Commit 726da3e1 authored by Jean-Christophe Filliâtre's avatar Jean-Christophe Filliâtre
asymetric split in split_goal; syntax /\ and \/ for asymetric and and or
parent 637a374f
...@@ -79,9 +79,9 @@ back +-+-+-+-------------------+ ...@@ -79,9 +79,9 @@ back +-+-+-+-------------------+
forall a : sparse_array . invariant a -> forall a : sparse_array . invariant a ->
let (SA val idx back sz n) = a in let (SA val idx back sz n) = a in
n = sz -> n = sz ->
permutation sz back and permutation sz back /\
forall i : int. 0 <= i < sz -> forall i : int. 0 <= i < sz ->
idx#i = dirichlet sz back i and is_elt a i idx#i = dirichlet sz back i /\ is_elt a i
...@@ -189,6 +189,10 @@ rule token = parse ...@@ -189,6 +189,10 @@ rule token = parse
{ ARROW } { ARROW }
{ LRARROW } { LRARROW }
{ ASYM_AND }
{ ASYM_OR }
{ DOT } { DOT }
...@@ -67,7 +67,7 @@ ...@@ -67,7 +67,7 @@
/* symbols */ /* symbols */
%token ARROW %token ARROW ASYM_AND ASYM_OR
%token BAR %token BAR
%token COLON COMMA %token COLON COMMA
%token DOT EQUAL %token DOT EQUAL
...@@ -90,8 +90,8 @@ ...@@ -90,8 +90,8 @@
%nonassoc prec_named %nonassoc prec_named
%right ARROW LRARROW %right ARROW LRARROW
%right OR %right OR ASYM_OR
%right AND %right AND ASYM_AND
%nonassoc NOT %nonassoc NOT
%left EQUAL OP1 %left EQUAL OP1
%left OP2 %left OP2
...@@ -346,8 +346,12 @@ lexpr: ...@@ -346,8 +346,12 @@ lexpr:
{ infix_pp $1 PPiff $3 } { infix_pp $1 PPiff $3 }
| lexpr OR lexpr | lexpr OR lexpr
{ infix_pp $1 PPor $3 } { infix_pp $1 PPor $3 }
| lexpr ASYM_OR lexpr
{ mk_pp (PPnamed ("asym_split", infix_pp $1 PPor $3)) }
| lexpr AND lexpr | lexpr AND lexpr
{ infix_pp $1 PPand $3 } { infix_pp $1 PPand $3 }
| lexpr ASYM_AND lexpr
{ mk_pp (PPnamed ("asym_split", infix_pp $1 PPand $3)) }
| NOT lexpr | NOT lexpr
{ prefix_pp PPnot $2 } { prefix_pp PPnot $2 }
| lexpr EQUAL lexpr | lexpr EQUAL lexpr
...@@ -39,8 +39,9 @@ let debug = ref false ...@@ -39,8 +39,9 @@ let debug = ref false
TODO: use simp forms / tag with label "WP" *) TODO: use simp forms / tag with label "WP" *)
let wp_and ?(sym=false) f1 f2 = let wp_and ?(sym=false) f1 f2 =
(* TODO: tag instead? *) (* if sym then f_and_simp f1 f2 else f_and_simp f1 (f_implies_simp f1 f2) *)
if sym then f_and_simp f1 f2 else f_and_simp f1 (f_implies_simp f1 f2) let f = f_and_simp f1 f2 in
if sym then f else f_label [Split_goal.asym_split] f
let wp_ands ?(sym=false) fl = let wp_ands ?(sym=false) fl =
List.fold_left (wp_and ~sym) f_true fl List.fold_left (wp_and ~sym) f_true fl
...@@ -33,10 +33,14 @@ let split_case spl c acc tl bl = ...@@ -33,10 +33,14 @@ let split_case spl c acc tl bl =
in in
apply_append (f_case tl) acc bll apply_append (f_case tl) acc bll
let asym_split = "asym_split"
let rec split_pos acc f = match f.f_node with let rec split_pos acc f = match f.f_node with
| Ftrue -> acc | Ftrue -> acc
| Ffalse -> f::acc | Ffalse -> f::acc
| Fapp _ -> f::acc | Fapp _ -> f::acc
| Fbinop (Fand,f1,f2) when List.mem asym_split f.f_label ->
split_pos (split_pos acc (f_implies f1 f2)) f1
| Fbinop (Fand,f1,f2) -> | Fbinop (Fand,f1,f2) ->
split_pos (split_pos acc f2) f1 split_pos (split_pos acc f2) f1
| Fbinop (Fimplies,f1,f2) -> | Fbinop (Fimplies,f1,f2) ->
...@@ -64,10 +68,14 @@ and split_neg acc f = match f.f_node with ...@@ -64,10 +68,14 @@ and split_neg acc f = match f.f_node with
apply_append2 f_and acc (split_neg [] f1) (split_neg [] f2) apply_append2 f_and acc (split_neg [] f1) (split_neg [] f2)
| Fbinop (Fimplies,f1,f2) when List.mem asym_split f.f_label ->
split_neg (split_neg acc (f_and f1 f2)) (f_not f1)
split_neg (split_neg acc f2) (f_not f1) split_neg (split_neg acc f2) (f_not f1)
| Fbinop (Fiff,f1,f2) -> | Fbinop (Fiff,f1,f2) ->
split_neg (split_neg acc (f_and (f_not f1) (f_not f2))) (f_and f2 f1) split_neg (split_neg acc (f_and (f_not f1) (f_not f2))) (f_and f2 f1)
| Fbinop (For,f1,f2) when List.mem asym_split f.f_label ->
split_neg (split_neg acc (f_and (f_not f1) f2)) f1
| Fbinop (For,f1,f2) -> | Fbinop (For,f1,f2) ->
split_neg (split_neg acc f2) f1 split_neg (split_neg acc f2) f1
| Fnot f -> | Fnot f ->
...@@ -17,6 +17,8 @@ ...@@ -17,6 +17,8 @@
val asym_split : Term.label
val split_pos : Term.fmla list -> Term.fmla -> Term.fmla list val split_pos : Term.fmla list -> Term.fmla -> Term.fmla list
val split_neg : Term.fmla list -> Term.fmla -> Term.fmla list val split_neg : Term.fmla list -> Term.fmla -> Term.fmla list
(* test file *) (* test file *)
theory Test theory S
use export int.Int use import int.Int
logic f(int) : int logic p int
logic q(int, int) goal G : forall x:int. (p 1 \/ p 2) -> p 3
axiom A : forall x:int. q (-x) (f x)
goal G : 3.14 = 3.15
theory Test2
use export list.List
goal G : let x = Nil in let t = (Cons 1 x, Cons 3.14 x) in t=t
end end
Supports Markdown
