Mise à jour terminée. Pour connaître les apports de la version 13.8.4 par rapport à notre ancienne version vous pouvez lire les "Release Notes" suivantes :
https://about.gitlab.com/releases/2021/02/11/security-release-gitlab-13-8-4-released/
https://about.gitlab.com/releases/2021/02/05/gitlab-13-8-3-released/
Commit 701d8966 authored by Martin Clochard's avatar Martin Clochard
Example: new proof for mccarthy function computation
parent 201623c0
......@@ -5,30 +5,29 @@ module McCarthy91
use import int.Int
function spec (x: int) : int = if x <= 100 then 91 else x-10
(* traditional recursive implementation *)
let rec f91 (n:int) : int variant { 101-n }
ensures { result = if n <= 100 then 91 else n - 10 }
ensures { result = spec n }
= if n <= 100 then
f91 (f91 (n + 11))
else
n - 10
(* non-recursive implementation using a while loop *)
use import ref.Ref
function f (x: int) : int = if x <= 100 then 91 else x-10
(* iter k x = f^k(x) *)
clone import int.Iter with type t = int, function f = f
clone import int.Iter with type t = int, function f = spec
let f91_nonrec (n0: int) ensures { result = f n0 }
let f91_nonrec (n0: int) ensures { result = spec n0 }
= let e = ref 1 in
let n = ref n0 in
while !e > 0 do
invariant { !e >= 0 /\ iter !e !n = f n0 }
invariant { !e >= 0 /\ iter !e !n = spec n0 }
variant { 101 - !n + 10 * !e, !e }
if !n > 100 then begin
n := !n - 10;
......@@ -40,4 +39,40 @@ module McCarthy91
done;
!n
(* Use a 'morally' irrelevant control flow from a recursive function
to ease proof (the recursive structure does not contribute to the
program execution). This is a technique for proving derecursified
programs. See verifythis_2016_tree_traversal for a more
complex example. *)
exception Stop
let f91_pseudorec (n0:int) : int
= let e = ref 1 in
let n = ref n0 in
let bloc () : unit
requires { !e >= 0 }
ensures { !(old e) > 0 }
ensures { if !(old n) > 100 then !n = !(old n) - 10 /\ !e = !(old e) - 1
else !n = !(old n) + 11 /\ !e = !(old e) + 1 }
raises { Stop -> !e = !(old e) = 0 /\ !n = !(old n) }
= if not (!e > 0) then raise Stop;
n := !n - 10;
e := !e - 1
end else begin
n := !n + 11;
e := !e + 1
in
let rec aux () : unit
requires { !e > 0 }
variant { 101 - !n }
ensures { !e = !(old e) - 1 /\ !n = spec !(old n) }
raises { Stop -> false }
= let u = !n in bloc (); if u <= 100 then (aux (); aux ()) in
try aux (); bloc (); absurd
with Stop -> !n end
......@@ -2,57 +2,17 @@
<!DOCTYPE why3session PUBLIC "-//Why3//proof session v5//EN"
"http://why3.lri.fr/why3session.dtd">
<why3session shape_version="4">
<prover id="0" name="CVC3" version="2.4.1" timelimit="10" memlimit="0"/>
<prover id="2" name="Z3" version="3.2" timelimit="10" memlimit="0"/>
<prover id="3" name="veriT" version="201310" timelimit="5" memlimit="4000"/>
<prover id="4" name="Alt-Ergo" version="0.99.1" timelimit="10" memlimit="0"/>
<prover id="0" name="Alt-Ergo" version="1.01" timelimit="5" steplimit="0" memlimit="1000"/>
<file name="../mccarthy.mlw" expanded="true">
<theory name="McCarthy91" sum="fc4723c0574acd30d3d960beb8743bed" expanded="true">
<goal name="WP_parameter f91" expl="VC for f91" expanded="true">
<proof prover="0" timelimit="2"><result status="valid" time="0.00"/></proof>
<proof prover="2" timelimit="2"><result status="valid" time="0.02"/></proof>
<proof prover="3"><result status="valid" time="0.00"/></proof>
<proof prover="4" timelimit="2"><result status="valid" time="0.02" steps="11"/></proof>
<theory name="McCarthy91" sum="4a73db0e7cb62d49c98fa874799f159d" expanded="true">
<goal name="WP_parameter f91" expl="VC for f91">
<proof prover="0"><result status="valid" time="0.00" steps="15"/></proof>
</goal>
<goal name="WP_parameter f91_nonrec" expl="VC for f91_nonrec" expanded="true">
<transf name="split_goal_wp" expanded="true">
<goal name="WP_parameter f91_nonrec.1" expl="1. loop invariant init" expanded="true">
<proof prover="0"><result status="valid" time="0.00"/></proof>
<proof prover="2"><result status="valid" time="0.00"/></proof>
<proof prover="4"><result status="valid" time="0.01" steps="1"/></proof>
</goal>
<goal name="WP_parameter f91_nonrec.2" expl="2. loop invariant preservation" expanded="true">
<proof prover="0"><result status="valid" time="0.02"/></proof>
<proof prover="2"><result status="valid" time="0.02"/></proof>
<proof prover="4"><result status="valid" time="0.00" steps="22"/></proof>
</goal>
<goal name="WP_parameter f91_nonrec.3" expl="3. loop variant decrease" expanded="true">
<proof prover="2"><result status="valid" time="0.01"/></proof>
<proof prover="4"><result status="valid" time="0.01" steps="6"/></proof>
</goal>
<goal name="WP_parameter f91_nonrec.4" expl="4. loop invariant preservation" expanded="true">
<proof prover="0"><result status="valid" time="0.03"/></proof>
<proof prover="4"><result status="valid" time="0.24" steps="87"/></proof>
</goal>
<goal name="WP_parameter f91_nonrec.5" expl="5. loop variant decrease" expanded="true">
<proof prover="2"><result status="valid" time="0.03"/></proof>
</goal>
<goal name="WP_parameter f91_nonrec.6" expl="6. postcondition" expanded="true">
<proof prover="4"><result status="valid" time="0.02" steps="5"/></proof>
</goal>
</transf>
<goal name="WP_parameter f91_nonrec" expl="VC for f91_nonrec">
<proof prover="0"><result status="valid" time="0.11" steps="171"/></proof>
</goal>
<goal name="WP_parameter f91_pseudorec" expl="VC for f91_pseudorec">
<proof prover="0"><result status="valid" time="0.02" steps="44"/></proof>
</goal>
</theory>
</file>
