Commit 742f0819 authored by MARCHE Claude's avatar MARCHE Claude
improved histograms
parent c4e7e01d
...@@ -112,22 +112,26 @@ let specialize_ls ls = ...@@ -112,22 +112,26 @@ let specialize_ls ls =
let spec ty = if ty_closed ty then Duty ty else spec ty in let spec ty = if ty_closed ty then Duty ty else spec ty in
List.map spec ls.ls_args, Opt.map spec ls.ls_value List.map spec ls.ls_args, Opt.map spec ls.ls_value
(* dead code
let specialize_fs ls = let specialize_fs ls =
let dtyl, dty = specialize_ls ls in let dtyl, dty = specialize_ls ls in
match dty with match dty with
| Some dty -> dtyl, dty | Some dty -> dtyl, dty
| None -> raise (FunctionSymbolExpected ls) | None -> raise (FunctionSymbolExpected ls)
let specialize_cs ls = let specialize_cs ls =
if ls.ls_constr = 0 then raise (ConstructorExpected ls); if ls.ls_constr = 0 then raise (ConstructorExpected ls);
dtyl, Opt.get dty dtyl, Opt.get dty
(* dead code
let specialize_ps ls = let specialize_ps ls =
| Some _ -> raise (PredicateSymbolExpected ls) | Some _ -> raise (PredicateSymbolExpected ls)
| None -> dtyl | None -> dtyl
(** Patterns, terms, and formulas *) (** Patterns, terms, and formulas *)
...@@ -20,7 +20,9 @@ open Task ...@@ -20,7 +20,9 @@ open Task
(** TODO use this label in the following function *) (** TODO use this label in the following function *)
(* dead code
let label_induction = create_label "induction" let label_induction = create_label "induction"
let desc_labels = [label_induction, let desc_labels = [label_induction,
...@@ -144,13 +146,14 @@ let print_lex lexl = ...@@ -144,13 +146,14 @@ let print_lex lexl =
(************************* WITH LEXICOGRAPHIC ORDER **************************) (************************* WITH LEXICOGRAPHIC ORDER **************************)
(* dead code
let split_quantifiers x qvl = let split_quantifiers x qvl =
let rec aux left = function let rec aux left = function
| hd :: tl when vs_equal x hd -> List.rev left, tl | hd :: tl when vs_equal x hd -> List.rev left, tl
| hd :: tl -> aux (hd :: left) tl | hd :: tl -> aux (hd :: left) tl
| [] -> assert false | [] -> assert false
in aux [] qvl in aux [] qvl
(*INITIAL FORMULA SPLIT*) (*INITIAL FORMULA SPLIT*)
let decompose_forall t = let decompose_forall t =
...@@ -363,17 +366,20 @@ the induction hypothesis are the variables on the right of the rightmost ...@@ -363,17 +366,20 @@ the induction hypothesis are the variables on the right of the rightmost
induction variable.*) induction variable.*)
(* separate prenex universal quantification from the body of the formula*) (* separate prenex universal quantification from the body of the formula*)
(* dead code
let decompose_int_forall t = let decompose_int_forall t =
let rec aux qvl_acc t = match t.t_node with let rec aux qvl_acc t = match t.t_node with
| Tquant (Tforall, qt) -> | Tquant (Tforall, qt) ->
let qvl, _, t = t_open_quant qt in aux (qvl_acc @ qvl) t let qvl, _, t = t_open_quant qt in aux (qvl_acc @ qvl) t
| _ -> qvl_acc, t | _ -> qvl_acc, t
in aux [] t in aux [] t
(* find labeled variables (for induction variables), (* find labeled variables (for induction variables),
and the rest of the quantified variables after the last labeled variable and the rest of the quantified variables after the last labeled variable
(for the variables to generalize inside induction hypothesis). (for the variables to generalize inside induction hypothesis).
Ex: the result of Va.x1.b.x2.c.x3.d.P is [a.x1.b.x2.c.x3][x1.x2.x3][d]*) Ex: the result of Va.x1.b.x2.c.x3.d.P is [a.x1.b.x2.c.x3][x1.x2.x3][d]*)
(* dead code
let split_int_qlv_labeled qvl = let split_int_qlv_labeled qvl =
let rec aux left_acc ind_acc gen_acc = function let rec aux left_acc ind_acc gen_acc = function
| [] -> List.rev left_acc, List.rev ind_acc, gen_acc | [] -> List.rev left_acc, List.rev ind_acc, gen_acc
...@@ -384,6 +390,7 @@ let split_int_qlv_labeled qvl = ...@@ -384,6 +390,7 @@ let split_int_qlv_labeled qvl =
then aux (v :: (gen_acc @ left_acc)) (v :: ind_acc) [] tl then aux (v :: (gen_acc @ left_acc)) (v :: ind_acc) [] tl
else aux left_acc ind_acc (v :: gen_acc) tl else aux left_acc ind_acc (v :: gen_acc) tl
in aux [] [] [] qvl in aux [] [] [] qvl
input: ordered induction variables, rightmost neutral variables input: ordered induction variables, rightmost neutral variables
...@@ -397,6 +404,7 @@ then output: ...@@ -397,6 +404,7 @@ then output:
(d',e') ~ 'generalization variables', (d',e') ~ 'generalization variables',
(x1',x2',x3') ~ 'induction variables' (x1',x2',x3') ~ 'induction variables'
(0 <= x1'/\0 <= x2'/\(x1' < x1 \/ x1' = x1 /\ x2' < x2) ~ 'hyp. condition' *) (0 <= x1'/\0 <= x2'/\(x1' < x1 \/ x1' = x1 /\ x2' < x2) ~ 'hyp. condition' *)
(* dead code
let lex_order_ivl (le_int,lt_int) ivl rvl = let lex_order_ivl (le_int,lt_int) ivl rvl =
let gen_rvl, (hd,hd',tl,tl') = let gen_rvl, (hd,hd',tl,tl') =
let create_v v = Term.create_vsymbol (Ident.id_clone v.vs_name) ty_int in let create_v v = Term.create_vsymbol (Ident.id_clone v.vs_name) ty_int in
...@@ -423,10 +431,12 @@ let lex_order_ivl (le_int,lt_int) ivl rvl = ...@@ -423,10 +431,12 @@ let lex_order_ivl (le_int,lt_int) ivl rvl =
| _ -> assert false | _ -> assert false
in lex_ord (hd, hd', [],[]) lt_hd (tl, tl') in in lex_ord (hd, hd', [],[]) lt_hd (tl, tl') in
gen_rvl, (hd' :: tl'), t_and nonneg_ivl' lt_lex gen_rvl, (hd' :: tl'), t_and nonneg_ivl' lt_lex
(*returns the resulting formula with induction hypothesis. (*returns the resulting formula with induction hypothesis.
The formula however is still not closed (by the quantifiers before The formula however is still not closed (by the quantifiers before
the rightmost neutral quantifiers). *) the rightmost neutral quantifiers). *)
(* dead code
let int_strong_induction_lex (le_int,lt_int) ivl rvl t = let int_strong_induction_lex (le_int,lt_int) ivl rvl t =
let (gen_rvl, ind_ivl, hyp_cond) = let (gen_rvl, ind_ivl, hyp_cond) =
lex_order_ivl (le_int,lt_int) ivl rvl in lex_order_ivl (le_int,lt_int) ivl rvl in
...@@ -437,7 +447,9 @@ let int_strong_induction_lex (le_int,lt_int) ivl rvl t = ...@@ -437,7 +447,9 @@ let int_strong_induction_lex (le_int,lt_int) ivl rvl t =
let ind_hyp = let ind_hyp =
t_forall_close (ind_ivl @ gen_rvl) [] (t_implies hyp_cond hyp_goal) in t_forall_close (ind_ivl @ gen_rvl) [] (t_implies hyp_cond hyp_goal) in
let open_t = t_implies ind_hyp (t_forall_close rvl [] t) in open_t let open_t = t_implies ind_hyp (t_forall_close rvl [] t) in open_t
(* dead code
let induction_int_lex _km (le_int,lt_int) t0 = let induction_int_lex _km (le_int,lt_int) t0 =
let qvl, t = decompose_int_forall t0 in let qvl, t = decompose_int_forall t0 in
let lvl,ivl, genl = split_int_qlv_labeled qvl in let lvl,ivl, genl = split_int_qlv_labeled qvl in
...@@ -452,7 +464,9 @@ let induction_int_lex _km (le_int,lt_int) t0 = ...@@ -452,7 +464,9 @@ let induction_int_lex _km (le_int,lt_int) t0 =
Format.printf "New Task: %a \n@." Pretty.print_term t); Format.printf "New Task: %a \n@." Pretty.print_term t);
[t] [t]
end end
(* dead code
let induction_int_lex th_int = function let induction_int_lex th_int = function
| Some | Some
{ task_decl = { td_node = Decl { d_node = Dprop (Pgoal, pr, f) } }; { task_decl = { td_node = Decl { d_node = Dprop (Pgoal, pr, f) } };
...@@ -466,6 +480,7 @@ let induction_int_lex th_int = function ...@@ -466,6 +480,7 @@ let induction_int_lex th_int = function
(induction_int_lex km (le_int, lt_int) f) (induction_int_lex km (le_int, lt_int) f)
with Exit -> [t] end with Exit -> [t] end
let () = let () =
...@@ -374,34 +374,34 @@ let run_one stats r0 r1 fname = ...@@ -374,34 +374,34 @@ let run_one stats r0 r1 fname =
(**** print histograms ******) (**** print histograms ******)
let print_hist stats = let print_hist stats =
let main_ch = open_out "why3session.gnuplot" in let main_file,main_ch =
Filename.open_temp_file "why3session" ".gnuplot"
in
let main_fmt = formatter_of_out_channel main_ch in let main_fmt = formatter_of_out_channel main_ch in
fprintf main_fmt "set logscale y@\n"; fprintf main_fmt "set logscale@\n";
fprintf main_fmt "set key rmargin@\n"; fprintf main_fmt "set key rmargin@\n";
let (_:int) = let (_:int) =
Hprover.fold Hprover.fold
(fun p h acc -> (fun p h acc ->
let pf = (string_of_int acc) ^ ".plot" in let pf,ch = Filename.open_temp_file "why3session" ".data" in
if acc = 1 then if acc = 1 then
fprintf main_fmt "plot [0:%d] [0.01:%.2f] " fprintf main_fmt "plot [1:%d] [0.01:%.2f] "
(stats.nb_proved_sub_goals + stats.nb_proved_root_goals) (stats.nb_proved_sub_goals + stats.nb_proved_root_goals)
(stats.max_time) (stats.max_time)
else else
fprintf main_fmt "replot"; fprintf main_fmt "replot";
fprintf main_fmt " \"%s\" using 2:1 title \"%s\" with linespoints ps 0.2@\n" fprintf main_fmt
pf (string_of_prover p); pf (string_of_prover p);
let ch = open_out pf in
let fmt = formatter_of_out_channel ch in let fmt = formatter_of_out_channel ch in
(* let (_ : float * int) =
fprintf fmt "0.00 0@\n";
let (_ :int) =
Mfloat.fold Mfloat.fold
(fun t c acc -> (fun t c (acct,accc) ->
let acc = c + acc in let accc = c + accc in
fprintf fmt "%.2f %d@\n" t acc; let acct = t +. acct in
acc) fprintf fmt "%.2f %d@\n" acct accc;
h 0 (acct,accc))
h (0.0,0)
in in
fprintf fmt "@."; fprintf fmt "@.";
close_out ch; close_out ch;
...@@ -412,8 +412,14 @@ let print_hist stats = ...@@ -412,8 +412,14 @@ let print_hist stats =
fprintf main_fmt "set terminal pdfcairo@\n"; fprintf main_fmt "set terminal pdfcairo@\n";
fprintf main_fmt "set output \"why3session.pdf\"@\n"; fprintf main_fmt "set output \"why3session.pdf\"@\n";
fprintf main_fmt "replot@."; fprintf main_fmt "replot@.";
close_out main_ch close_out main_ch;
let cmd = "gnuplot " ^ main_file in
eprintf "Running command %s@." cmd;
let ret = Sys.command cmd in
if ret <> 0 then
eprintf "Command %s failed@." cmd
else
eprintf "See also results in file why3session.pdf@."
(****** run on all files ******) (****** run on all files ******)
