Theory : use
parent c47b1f02
theory A theory A
type t
namespace S namespace S
type t type t
type t
end end
end end
(* test file *)
theory A
type t
theory B
use export A
type t
(* test file *)
theory A
type t
theory B
type t
use export A
(* test file *)
theory A
type t
theory B
type t
use import A
(* test file *)
theory A
type t
theory B
use import A
type t
(* test file *)
theory A
type t
theory B
use export A
logic c : A.t
(* test file *)
theory A
logic c : t
...@@ -61,7 +61,7 @@ let id_user sh ln loc = create_ident sh ln (User loc) ...@@ -61,7 +61,7 @@ let id_user sh ln loc = create_ident sh ln (User loc)
type printer = (string, int) Hashtbl.t * (int, string) Hashtbl.t type printer = (string, int) Hashtbl.t * (int, string) Hashtbl.t
let create_printer _ = Hashtbl.create 1997, Hashtbl.create 1997 let create_printer () = Hashtbl.create 1997, Hashtbl.create 1997
let rec find_index indices name ind = let rec find_index indices name ind =
if Hashtbl.mem indices (name ^ string_of_int ind) if Hashtbl.mem indices (name ^ string_of_int ind)
...@@ -71,16 +71,17 @@ let find_unique indices name = ...@@ -71,16 +71,17 @@ let find_unique indices name =
try try
let ind = Hashtbl.find indices name + 1 in let ind = Hashtbl.find indices name + 1 in
let ind = find_index indices name ind in let ind = find_index indices name ind in
let _ = Hashtbl.add indices name ind in Hashtbl.add indices name ind;
name ^ string_of_int ind name ^ string_of_int ind
with Not_found -> with Not_found ->
name name
let id_unique (indices,values) id = let id_unique (indices,values) id =
try Hashtbl.find values id.id_tag try
let name = find_unique indices id.id_long in let name = find_unique indices id.id_long in
let _ = Hashtbl.add values id.id_tag name in Hashtbl.add values id.id_tag name;
let _ = Hashtbl.add indices name 0 in Hashtbl.add indices name 0;
name name
...@@ -25,17 +25,11 @@ open Term ...@@ -25,17 +25,11 @@ open Term
(** Error reporting *) (** Error reporting *)
type error = exception CloseTheory
| OpenTheory exception NoOpenedNamespace
| CloseTheory exception RedeclaredIdent of ident
| NoOpenedTheory exception CannotInstantiate
| NoOpenedNamespace exception ClashSymbol of string
| RedeclaredIdent
| CannotInstantiate
exception Error of error
let error e = raise (Error e)
(** The environment type *) (** The environment type *)
...@@ -62,14 +56,14 @@ type decl = ...@@ -62,14 +56,14 @@ type decl =
type decl_or_use = type decl_or_use =
| Decl of decl | Decl of decl
| Use of t | Use of theory
and t = { and theory = {
t_name : ident; th_name : ident;
t_local : Sid.t; (* locally declared abstract symbols *) th_param : Sid.t; (* locally declared abstract symbols *)
t_known : Sid.t; (* imported and locally declared symbols *) th_known : ident Mid.t; (* imported and locally declared symbols *)
t_namespace : namespace; th_export : namespace;
t_decls : decl_or_use list; th_decls : decl_or_use list;
and namespace = { and namespace = {
...@@ -80,12 +74,14 @@ and namespace = { ...@@ -80,12 +74,14 @@ and namespace = {
namespace : namespace M.t; namespace : namespace M.t;
type th = { type theory_uc = {
th_name : ident; uc_name : ident;
th_local : Sid.t; uc_param : Sid.t;
th_known : Sid.t; uc_known : ident Mid.t;
th_stack : (namespace * namespace) list; (* stack of imports/exports *) uc_visible: namespace list; (* stack of visible symbols *)
th_decls : decl_or_use list; uc_import : namespace list;
uc_export : namespace list;
uc_decls : decl_or_use list;
(** Creating environments *) (** Creating environments *)
...@@ -99,41 +95,92 @@ let empty_ns = { ...@@ -99,41 +95,92 @@ let empty_ns = {
let create_theory n = { let create_theory n = {
th_name = n; uc_name = n;
th_local = Sid.empty; uc_param = Sid.empty;
th_known = Sid.empty; uc_known = Mid.add n n Mid.empty;
th_stack = [empty_ns, empty_ns]; uc_visible = [empty_ns];
th_decls = []; uc_import = [empty_ns];
uc_export = [empty_ns];
uc_decls = [];
let close_theory th = match th.th_stack with let close_theory th = match th.uc_export with
| [_, e] -> | [e] ->
{ t_name = th.th_name; { th_name = th.uc_name;
t_local = th.th_local; th_param = th.uc_param;
t_known = th.th_known; th_known = th.uc_known;
t_namespace = e; th_export = e;
t_decls = List.rev th.th_decls; } th_decls = List.rev th.uc_decls; }
| _ -> | _ ->
error CloseTheory raise CloseTheory
let open_namespace th = match th.th_stack with let open_namespace th = match th.uc_visible with
| (i, _) :: _ as st -> | ns :: _ as st ->
{ th with th_stack = (i, empty_ns) :: st } { th with
uc_visible = ns :: st;
uc_import = empty_ns :: th.uc_import;
uc_export = empty_ns :: th.uc_export; }
assert false assert false
let close_namespace th n ~import = match th.th_stack with let fusion ~check ns1 ns2 =
| (_, e0) :: (i, e) :: st -> let merge_ns m1 m2 =
M.fold
(fun k1 v1 m2 ->
if check && M.mem k1 m2 then raise (ClashSymbol k1);
M.add k1 v1 m2)
m1 m2
in
{ tysymbols = merge_ns ns1.tysymbols ns2.tysymbols;
fsymbols = merge_ns ns1.fsymbols ns2.fsymbols;
psymbols = merge_ns ns1.psymbols ns2.psymbols;
props = merge_ns ns1.props ns2.props;
namespace = merge_ns ns1.namespace ns2.namespace; }
let add_known id uc =
if Mid.mem id uc.uc_known then raise (RedeclaredIdent id);
{ uc with uc_known = Mid.add id uc.uc_name uc.uc_known }
let close_namespace uc n ~import =
match uc.uc_visible, uc.uc_import, uc.uc_export with
| v0 :: v1 :: stv, i0 :: i1 :: sti, e0 :: e1 :: ste ->
let s = n.id_short in let s = n.id_short in
let add ns = { ns with namespace = M.add s e0 ns.namespace } in let add ns1 ns2 = { ns2 with namespace = M.add s ns1 ns2.namespace } in
{ th with th_stack = (add i, add e) :: st } let v1 = add v0 v1 and i1 = add i0 i1 and e1 = add e0 e1 in
| [_] -> let v1 = if import then fusion ~check:false v0 v1 else v1 in
error NoOpenedNamespace let i1 = if import then fusion ~check:true i0 i1 else i1 in
| [] -> add_known n
{ uc with
uc_visible = v1 :: stv;
uc_import = i1 :: sti;
uc_export = e1 :: ste; }
| [_], [_], [_] ->
raise NoOpenedNamespace
| _ ->
let use_export th t = let merge_known m1 m2 =
assert false (* TODO *) Mid.fold
(fun k1 id1 m ->
try
let id2 = Mid.find k1 m2 in
if id1 != id2 then raise (RedeclaredIdent id1);
m
with Not_found ->
Mid.add k1 id1 m)
m1 m2
let use_export uc th =
| v0 :: stv, i0 :: sti, e0 :: ste ->
{ uc with
uc_visible = fusion ~check:false th.th_export v0 :: stv;
uc_import = fusion ~check:true th.th_export i0 :: sti;
uc_export = fusion ~check:false th.th_export e0 :: ste;
uc_known = merge_known uc.uc_known th.th_known;
| _ ->
assert false
type th_inst = { type th_inst = {
inst_ts : tysymbol Mts.t; inst_ts : tysymbol Mts.t;
...@@ -142,58 +189,64 @@ type th_inst = { ...@@ -142,58 +189,64 @@ type th_inst = {
let check_sym id t = let check_sym id t =
if Sid.mem id t.t_local then () else error CannotInstantiate if not (Sid.mem id t.th_param) then raise CannotInstantiate
let clone_export th t i = let clone_export th t i =
let check_ts s _ = check_sym s.ts_name t in let check_ts s _ = check_sym s.ts_name t in
let _ = Mts.iter check_ts i.inst_ts in Mts.iter check_ts i.inst_ts;
let check_fs s _ = check_sym s.fs_name t in let check_fs s _ = check_sym s.fs_name t in
let _ = Mfs.iter check_fs i.inst_fs in Mfs.iter check_fs i.inst_fs;
let check_ps s _ = check_sym s.ps_name t in let check_ps s _ = check_sym s.ps_name t in
let _ = Mps.iter check_ps i.inst_ps in Mps.iter check_ps i.inst_ps;
assert false (* TODO *) assert false (* TODO *)
let add_tysymbol x ty ns = { ns with tysymbols = M.add x ty ns.tysymbols } let generic_add ~check x v m =
let add_fsymbol x ty ns = { ns with fsymbols = M.add x ty ns.fsymbols } if check && M.mem x m then raise (ClashSymbol x);
let add_psymbol x ty ns = { ns with psymbols = M.add x ty ns.psymbols } M.add x v m
let add_tysymbol ~check x ty ns =
{ ns with tysymbols = generic_add ~check x ty ns.tysymbols }
let add_fsymbol ~check x ty ns =
{ ns with fsymbols = generic_add ~check x ty ns.fsymbols }
let add_psymbol ~check x ty ns =
{ ns with psymbols = generic_add ~check x ty ns.psymbols }
let add_symbol add x v uc =
let x = x.id_short in
{ uc with
uc_visible = add ~check:false x v v0 :: stv;
uc_import = add ~check:true x v i0 :: sti;
uc_export = add ~check:false x v e0 :: ste }
let add_ns add x v th = match th.th_stack with | _ ->
| (i, e) :: st -> assert false
let x = x.id_short in (add x v i, add x v e) :: st
| [] -> assert false
let add_known id th =
let _ = if Sid.mem id th.th_known
then error RedeclaredIdent else ()
in
{ th with th_known = Sid.add id th.th_known }
let add_local id th = let add_param id uc =
let th = add_known id th in let uc = add_known id uc in
{ th with th_local = Sid.add id th.th_local } { uc with uc_param = Sid.add id uc.uc_param }
let add_decl th d = let add_decl uc d =
let st = match d with let uc = match d with
| Dtype [ty, Ty_abstract] -> | Dtype [ty, Ty_abstract] ->
let th = add_local ty.ts_name th in let uc = add_param ty.ts_name uc in
add_ns add_tysymbol ty.ts_name ty th add_symbol add_tysymbol ty.ts_name ty uc
| Dlogic [Lfunction (fs, None)] -> | Dlogic [Lfunction (fs, None)] ->
let th = add_local fs.fs_name th in let uc = add_param fs.fs_name uc in
add_ns add_fsymbol fs.fs_name fs th add_symbol add_fsymbol fs.fs_name fs uc
| Dlogic [Lpredicate (ps, None)] -> | Dlogic [Lpredicate (ps, None)] ->
let th = add_local ps.ps_name th in let uc = add_param ps.ps_name uc in
add_ns add_psymbol ps.ps_name ps th add_symbol add_psymbol ps.ps_name ps uc
| _ -> | _ ->
in in
{ th with { uc with uc_decls = (Decl d) :: uc.uc_decls }
th_stack = st;
th_decls = (Decl d) :: th.th_decls }
(** Querying environments *) (** Querying environments *)
let get_namespace th = match th.th_stack with let get_namespace th = match th.uc_visible with
| (ns, _) :: _ -> ns | ns :: _ -> ns
| [] -> assert false | [] -> assert false
let find_tysymbol ns s = M.find s ns.tysymbols let find_tysymbol ns s = M.find s ns.tysymbols
...@@ -208,22 +261,6 @@ let mem_psymbol ns s = M.mem s ns.psymbols ...@@ -208,22 +261,6 @@ let mem_psymbol ns s = M.mem s ns.psymbols
let mem_namespace ns s = M.mem s ns.namespace let mem_namespace ns s = M.mem s ns.namespace
let mem_prop ns s = M.mem s ns.props let mem_prop ns s = M.mem s ns.props
let report fmt = function
| OpenTheory ->
fprintf fmt "cannot open a new theory in a non-empty context"
| CloseTheory ->
fprintf fmt "cannot close theory: there are still unclosed namespaces"
| NoOpenedTheory ->
fprintf fmt "no opened theory"
| NoOpenedNamespace ->
fprintf fmt "no opened namespace"
| RedeclaredIdent ->
fprintf fmt "cannot redeclare identifiers"
| CannotInstantiate ->
fprintf fmt "cannot instantiate a defined symbol"
(** Debugging *) (** Debugging *)
let print_ident = let print_ident =
...@@ -42,29 +42,29 @@ type decl = ...@@ -42,29 +42,29 @@ type decl =
and t = private { and theory = private {
and namespace and namespace
(** Building *) (** Building *)
type th type theory_uc
(** a theory under construction *) (** a theory under construction *)
val create_theory : ident -> th val create_theory : ident -> theory_uc
val open_namespace : th -> th val open_namespace : theory_uc -> theory_uc
val close_namespace : th -> ident -> import:bool -> th val close_namespace : theory_uc -> ident -> import:bool -> theory_uc
val use_export : th -> t -> th val use_export : theory_uc -> theory -> theory_uc
...@@ -72,15 +72,15 @@ type th_inst = { ...@@ -72,15 +72,15 @@ type th_inst = {
inst_ps : psymbol Mps.t; inst_ps : psymbol Mps.t;
val clone_export : th -> t -> th_inst -> th val clone_export : theory_uc -> theory -> th_inst -> theory_uc
val add_decl : th -> decl -> th val add_decl : theory_uc -> decl -> theory_uc
val close_theory : th -> t val close_theory : theory_uc -> theory
(** Querying *) (** Querying *)
val get_namespace : th -> namespace val get_namespace : theory_uc -> namespace
val find_tysymbol : namespace -> string -> tysymbol val find_tysymbol : namespace -> string -> tysymbol
val find_fsymbol : namespace -> string -> fsymbol val find_fsymbol : namespace -> string -> fsymbol
...@@ -94,16 +94,16 @@ val mem_psymbol : namespace -> string -> bool ...@@ -94,16 +94,16 @@ val mem_psymbol : namespace -> string -> bool
val mem_namespace: namespace -> string -> bool val mem_namespace: namespace -> string -> bool
val mem_prop : namespace -> string -> bool val mem_prop : namespace -> string -> bool
(** Error reporting *) (** Exceptions *)
type error exception CloseTheory
exception Error of error exception RedeclaredIdent of ident
val report : Format.formatter -> error -> unit exception ClashSymbol of string
val print_th : Format.formatter -> th -> unit val print_th : Format.formatter -> theory_uc -> unit
val print_t : Format.formatter -> t -> unit val print_t : Format.formatter -> theory -> unit
...@@ -22,11 +22,13 @@ open Format ...@@ -22,11 +22,13 @@ open Format
let files = ref [] let files = ref []
let parse_only = ref false let parse_only = ref false
let type_only = ref false let type_only = ref false
let debug = ref false
let () = let () =
Arg.parse Arg.parse
["--parse-only", Arg.Set parse_only, "stops after parsing"; ["--parse-only", Arg.Set parse_only, "stops after parsing";
"--type-only", Arg.Set type_only, "stops after type-checking"; "--type-only", Arg.Set type_only, "stops after type-checking";
"--debug", Arg.Set debug, "sets the debug flag";
(fun f -> files := f :: !files) (fun f -> files := f :: !files)
"usage: why [options] files..." "usage: why [options] files..."
...@@ -49,13 +51,13 @@ let type_file env file = ...@@ -49,13 +51,13 @@ let type_file env file =
Loc.set_file file lb; Loc.set_file file lb;
let f = Lexer.parse_logic_file lb in let f = Lexer.parse_logic_file lb in
close_in c; close_in c;
if !parse_only then env else List.fold_left Typing.add_theory env f if !parse_only then env else Typing.add_theories env f
let () = let () =
try try
let env = Typing.create ["lib"] in let env = Typing.create ["lib"; ""] in
ignore (List.fold_left type_file env !files) ignore (List.fold_left type_file env !files)
with e -> with e when not !debug ->
eprintf "%a@." report e; eprintf "%a@." report e;
exit 1 exit 1
