinary
s
int_of_string
"0b"
s
Failure
_
raise
Parsing
Parse_error
Failure
_
raise
Parsing
Parse_error
let
qualid_last
function
Qident
x
Qdot
_
x
x
id
Tokens
Tokens
@@ -316,7 +320,7 @@ namespace_import:
namespace_name
namespace_name
uident
Some
uident
Some
id
UNDERSCORE
None
UNDERSCORE
None
@@ -354,17 +358,17 @@ use_clone:
use
use
imp_exp
tqualid
imp_exp
tqualid
use_theory
2
use_as
None
use_imp_exp
use_theory
2
use_as
Some
qualid_last
2
use_imp_exp
imp_exp
tqualid
AS
uident
imp_exp
tqualid
AS
uident
use_theory
2
use_as
Some
Some
4
use_imp_exp
use_theory
2
use_as
Some
4
id
use_imp_exp
imp_exp
tqualid
AS
UNDERSCORE
imp_exp
tqualid
AS
UNDERSCORE
use_theory
2
use_as
Some
None
use_imp_exp
use_theory
2
use_as
None
use_imp_exp
imp_exp
imp_exp
IMPORT
Import
IMPORT
Some
true
EXPORT
Export
EXPORT
None
epsilon
Nothing
epsilon
Some
false
clone_subst
clone_subst
@@ -378,13 +382,13 @@ list1_comma_subst:
subst
subst
NAMESPACE
ns
EQUAL
ns
CSns
2
4
NAMESPACE
ns
EQUAL
ns
CSns
floc
2
4
TYPE
qualid
EQUAL
qualid
CStsym
2
4
TYPE
qualid
EQUAL
qualid
CStsym
floc
2
4
CONSTANT
qualid
EQUAL
qualid
CSfsym
2
4
CONSTANT
qualid
EQUAL
qualid
CSfsym
floc
2
4
FUNCTION
qualid
EQUAL
qualid
CSfsym
2
4
FUNCTION
qualid
EQUAL
qualid
CSfsym
floc
2
4
PREDICATE
qualid
EQUAL
qualid
CSpsym
2
4
PREDICATE
qualid
EQUAL
qualid
CSpsym
floc
2
4
LEMMA
qualid
CSlemma
2
LEMMA
qualid
CSlemma
floc
2
GOAL
qualid
CSgoal
2
GOAL
qualid
CSgoal
floc
2
ns
ns
@@ -1062,9 +1066,9 @@ opt_semicolon:
use_module
use_module
imp_exp
MODULE
tqualid
imp_exp
MODULE
tqualid
Duse
3
None
Duse
3
Some
qualid_last
3
imp_exp
MODULE
tqualid
AS
uident
imp_exp
MODULE
tqualid
AS
uident
Duse
3
Some
5
Duse
3
Some
5
id
list1_recfun_sep_and
src/parser/ptree.ml
7d681280
@@ -94,22 +94,21 @@ type plogic_type =
PPredicate
of
pty
list
PPredicate
of
pty
list
PFunction
of
pty
list
pty
PFunction
of
pty
list
pty
type
imp_exp
Import
Export
Nothing
type
use
type
use
use_theory
qualid
use_theory
qualid
use_as
ident
option
option
use_as
string
option
use_imp_exp
imp_exp
(* None = as _, Some id = as id *)
use_imp_exp
bool
option
(* None = export, Some false = default, Some true = import *)
type
clone_subst
type
clone_subst
CSns
of
qualid
option
qualid
option
CSns
of
loc
qualid
option
qualid
option
CStsym
of
qualid
qualid
CStsym
of
loc
qualid
qualid
CSfsym
of
qualid
qualid
CSfsym
of
loc
qualid
qualid
CSpsym
of
qualid
qualid
CSpsym
of
loc
qualid
qualid
CSlemma
of
qualid
CSlemma
of
loc
qualid
CSgoal
of
qualid
CSgoal
of
loc
qualid
type
is_mutable
bool
type
is_mutable
bool
@@ -246,8 +245,8 @@ type program_decl =
Dparam
of
ident
type_v
Dparam
of
ident
type_v
Dexn
of
ident
pty
option
Dexn
of
ident
pty
option
(* modules *)
(* modules *)
Duse
of
qualid
imp_exp
(*as:*)
ident
option
Duse
of
qualid
bool
option
(*as:*)
string
option
Dnamespace
of
loc
ident
option
(* import: *)
bool
program_decl
list
Dnamespace
of
loc
string
option
(* import: *)
bool
program_decl
list
type
theory
type
theory
pth_name
ident
pth_name
ident
src/parser/typing.ml
7d681280
@@ -31,7 +31,6 @@ open Denv
(** errors *)
(** errors *)
exception
Message
of
string
exception
DuplicateTypeVar
of
string
exception
DuplicateTypeVar
of
string
exception
TypeArity
of
qualid
int
int
exception
TypeArity
of
qualid
int
int
exception
Clash
of
string
exception
Clash
of
string
@@ -47,28 +46,15 @@ exception UnboundTypeVar of string
exception
UnboundType
of
string
list
exception
UnboundType
of
string
list
exception
UnboundSymbol
of
string
list
exception
UnboundSymbol
of
string
list
let
error
loc
e
match
loc
let
error
Loc
error
None
raise
e
Some
loc
raise
Loc
Located
loc
e
let
errorm
Loc
errorm
let
errorm
loc
f
let
buf
Buffer
create
512
in
let
fmt
Format
formatter_of_buffer
buf
in
Format
kfprintf
fun
_
Format
pp_print_flush
fmt
let
s
Buffer
contents
buf
in
Buffer
clear
buf
error
loc
Message
s
fmt
f
let
rec
print_qualid
fmt
function
let
rec
print_qualid
fmt
function
Qident
s
fprintf
fmt
"%s"
s
id
Qident
s
fprintf
fmt
"%s"
s
id
Qdot
m
s
fprintf
fmt
"%a.%s"
print_qualid
m
s
id
Qdot
m
s
fprintf
fmt
"%a.%s"
print_qualid
m
s
id
let
Exn_printer
fun
fmt
e
match
e
let
Exn_printer
fun
fmt
e
match
e
Message
s
fprintf
fmt
"%s"
s
DuplicateTypeVar
s
DuplicateTypeVar
s
fprintf
fmt
"duplicate type parameter %s"
s
fprintf
fmt
s
TypeArity
id
a
n
TypeArity
id
a
n
@@ -1135,6 +1121,44 @@ let add_decl th = function
let
add_decl
th
d
let
add_decl
th
d
if
Debug
test_flag
debug_parse_only
then
th
else
add_decl
th
d
if
Debug
test_flag
debug_parse_only
then
th
else
add_decl
th
d
let
type_inst
th
t
s
let
add_inst
s
function
CSns
loc
p
q
let
find
ns
x
find_namespace_ns
x
ns
in
let
ns1
option_fold
find
t
th_export
p
in
let
ns2
option_fold
find
get_namespace
th
q
in
clone_ns
loc
t
th_local
ns2
ns1
s
CStsym
loc
p
q
let
ts1
find_tysymbol_ns
p
t
th_export
in
let
ts2
find_tysymbol
q
th
in
if
Mts
mem
ts1
s
inst_ts
then
error
loc
Clash
ts1
ts_name
id_string
s
inst_ts
Mts
add
ts1
ts2
s
inst_ts
CSfsym
loc
p
q
let
ls1
find_fsymbol_ns
p
t
th_export
in
let
ls2
find_fsymbol
q
th
in
if
Mls
mem
ls1
s
inst_ls
then
error
loc
Clash
ls1
ls_name
id_string
s
inst_ls
Mls
add
ls1
ls2
s
inst_ls
CSpsym
loc
p
q
let
ls1
find_psymbol_ns
p
t
th_export
in
let
ls2
find_psymbol
q
th
in
if
Mls
mem
ls1
s
inst_ls
then
error
loc
Clash
ls1
ls_name
id_string
s
inst_ls
Mls
add
ls1
ls2
s
inst_ls
CSlemma
loc
p
let
pr
find_prop_ns
p
t
th_export
in
if
Spr
mem
pr
s
inst_lemma
Spr
mem
pr
s
inst_goal
then
error
loc
Clash
pr
pr_name
id_string
s
inst_lemma
Spr
add
pr
s
inst_lemma
CSgoal
loc
p
let
pr
find_prop_ns
p
t
th_export
in
if
Spr
mem
pr
s
inst_lemma
Spr
mem
pr
s
inst_goal
then
error
loc
Clash
pr
pr_name
id_string
s
inst_goal
Spr
add
pr
s
inst_goal
in
fold_left
add_inst
empty_inst
s
let
add_use_clone
env
lenv
th
loc
use
subst
let
add_use_clone
env
lenv
th
loc
use
subst
if
Debug
test_flag
debug_parse_only
then
th
else
if
Debug
test_flag
debug_parse_only
then
th
else
let
q
id
split_qualid
use
use_theory
in
let
q
id
split_qualid
use
use_theory
in
@@ -1145,65 +1169,17 @@ let add_use_clone env lenv th (loc, use, subst) =
TheoryNotFound
_
error
loc
UnboundTheory
use
use_theory
TheoryNotFound
_
error
loc
UnboundTheory
use
use_theory
in
in
let
use_or_clone
th
match
subst
let
use_or_clone
th
match
subst
None
None
use_export
th
t
use_export
th
t
Some
s
clone_export
th
t
type_inst
th
t
s
Some
s
let
add_inst
s
function
CSns
p
q
let
find
ns
x
find_namespace_ns
x
ns
in
let
ns1
option_fold
find
t
th_export
p
in
let
ns2
option_fold
find
get_namespace
th
q
in
clone_ns
loc
t
th_local
ns2
ns1
s
CStsym
p
q
let
ts1
find_tysymbol_ns
p
t
th_export
in
let
ts2
find_tysymbol
q
th
in
if
Mts
mem
ts1
s
inst_ts
then
error
loc
Clash
ts1
ts_name
id_string
s
inst_ts
Mts
add
ts1
ts2
s
inst_ts
CSfsym
p
q
let
ls1
find_fsymbol_ns
p
t
th_export
in
let
ls2
find_fsymbol
q
th
in
if
Mls
mem
ls1
s
inst_ls
then
error
loc
Clash
ls1
ls_name
id_string
s
inst_ls
Mls
add
ls1
ls2
s
inst_ls
CSpsym
p
q
let
ls1
find_psymbol_ns
p
t
th_export
in
let
ls2
find_psymbol
q
th
in
if
Mls
mem
ls1
s
inst_ls
then
error
loc
Clash
ls1
ls_name
id_string
s
inst_ls
Mls
add
ls1
ls2
s
inst_ls
CSlemma
p
let
pr
find_prop_ns
p
t
th_export
in
if
Spr
mem
pr
s
inst_lemma
Spr
mem
pr
s
inst_goal
then
error
loc
Clash
pr
pr_name
id_string
s
inst_lemma
Spr
add
pr
s
inst_lemma
CSgoal
p
let
pr
find_prop_ns
p
t
th_export
in
if
Spr
mem
pr
s
inst_lemma
Spr
mem
pr
s
inst_goal
then
error
loc
Clash
pr
pr_name
id_string
s
inst_goal
Spr
add
pr
s
inst_goal
in
let
s
fold_left
add_inst
empty_inst
s
in
clone_export
th
t
s
in
let
n
match
use
use_as
None
Some
t
th_name
id_string
Some
Some
x
Some
x
id
Some
None
None
in
in
begin
try
match
use
use_imp_exp
begin
try
match
use
use_imp_exp
Nothing
Some
imp
(* use T = namespace T use_export T end *)
let
th
open_namespace
th
in
let
th
open_namespace
th
in
let
th
use_or_clone
th
in
let
th
use_or_clone
th
in
close_namespace
th
false
n
close_namespace
th
imp
use
use_as
Import
None
(* use import T = namespace T use_export T end import T *)
use_or_clone
th
let
th
open_namespace
th
in
let
th
use_or_clone
th
in
close_namespace
th
true
n
Export
use_or_clone
th
ClashSymbol
s
error
loc
Clash
s
ClashSymbol
s
error
loc
Clash
s
@@ -1214,13 +1190,12 @@ let close_theory loc lenv th =
if
Mstr
mem
id
lenv
then
error
loc
ClashTheory
id
if
Mstr
mem
id
lenv
then
error
loc
ClashTheory
id
Mstr
add
id
th
lenv
Mstr
add
id
th
lenv
let
close_namespace
loc
import
name
th
let
close_namespace
loc
import
id
th
let
id
option_map
fun
id
id
id
name
in
try
close_namespace
th
import
id
try
close_namespace
th
import
id
ClashSymbol
s
error
loc
Clash
s
ClashSymbol
s
error
loc
Clash
s
Local Variables:
Local Variables:
compile-command: "unset LANG; make -C ../..
test
compile-command: "unset LANG; make -C ../.."
End:
End:
src/parser/typing.mli
7d681280
@@ -35,7 +35,7 @@ val add_use_clone :
unit
Env
library
theory
Mstr
t
theory_uc
Ptree
use_clone
theory_uc
unit
Env
library
theory
Mstr
t
theory_uc
Ptree
use_clone
theory_uc
val
close_namespace
val
close_namespace
Loc
position
bool
P
tr
ee
ident
option
theory_uc
theory_uc
Loc
position
bool
s
tr
ing
option
theory_uc
theory_uc
val
close_theory
Loc
position
theory
Mstr
t
theory_uc
theory
Mstr
t
val
close_theory
Loc
position
theory
Mstr
t
theory_uc
theory
Mstr
t
@@ -95,3 +95,4 @@ val list_fields: theory_uc ->
(** check that the given fields all belong to the same record type
and do not appear several times *)
val
type_inst
theory_uc
theory
Ptree
clone_subst
list
th_inst
src/programs/pgm_typing.ml
7d681280
@@ -2262,7 +2262,7 @@ let find_module penv lmod q id = match q with
Mstr
find
id
lmod
Mstr
find
id
lmod
_
_
_
_
(* module in file f *)
Mstr
find
id
Env
read_lib_file
penv
q
Mstr
find
id
fst
Env
read_lib_file
penv
q
(* env = to retrieve theories and modules from the loadpath
lmod = local modules *)
@@ -2346,22 +2346,13 @@ let rec decl ~wp env ltm lmod uc = function
Not_found
Not_found
errorm
loc
"@[unbound module %a@]"
print_qualid
qid
errorm
loc
print_qualid
qid
in
in
let
n
match
use_as
None
Some
m
m_name
id_string
Some
x
Some
x
id
in
begin
try
match
imp_exp
begin
try
match
imp_exp
Nothing
Some
imp
let
uc
open_namespace
uc
in
let
uc
open_namespace
uc
in
let
uc
use_export
uc
m
in
let
uc
use_export
uc
m
in
close_namespace
uc
false
n
close_namespace
uc
imp
use_as
Import
None
let
uc
open_namespace
uc
in
let
uc
use_export
uc
m
in
close_namespace
uc
true
n
Export
use_export
uc
m
use_export
uc
m
ClashSymbol
s
ClashSymbol
s
errorm
loc
"clash with previous symbol %s"
s
errorm
loc
s
@@ -2369,7 +2360,6 @@ let rec decl ~wp env ltm lmod uc = function
Ptree
Dnamespace
loc
id
import
dl
Ptree
Dnamespace
loc
id
import
dl
let
uc
open_namespace
uc
in
let
uc
open_namespace
uc
in
let
uc
fold_left
decl
wp
env
ltm
lmod
uc
dl
in
let
uc
fold_left
decl
wp
env
ltm
lmod
uc
dl
in
let
id
option_map
fun
id
id
id
id
in
begin
try
close_namespace
uc
import
id
begin
try
close_namespace
uc
import
id
ClashSymbol
s
errorm
loc
s
ClashSymbol
s
errorm
loc
s
Ptree
Dlogic
TypeDecl
d
Ptree
Dlogic
TypeDecl
d
src/util/exn_printer.mli
7d681280
@@ -26,5 +26,5 @@ val register : exn_printer -> unit
(* Register a formatter of exception *)
val
exn_printer
exn_printer
val
exn_printer
exn_printer
(* exn_printer fmt exn
print
the
exception using all
the
previously
exn_printer fmt exn
print
s
exception
[exn]
using all previously
registered printer and return *)
registered printer
s
and return
s
src/util/loc.ml
7d681280
@@ -54,8 +54,6 @@ let user_position fname lnum cnum1 cnum2 = (fname,lnum,cnum1,cnum2)
let
get
loc
loc
let
get
loc
loc
exception
Located
of
position
exn
let
dummy_position
let
dummy_position
let
join
f1
l1
b1
e1
f2
,_,
b2
e2
let
join
f1
l1
b1
e1
f2
,_,
b2
e2
@@ -77,9 +75,44 @@ let gen_report_position fmt (f,l,b,e) =
let
report_position
fmt
fprintf
fmt
"%a:@
\n
gen_report_position
let
report_position
fmt
fprintf
fmt
"%a:@
\n
gen_report_position
(* located exceptions *)
exception
Located
of
position
exn
let
try1
loc
f
x
try
f
x
Located
_
as
e
raise
e
e
raise
Located
loc
e
let
try2
loc
f
x
y
try
f
x
y
Located
_
as
e
raise
e
e
raise
Located
loc
e
let
try3
loc
f
x
y
z
try
f
x
y
z
Located
_
as
e
raise
e
e
raise
Located
loc
e
let
try4
loc
f
x
y
z
t
try
f
x
y
z
t
Located
_
as
e
raise
e
e
raise
Located
loc
e
let
error
