Commit 79f4dedf authored by Andrei Paskevich's avatar Andrei Paskevich
TPTP typing, alpha-release
parent b6970283
...@@ -310,11 +310,11 @@ lib/plugins/%.cmo: plugins/transform/%.cmo ...@@ -310,11 +310,11 @@ lib/plugins/%.cmo: plugins/transform/%.cmo
lib/plugins/tptp.cmxs: $(TFF1CMX) lib/plugins/tptp.cmxs: $(TFF1CMX)
$(if $(QUIET), @echo 'Linking $@' &&) \ $(if $(QUIET), @echo 'Linking $@' &&) \
$(OCAMLOPT) $(OFLAGS) -shared -o $@ $< $(OCAMLOPT) $(OFLAGS) -shared -o $@ $^
lib/plugins/tptp.cmo: $(TFF1CMO) lib/plugins/tptp.cmo: $(TFF1CMO)
$(if $(QUIET),@echo 'Linking $@' &&) \ $(if $(QUIET),@echo 'Linking $@' &&) \
$(OCAMLC) $(BFLAGS) -pack -o $@ $< $(OCAMLC) $(BFLAGS) -pack -o $@ $^
include .depend.plugins include .depend.plugins
...@@ -252,7 +252,8 @@ and comment_line = parse ...@@ -252,7 +252,8 @@ and comment_line = parse
let ast = with_location (tptp_file token) lb in let ast = with_location (tptp_file token) lb in
Tptp_typing.typecheck env path ast Tptp_typing.typecheck env path ast
let () = Env.register_format "tptp" ["p";"ax"] read_channel (* let () = Env.register_format "tptp" ["p";"ax"] read_channel *)
let () = Env.register_format "tff1" ["p";"ax"] read_channel
...@@ -148,7 +148,7 @@ unitary_formula: ...@@ -148,7 +148,7 @@ unitary_formula:
{ mk_e (Enot (mk_e (Eequ ($1,$3)))) } { mk_e (Enot (mk_e (Eequ ($1,$3)))) }
| term EQUAL term | term EQUAL term
{ mk_e (Eequ ($1,$3)) } { mk_e (Eequ ($1,$3)) }
| LEFTPAR unitary_formula RIGHTPAR | LEFTPAR formula RIGHTPAR
{ $2 } { $2 }
| plain_term | plain_term
{ $1 } { $1 }
...@@ -43,31 +43,26 @@ let errorm ?loc f = ...@@ -43,31 +43,26 @@ let errorm ?loc f =
Buffer.clear buf; Buffer.clear buf;
error ?loc (Message s)) fmt f error ?loc (Message s)) fmt f
exception TypeInference
exception TypeExpected exception TypeExpected
exception TermExpected exception TermExpected
exception FmlaExpected exception FmlaExpected
exception TVarExpected
exception VarExpected
exception InvalidDummy exception InvalidDummy
exception BadTyQuant exception DependentTy
exception BadArity exception BadArity
let () = Exn_printer.register (fun fmt e -> match e with let () = Exn_printer.register (fun fmt e -> match e with
| Message s -> fprintf fmt "%s" s | Message s -> fprintf fmt "%s" s
| TypeInference -> fprintf fmt "type inference is not supported"
| TypeExpected -> fprintf fmt "type expression expected" | TypeExpected -> fprintf fmt "type expression expected"
| TermExpected -> fprintf fmt "term expression expected" | TermExpected -> fprintf fmt "term expression expected"
| FmlaExpected -> fprintf fmt "formula expression expected" | FmlaExpected -> fprintf fmt "formula expression expected"
| TVarExpected -> fprintf fmt "type variable expected"
| VarExpected -> fprintf fmt "term variable expected"
| InvalidDummy -> fprintf fmt "invalid type placeholder" | InvalidDummy -> fprintf fmt "invalid type placeholder"
| BadTyQuant -> fprintf fmt "forbidden type quantifier" | DependentTy -> fprintf fmt "dependent type"
| BadArity -> fprintf fmt "bad arity" | BadArity -> fprintf fmt "bad arity"
| _ -> raise e) | _ -> raise e)
type symbol = type symbol =
| STVar of ty | STSko of ty
| STVar of tvsymbol
| SVar of vsymbol | SVar of vsymbol
| SType of tysymbol | SType of tysymbol
| SFunc of tvsymbol list * lsymbol | SFunc of tvsymbol list * lsymbol
...@@ -86,12 +81,13 @@ let d_univ = create_ty_decl [ts_univ, Tabstract] ...@@ -86,12 +81,13 @@ let d_univ = create_ty_decl [ts_univ, Tabstract]
let find_tv ~loc env impl s = let find_tv ~loc env impl s =
let tv = try Mstr.find s env with Not_found -> let tv = try Mstr.find s env with Not_found ->
try Hashtbl.find impl s with Not_found -> try Hashtbl.find impl s with Not_found ->
let tv = STVar (ty_var (create_tvsymbol (id_user s loc))) in let tv = STVar (create_tvsymbol (id_user s loc)) in
Hashtbl.add impl s tv; Hashtbl.add impl s tv;
tv in tv in
match tv with match tv with
| STVar tv -> tv | STVar tv -> ty_var tv
| _ -> error ~loc TVarExpected | STSko ty -> ty
| _ -> error ~loc TypeExpected
let find_vs ~loc env impl s = let find_vs ~loc env impl s =
let vs = try Mstr.find s env with Not_found -> let vs = try Mstr.find s env with Not_found ->
...@@ -100,16 +96,19 @@ let find_vs ~loc env impl s = ...@@ -100,16 +96,19 @@ let find_vs ~loc env impl s =
Hashtbl.add impl s vs; Hashtbl.add impl s vs;
vs in vs in
match vs with match vs with
| SVar vs -> vs | SVar vs -> t_var vs
| _ -> error ~loc VarExpected | _ -> error ~loc TermExpected
let find_ts ~loc env impl s args = let find_ts ~loc env impl s args =
try Mstr.find s env with Not_found -> let ts = try Mstr.find s env with Not_found ->
let args = List.map (fun _ -> create_tvsymbol (id_fresh "a")) args in let args = List.map (fun _ -> create_tvsymbol (id_fresh "a")) args in
let ts = SType (create_tysymbol (id_user s loc) args None) in let ts = SType (create_tysymbol (id_user s loc) args None) in
Hashtbl.add impl s ts; Hashtbl.add impl s ts;
ts ts in
match ts with
| SType ts -> ts
let find_fs ~loc env impl s args = let find_fs ~loc env impl s args =
try Mstr.find s env with Not_found -> try Mstr.find s env with Not_found ->
...@@ -129,9 +128,7 @@ let find_ps ~loc env impl s args = ...@@ -129,9 +128,7 @@ let find_ps ~loc env impl s args =
let rec ty denv env impl { e_loc = loc; e_node = n } = match n with let rec ty denv env impl { e_loc = loc; e_node = n } = match n with
| Eapp (aw,al) -> | Eapp (aw,al) ->
let ts = match find_ts ~loc env impl aw al with let ts = find_ts ~loc env impl aw al in
| SType ts -> ts
| _ -> error ~loc TypeExpected in
let tys = List.map (ty denv env impl) al in let tys = List.map (ty denv env impl) al in
ty_app ts tys ty_app ts tys
| Edef (dw,al) -> | Edef (dw,al) ->
...@@ -165,7 +162,7 @@ let rec term denv env impl { e_loc = loc; e_node = n } = match n with ...@@ -165,7 +162,7 @@ let rec term denv env impl { e_loc = loc; e_node = n } = match n with
let tl = List.map (term denv env impl) al in let tl = List.map (term denv env impl) al in
t_app_infer fs tl t_app_infer fs tl
| Evar v -> | Evar v ->
t_var (find_vs ~loc env impl v) find_vs ~loc env impl v
| Edob _ -> | Edob _ ->
(* TODO: distinct objects *) (* TODO: distinct objects *)
assert false assert false
...@@ -177,7 +174,7 @@ let rec term denv env impl { e_loc = loc; e_node = n } = match n with ...@@ -177,7 +174,7 @@ let rec term denv env impl { e_loc = loc; e_node = n } = match n with
| Eite (e1,e2,e3) -> | Eite (e1,e2,e3) ->
(* we can't fix the polarity of the condition here, (* we can't fix the polarity of the condition here,
and so type quantifiers are forbidden in terms *) hence type quantifiers are forbidden in terms *)
let cn,_ = fmla denv env impl None [] e1 in let cn,_ = fmla denv env impl None [] e1 in
let th = term denv env impl e2 in let th = term denv env impl e2 in
let el = term denv env impl e3 in let el = term denv env impl e3 in
...@@ -206,17 +203,18 @@ and fmla denv env impl pol tvl { e_loc = loc; e_node = n } = match n with ...@@ -206,17 +203,18 @@ and fmla denv env impl pol tvl { e_loc = loc; e_node = n } = match n with
let loc = e.e_loc in let loc = e.e_loc in
if e.e_node = Edef (DT DTtype, []) then if e.e_node = Edef (DT DTtype, []) then
match pol,quant with match pol,quant with
| None, _ -> error ~loc BadTyQuant | None, _ ->
errorm ~loc "Invalid type quantifier"
| Some true, Qexists (* goals *) | Some true, Qexists (* goals *)
| Some false, Qforall (* premises *) -> | Some false, Qforall (* premises *) ->
let tv = create_tvsymbol (id_user s loc) in let tv = create_tvsymbol (id_user s loc) in
Mstr.add s (STVar (ty_var tv)) env, pol, tv::tvl, vl, true Mstr.add s (STVar tv) env, pol, tv::tvl, vl, true
| Some true, Qforall (* goals *) | Some true, Qforall (* goals *)
| Some false, Qexists (* premises *) -> | Some false, Qexists (* premises *) ->
let ts = create_tysymbol (id_user s loc) tvl None in let ts = create_tysymbol (id_user s loc) tvl None in
let tv = ty_app ts (List.map ty_var tvl) in let tv = ty_app ts (List.map ty_var tvl) in
Hashtbl.add impl ("_sk_" ^ s) (SType ts); Hashtbl.add impl ("_sk_" ^ s) (SType ts);
Mstr.add s (STVar tv) env, pol, tvl, vl, true Mstr.add s (STSko tv) env, pol, tvl, vl, true
else else
let ty = ty denv env impl e in let ty = ty denv env impl e in
let vs = create_vsymbol (id_user s loc) ty in let vs = create_vsymbol (id_user s loc) ty in
...@@ -226,8 +224,7 @@ and fmla denv env impl pol tvl { e_loc = loc; e_node = n } = match n with ...@@ -226,8 +224,7 @@ and fmla denv env impl pol tvl { e_loc = loc; e_node = n } = match n with
let f1,b1 = fmla denv env impl pol tvl e1 in let f1,b1 = fmla denv env impl pol tvl e1 in
let quant = match quant with let quant = match quant with
| Qforall -> Tforall | Qforall -> Tforall
| Qexists -> Texists | Qexists -> Texists in
in
t_quant_close quant (List.rev vl) [] f1, b || b1 t_quant_close quant (List.rev vl) [] f1, b || b1
(* here we can treat type quantifiers in 'if' conditions, (* here we can treat type quantifiers in 'if' conditions,
...@@ -319,5 +316,109 @@ and let_args denv env impl loc e tvl vl al = ...@@ -319,5 +316,109 @@ and let_args denv env impl loc e tvl vl al =
in in
args Mtv.empty Mvs.empty tvl vl al args Mtv.empty Mvs.empty tvl vl al
let typecheck _env _path _ast = Mstr.empty let typedecl denv env impl loc s (tvl,(el,e)) =
(* type constructor *)
if tvl <> [] then error ~loc DependentTy else
let ntv { e_node = n ; e_loc = loc } = match n with
| Edef (DT DTtype, []) -> create_tvsymbol (id_fresh "a")
| _ -> error ~loc DependentTy
in
let ts = create_tysymbol (id_user s loc) (List.map ntv el) None in
Hashtbl.add impl s (SType ts)
else
(* function/predicate symbol *)
let ntv (s, { e_node = n ; e_loc = loc }) = match n with
| Edef (DT DTtype, []) -> create_tvsymbol (id_fresh s)
in
let tvl = List.map ntv tvl in
let add e v = Mstr.add v.tv_name.id_string (STVar v) e in
let env = List.fold_left add env tvl in
let tyl = List.map (ty denv env impl) el in
let tyv =
if e.e_node = Edef (DT DTprop, []) then None
else Some (ty denv env impl e) in
let ls = create_lsymbol (id_user s loc) tyl tyv in
Hashtbl.add impl s (SFunc (tvl,ls))
let flush_impl ~strict env uc impl =
let update s e (env,uc) = match e with
| SType ts ->
Mstr.add s e env, add_ty_decl uc [ts,Tabstract]
| SFunc (_,ls) | SPred (_,ls) ->
Mstr.add s e env, add_logic_decl uc [ls,None]
| STVar tv when strict ->
errorm ?loc:tv.tv_name.id_loc "Unbound type variable %s" s
| SVar vs when strict ->
errorm ?loc:vs.vs_name.id_loc "Unbound variable %s" s
| STVar _ | SVar _ -> env,uc
(* none of these is possible in implicit *)
| SletF _ | SletP _ | STSko _ -> assert false
in
let res = Hashtbl.fold update impl (env,uc) in
Hashtbl.clear impl;
res
let typecheck _genv path ast =
(* TODO: built-ins *)
let denv = () in
let impl = Hashtbl.create 17 in
let conj = ref false in
let negc = ref false in
let input (env,uc) = function
(* illegal stuff *)
| Formula (_,_,_,_,loc) when !conj ->
errorm ~loc "No formula can appear below a conjecture"
| Formula (_,_,r,_,loc) when !negc && r <> Negated_conjecture ->
errorm ~loc "This formula cannot appear below a negated_conjecture"
| Include (_,_,loc) when !conj || !negc ->
errorm ~loc "Includes cannot appear below conjectures"
(* type declarations *)
| Formula (_,_,Type,TypedAtom (s,e),loc) ->
typedecl denv env impl loc s e;
flush_impl ~strict:true env uc impl
| Formula (_,_,Type,_,loc)
| Formula (_,_,_,TypedAtom _,loc) ->
errorm ~loc "Invalid type declaration"
(* logical formulas *)
| Formula (_,_,_,Sequent _,loc) -> (* TODO *)
errorm ~loc "Sequents are not supported"
| Formula (k,s,r,LogicFormula e,loc) ->
if r = Conjecture then conj := true;
if r = Negated_conjecture then negc := true;
let strict = k <> CNF in
let pol = r = Conjecture in
let f,_ = fmla denv env impl (Some pol) [] e in
let f = if strict then f else
let q = if pol then Texists else Tforall in
let vl = Mvs.keys f.t_vars in
t_quant_close q vl [] f in
let env,uc = flush_impl ~strict env uc impl in
let pr = create_prsymbol (id_user s loc) in
if r <> Conjecture then
env, add_prop_decl uc Paxiom pr f
else if Stv.is_empty (t_ty_freevars Stv.empty f) then
env, add_prop_decl uc Pgoal pr f
else
(* Why3 does not support polymorphic goals *)
let uc = add_prop_decl uc Paxiom pr (t_not f) in
let pr = create_prsymbol (id_fresh "contradiction") in
env, add_prop_decl uc Pgoal pr t_false
(* includes *)
| Include (_f,[],_loc) ->
assert false (* TODO: include *)
| Include (_,_,loc) ->
errorm ~loc "Formula selection is not supported"
in
let env = Mstr.empty in
(* FIXME: localize the identifier *)
let uc = create_theory ~path (id_fresh "T") in
let _,uc = List.fold_left input (env,uc) ast in
let uc = if not !negc then uc else
add_prop_decl uc Pgoal pr t_false in
Mstr.singleton "T" (close_theory uc)
