Commit 7c28220d authored by Andrei Paskevich's avatar Andrei Paskevich
invariants: minor
parent 5ef42162
...@@ -134,12 +134,17 @@ let rec get_point st n = ...@@ -134,12 +134,17 @@ let rec get_point st n =
| L n -> get_point st n | L n -> get_point st n
| b -> n, b | b -> n, b
let isV = function V -> true | _ -> false
let add_point v c sr =
if isV c then sr else Mvs.add v c sr
let mkC css = let mkC css =
let chk _ l = List.for_all (function V -> true | _ -> false) l in let chk _ l = List.for_all isV l in
if Mls.for_all chk css then V else C css if Mls.for_all chk css then V else C css
let mkR pjs = let mkR pjs =
let chk _ c = match c with V -> true | _ -> false in let chk _ c = isV c in
if Mls.for_all chk pjs then V else R pjs if Mls.for_all chk pjs then V else R pjs
(* TODO: (* TODO:
...@@ -204,9 +209,9 @@ let add_var kn st v = ...@@ -204,9 +209,9 @@ let add_var kn st v =
Mls.add cs (List.map2 conv_field c.rs_cty.cty_args tyl) m in Mls.add cs (List.map2 conv_field c.rs_cty.cty_args tyl) m in
mkC (List.fold_left add_constr Mls.empty d.itd_constructors) mkC (List.fold_left add_constr Mls.empty d.itd_constructors)
in in
match down [] (t_var v) v.vs_ty with let c = down [] (t_var v) v.vs_ty in
| V -> st (* not broken *) let sr = add_point v c st.s_roots in
| c -> { s_roots = Mvs.add v c st.s_roots; s_points = !rp } { s_roots = sr; s_points = !rp }
let cap_valid st c = let cap_valid st c =
let rec down = function let rec down = function
...@@ -218,7 +223,7 @@ let cap_valid st c = ...@@ -218,7 +223,7 @@ let cap_valid st c =
let add_pat st c p = let add_pat st c p =
let rec down rt c p = let rec down rt c p =
if c = V then rt else if isV c then rt else
match p.pat_node with match p.pat_node with
| Pwild -> rt | Pwild -> rt
| Pvar v -> Mvs.add v c rt | Pvar v -> Mvs.add v c rt
...@@ -335,7 +340,7 @@ let cap_of_term kn st t = ...@@ -335,7 +340,7 @@ let cap_of_term kn st t =
| Tlet (t0,tb) -> | Tlet (t0,tb) ->
let t0, c0 = down sr [] t0 in let t0, c0 = down sr [] t0 in
let v, t1 = t_open_bound tb in let v, t1 = t_open_bound tb in
let sr = Mvs.add v c0 sr in let sr = add_point v c0 sr in
let t1, c1 = down sr pjl t1 in let t1, c1 = down sr pjl t1 in
t_label_copy t (t_let_close v t0 t1), c1 t_label_copy t (t_let_close v t0 t1), c1
| Tcase (t0,bl) -> | Tcase (t0,bl) ->
