GitLab
Support
Community forum
Keyboard shortcuts
why3
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
Why3
why3
7747ddde
7747ddde
MARCHE Claude
Try Why3: execution of main function in each module
01c1e52a
4
4 changed files
40 additions
13 deletions
+40
-13
src/tools/why3execute.ml
+2
-2
src/trywhy3/trywhy3.ml
+29
-2
src/whyml/mlw_interp.ml
+7
-7
src/whyml/mlw_interp.mli
+2
-2
7747ddde
@@ -65,8 +65,8 @@ let do_input f =
exit
exit
Some
d
Some
d
try
try
printf
"@[<hov 2>Execution of %s.%s ():@
\n
mid
name
printf
\n
%a"
mid
name
Mlw_interp
eval_global_symbol
env
m
d
Mlw_interp
eval_global_symbol
env
m
d
e
when
Debug
test_noflag
Debug
stack_trace
e
when
Debug
test_noflag
Debug
stack_trace
printf
\n
printf
\n
raise
e
in
raise
e
in
7747ddde
@@ -156,8 +156,35 @@ let why3_execute (modules,_theories) =
Stdlib
Mstr
fold
Stdlib
Mstr
fold
fun
_k
m
acc
fun
_k
m
acc
let
th
m
Mlw_module
mod_theory
in
let
th
m
Mlw_module
mod_theory
in
let
name
th
Theory
th_name
Ident
id_string
in
let
modname
th
Theory
th_name
Ident
id_string
in
Html
of_string
"Module "
name
acc
try
let
ps
Mlw_module
ns_find_ps
m
Mlw_module
mod_export
"main"
in
let
moduleans
Html
of_string
"Module "
modname
in
let
ans
match
Mlw_decl
find_definition
m
Mlw_module
mod_known
ps
None
moduleans
Html
ul
Html
of_string
"function main has no definition"
Some
d
try
moduleans
Html
ul
Html
of_string
Pp
sprintf
"%a"
Mlw_interp
eval_global_symbol
env
m
d
e
moduleans
Html
ul
Html
of_string
Pp
sprintf
"exception during execution of function main : %a (%s)"
Exn_printer
exn_printer
e
Printexc
to_string
e
in
ans
acc
Not_found
acc
modules
modules
in
in
Html
ul
mods
Html
ul
mods
7747ddde
@@ -1373,7 +1373,7 @@ let eval_global_expr env mkm tkm _writes e =
let
eval_global_symbol
env
m
d
let
eval_global_symbol
env
m
fmt
d
let
lam
d
Mlw_expr
fun_lambda
in
let
lam
d
Mlw_expr
fun_lambda
in
match
lam
Mlw_expr
l_args
match
lam
Mlw_expr
l_args
pvs
when
Mlw_ty
ity_equal
pvs
Mlw_ty
pv_ity
Mlw_ty
ity_unit
pvs
when
Mlw_ty
ity_equal
pvs
Mlw_ty
pv_ity
Mlw_ty
ity_unit
@@ -1382,7 +1382,7 @@ let eval_global_symbol env m d =
let
eff
spec
Mlw_ty
c_effect
in
let
eff
spec
Mlw_ty
c_effect
in
let
writes
eff
Mlw_ty
eff_writes
in
let
writes
eff
Mlw_ty
eff_writes
in
let
body
lam
Mlw_expr
l_expr
in
let
body
lam
Mlw_expr
l_expr
in
printf
"@[<hov 2> type:@ %a@]@."
fprintf
fmt
Mlw_pretty
print_vty
body
Mlw_expr
e_vty
Mlw_pretty
print_vty
body
Mlw_expr
e_vty
(* printf "effect: %a@\n" *)
(* Mlw_pretty.print_effect body.Mlw_expr.e_effect; *)
@@ -1393,26 +1393,26 @@ let eval_global_symbol env m d =
in
in
match
res
match
res
Normal
_
Normal
_
printf
"@[<hov 2> result:@ %a@
\n
globals:@ %a@]@."
fprintf
fmt
\n
globals:@ %a@]@."
print_logic_result
res
print_vsenv
final_env
print_logic_result
res
print_vsenv
final_env
printf
"@[<hov 2> result:@ %a@\nstate :@ %a@]@."
fprintf fmt
(print_result m.Mlw_module.mod_known
m.Mlw_module.mod_theory.Theory.th_known st) res
print_state st
print_state st
Excep
_
Excep
_
printf
"@[<hov 2>exceptional result:@ %a@
\n
globals:@ %a@]@."
fprintf
fmt
\n
globals:@ %a@]@."
print_logic_result
res
print_vsenv
final_env
print_logic_result
res
print_vsenv
final_env
printf
"@[<hov 2>exceptional result:@ %a@\nstate:@ %a@]@."
fprintf fmt
print_state st;
print_state st;
exit
exit
Irred
_
Fun
_
Irred
_
Fun
_
printf
\n
fprintf
fmt
\n
eprintf
"Execution error: %a@."
print_logic_result
res
eprintf
print_logic_result
res
exit
2
exit
2
7747ddde
@@ -15,8 +15,8 @@ type value
val
print_value
Format
formatter
value
unit
val
print_value
Format
formatter
value
unit
val
eval_global_term
val
eval_global_term
Env
env
Decl
known_map
Term
term
value
Env
env
Decl
known_map
Term
term
value
val
eval_global_symbol
val
eval_global_symbol
Env
env
Mlw_module
modul
Mlw_expr
fun_defn
unit
Env
env
Mlw_module
modul
Format
formatter
Mlw_expr
fun_defn
unit
