Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit 6fe4bfe8 authored by Andrei Paskevich's avatar Andrei Paskevich
encode_simple to use in tptp (just for safety) and smtlib
parent 696a5d55
...@@ -112,7 +112,7 @@ LIB_TRANSFORM = simplify_recursive_definition simplify_formula inlining \ ...@@ -112,7 +112,7 @@ LIB_TRANSFORM = simplify_recursive_definition simplify_formula inlining \
eliminate_definition eliminate_algebraic \ eliminate_definition eliminate_algebraic \
encoding_enumeration \ encoding_enumeration \
eliminate_inductive eliminate_let eliminate_if \ eliminate_inductive eliminate_let eliminate_if \
explicit_polymorphism simple_types encoding_instantiate \ explicit_polymorphism encoding_simple encoding_instantiate \
simplify_array filter_trigger split_goal simplify_array filter_trigger split_goal
LIB_PRINTER = print_real alt_ergo why3 smt coq tptp simplify gappa LIB_PRINTER = print_real alt_ergo why3 smt coq tptp simplify gappa
(* Why driver for SMT syntax *)
prelude ";;; this is a prelude for CVC3 "
printer "smtv1"
filename "%f-%t-%g.smt"
valid "unsat"
unknown "\\bunknown\\b\\|\\bsat\\b" "Unknown"
(* À discuter *)
transformation "simplify_recursive_definition"
transformation "inline_trivial"
transformation "eliminate_builtin"
transformation "eliminate_definition"
transformation "eliminate_inductive"
transformation "eliminate_algebraic"
transformation "simplify_formula"
transformation "simplify_trivial_quantification"
transformation "encoding_enumeration"
transformation "explicit_polymorphism"
transformation "encoding_simple_kept"
theory BuiltIn
syntax type int "Int"
syntax type real "Real"
syntax logic (=) "(= %1 %2)"
syntax logic (<>) "(not (= %1 %2))"
theory int.Int
prelude ";;; this is a prelude for CVC3, Arithmetic"
syntax logic zero "0"
syntax logic (+) "(+ %1 %2)"
syntax logic (-) "(- %1 %2)"
syntax logic (*) "(* %1 %2)"
syntax logic (-_) "(- %1)"
syntax logic (<=) "(<= %1 %2)"
syntax logic (<) "(< %1 %2)"
syntax logic (>=) "(>= %1 %2)"
syntax logic (>) "(> %1 %2)"
remove prop CommutativeGroup.Comm.Comm
remove prop CommutativeGroup.Assoc.Assoc
remove prop CommutativeGroup.Unit_def
remove prop CommutativeGroup.Inv_def
remove prop Assoc.Assoc
remove prop Mul_distr
remove prop Comm.Comm
remove prop Unitary
remove prop Refl
remove prop Trans
remove prop Antisymm
remove prop Total
theory real.Real
prelude ";;; this is a prelude for Z3, Arithmetic"
syntax logic (/) "(/ %1 %2)"
syntax logic inv "(/ 1.0 %1)"
remove prop Inverse
remove prop Unitary
remove prop Refl
remove prop Trans
remove prop Total
(* L'encodage des types sommes bloquent cette théorie builtin *)
theory bool.Bool
syntax type bool "bool"
syntax logic True "true"
syntax logic False "false"
syntax logic andb "(and %1 %2)"
syntax logic orb "(or %1 %2)"
syntax logic xorb "(xor %1 %2)"
syntax logic notb "(not %1)"
meta cloned "encoding_decorate : kept" type bool
Local Variables:
mode: why
compile-command: "make -C ../.. bench"
End:
...@@ -29,12 +29,7 @@ transformation "eliminate_let" ...@@ -29,12 +29,7 @@ transformation "eliminate_let"
(* Add the projections for enumeration types*) (* Add the projections for enumeration types*)
transformation "encoding_enumeration" transformation "encoding_enumeration"
transformation "explicit_polymorphism" transformation "explicit_polymorphism"
(*transformation "encoding_decorate"*)
transformation "simple_types"
theory BuiltIn theory BuiltIn
syntax type int "Int" syntax type int "Int"
(* Why driver for tptp first-order logic solvers *)
prelude "% this is a why prelude for tptp solvers
fof(two_constants, axiom, ~ ('0' = '1')).
printer "tptp"
filename "%f-%t-%g.p"
valid "Proof found"
invalid "Completion found"
fail "Failure" "Failure"
unknown "No Proof Found" "Unknown"
timeout "Resource limit exceeded"
timeout "Ran out of time"
(* to be improved *)
transformation "eliminate_if"
transformation "encoding_simple"
theory BuiltIn
syntax logic (=) "(%1 = %2)"
syntax logic (<>) "(%1 != %2)"
Local Variables:
mode: why
compile-command: "unset LANG; make -C .. bench"
End:
(* vim:syntax=ocaml
prelude ";;; this is a prelude for Z3"
printer "smtv1"
valid "^unsat"
unknown "^\\(unknown\\|sat\\|Fail\\)" "Unknown"
(* À discuter *)
theory BuiltIn
theory int.Int
remove prop Unitary
remove prop Refl
remove prop Trans
remove prop Total
theory real.Real
remove prop Inverse
remove prop Unitary
remove prop Refl
remove prop Trans
remove prop Total
theory bool.Bool
theory int.EuclideanDivision
syntax logic div "(div %1 %2)"
syntax logic mod "(mod %1 %2)"
remove prop Mod_bound
remove prop Div_mod
remove prop Mod_1
remove prop Div_1
Local Variables:
mode: why
End:
...@@ -225,8 +225,8 @@ let add_type (state, task) ts csl = ...@@ -225,8 +225,8 @@ let add_type (state, task) ts csl =
let comp t (state,task) = match t.task_decl.td_node with let comp t (state,task) = match t.task_decl.td_node with
| Decl { d_node = Dtype dl } -> | Decl { d_node = Dtype dl } ->
(* add abstract type declarations *) (* add abstract type declarations *)
let tydl = List.rev_map (fun (ts,_) -> (ts,Tabstract)) dl in let tydl = List.map (fun (ts,_) -> [ts,Tabstract]) dl in
let task = add_decl task (create_ty_decl tydl) in let task = List.fold_left add_ty_decl task tydl in
(* add needed functions and axioms *) (* add needed functions and axioms *)
let add acc (ts,df) = match df with let add acc (ts,df) = match df with
| Tabstract -> acc | Tabstract -> acc
(* Copyright (C) 2010- *)
(* Francois Bobot *)
(* Jean-Christophe Filliatre *)
(* Johannes Kanig *)
(* Andrei Paskevich *)
(* This software is free software; you can redistribute it and/or *)
(* modify it under the terms of the GNU Library General Public *)
(* License version 2.1, with the special exception on linking *)
(* described in file LICENSE. *)
(* This software is distributed in the hope that it will be useful, *)
(* but WITHOUT ANY WARRANTY; without even the implied warranty of *)
(* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. *)
open Util
open Ident
open Ty
open Term
open Decl
open Theory
open Task
let meta_kept = register_meta "encoding_decorate : kept" [MTtysymbol]
(* From Encoding Polymorphism CADE07*)
type lconv = { u2t : lsymbol ; t2u : lsymbol }
type tenv = {
kept : Sts.t option;
declare_kept : tysymbol -> decl list;
specials : lconv Hty.t;
ty_uni : ty;
trans_lsymbol : lsymbol Hls.t
let init_tenv kept =
let ts_uni = create_tysymbol (id_fresh "uni") [] None in
let task = use_export None builtin_theory in
let task = add_ty_decl task [ts_uni, Tabstract] in
let ty_uni = ty_app ts_uni [] in
let specials = Hty.create 17 in
let declare_kept ts =
let ty = ty_app ts [] in
let name = ts.ts_name.id_string in
let u2t = create_fsymbol (id_fresh ("uni2" ^ name)) [ty_uni] ty in
let t2u = create_fsymbol (id_fresh (name ^ "2uni")) [ty] ty_uni in
let pr_u = create_prsymbol (id_fresh ("uni2" ^ name ^ "2uni")) in
let pr_t = create_prsymbol (id_fresh (name ^ "2uni2" ^ name)) in
let vu = create_vsymbol (id_fresh "vu") ty_uni in
let vt = create_vsymbol (id_fresh "vt") ty in
let tu = t_var vu in
let tt = t_var vt in
let u2t2u = t_app t2u [t_app u2t [tu] ty] ty_uni in
let t2u2t = t_app u2t [t_app t2u [tt] ty_uni] ty in
let u2t2u = f_forall [vu] [] (f_equ u2t2u tu) in
let t2u2t = f_forall [vt] [] (f_equ t2u2t tt) in
Hty.add specials ty { u2t = u2t ; t2u = t2u };
[ create_ty_decl [ts, Tabstract];
create_logic_decl [u2t, None];
create_logic_decl [t2u, None];
create_prop_decl Paxiom pr_u u2t2u;
create_prop_decl Paxiom pr_t t2u2t ]
in
task,
{ kept = option_map (Sts.add Explicit_polymorphism.ts_ty) kept;
declare_kept = Wts.memoize 7 declare_kept;
specials = specials;
ty_uni = ty_uni;
trans_lsymbol = Hls.create 17 }
let is_kept tenv ts =
ts_equal ts ts_int || ts_equal ts ts_real ||
ts.ts_args = [] && match tenv.kept with
| Some s -> Sts.mem ts s
| None -> true
(* Convert type *)
let conv_ty tenv ty =
if Hty.mem tenv.specials ty then ty else tenv.ty_uni
(* Convert a variable *)
let conv_vs tenv vs =
let ty = conv_ty tenv vs.vs_ty in
if ty_equal ty vs.vs_ty then vs else
create_vsymbol (id_dup vs.vs_name) ty
(* Convert a logic symbol to the encoded one *)
let conv_ls tenv ls =
if ls_equal ls ps_equ || ls_equal ls ps_neq then ls
else try Hls.find tenv.trans_lsymbol ls with Not_found ->
let ty_res = Util.option_map (conv_ty tenv) ls.ls_value in
let ty_arg = List.map (conv_ty tenv) ls.ls_args in
let ls' =
if Util.option_eq ty_equal ty_res ls.ls_value &&
List.for_all2 ty_equal ty_arg ls.ls_args then ls
else create_lsymbol (id_clone ls.ls_name) ty_arg ty_res
in
Hls.add tenv.trans_lsymbol ls ls';
ls'
(* Convert the argument of a function *)
let conv_arg tenv ty_arg t =
let ty_val = t.t_ty in
if ty_equal ty_arg ty_val then t else
if ty_equal ty_arg tenv.ty_uni then
let lc = Hty.find tenv.specials ty_val in
t_app lc.t2u [t] ty_arg
else if ty_equal ty_val tenv.ty_uni then
let lc = Hty.find tenv.specials ty_arg in
t_app lc.u2t [t] ty_arg
else assert false
let rec rewrite_term tenv vm t =
let fnT = rewrite_term tenv in
let fnF = rewrite_fmla tenv in
match t.t_node with
| Tconst _ -> t
| Tvar x ->
Mvs.find x vm
| Tapp (fs,tl) ->
let fs = conv_ls tenv fs in
let fn ty t = conv_arg tenv ty (fnT vm t) in
let tl = List.map2 fn fs.ls_args tl in
t_app fs tl (conv_ty tenv t.t_ty)
| Tif (f, t1, t2) ->
t_if (fnF vm f) (fnT vm t1) (fnT vm t2)
| Tlet (t1, b) ->
let u,t2 = t_open_bound b in
let u' = conv_vs tenv u in
let t1' = fnT vm t1 in
let t2' = fnT (Mvs.add u (t_var u') vm) t2 in
if vs_equal u u' && t_equal t1 t1' && t_equal t2 t2'
then t else t_let u' t1' t2'
| Tcase _ | Teps _ | Tbvar _ ->
Printer.unsupportedTerm t "unsupported term"
and rewrite_fmla tenv vm f =
match f.f_node with
| Fapp (ps,tl) when ls_equal ps ps_equ || ls_equal ps ps_neq ->
f_app ps (List.map (fnT vm) tl)
| Fapp (ps,tl) ->
let ps = conv_ls tenv ps in
let tl = List.map2 fn ps.ls_args tl in
f_app ps tl
| Fquant (q,b) ->
let vl, tl, f1 = f_open_quant b in
let add m v = let v' = conv_vs tenv v in Mvs.add v (t_var v') m, v' in
let vm', vl' = Util.map_fold_left add vm vl in
let tl' = tr_map (fnT vm') (fnF vm') tl in
let f1' = fnF vm' f1 in
if List.for_all2 vs_equal vl vl' && trl_equal tl tl' && f_equal f1 f1'
then f else f_quant q vl' tl' f1'
| Flet (t1, b) ->
let u,f1 = f_open_bound b in
let f1' = fnF (Mvs.add u (t_var u') vm) f1 in
if vs_equal u u' && t_equal t1 t1' && f_equal f1 f1'
then f else f_let u' t1' f1'
| Fcase _ ->
Printer.unsupportedFmla f "unsupported formula"
| _ -> f_map (fnT vm) (fnF vm) f
let decl tenv d =
match d.d_node with
| Dtype dl ->
let add acc = function
| ts, Tabstract when not (is_kept tenv ts) -> acc
| ts, Tabstract -> List.rev_append (tenv.declare_kept ts) acc
| _ -> Printer.unsupportedDecl d "use eliminate_algebraic"
in
List.rev (List.fold_left add [] dl)
| Dlogic ll ->
let conv = function
| ls, None -> create_logic_decl [conv_ls tenv ls, None]
| _ -> Printer.unsupportedDecl d "use eliminate_definition"
in
List.map conv ll
| Dind _ ->
Printer.unsupportedDecl d "use eliminate_inductive"
| Dprop _ ->
[decl_map (fnT Mvs.empty) (fnF Mvs.empty) d]
let t = Trans.on_meta meta_kept (fun tds ->
let s = Task.find_tagged_ts meta_kept tds Sts.empty in
let task, tenv = init_tenv (Some s) in
Trans.decl (decl tenv) task)
let () = Trans.register_transform "encoding_simple_kept" t
let t_all =
let task, tenv = init_tenv None in
let () = Trans.register_transform "encoding_simple_all" t_all
let t_none =
let task, tenv = init_tenv (Some Sts.empty) in
let () = Trans.register_transform "encoding_simple" t_none
...@@ -17,25 +17,5 @@ ...@@ -17,25 +17,5 @@
(**s transformation from a typed logic to a logic with only one universal val meta_kept : string
type, builtin types, and symbols used to convert explicitely values from
the universal type to builtin ones (and the other way) *)
(* TODO : learn english... *)
open Util
open Ident
open Ty
open Term
open Decl
open Task
let simple_types = Trans.identity
let _ = Trans.register_transform "simple_types" simple_types
Local Variables:
compile-command: "unset LANG; make -C ../.. -k"
End:
...@@ -158,6 +158,8 @@ module Utils = struct ...@@ -158,6 +158,8 @@ module Utils = struct
end end
let ts_ty = Utils.t
(* from now on, we shall use those functions without module qualification *) (* from now on, we shall use those functions without module qualification *)
open Utils open Utils
...@@ -17,6 +17,10 @@ ...@@ -17,6 +17,10 @@
(** type of types *)
val ts_ty : Ty.tysymbol
(** transformation from polymorphic logic to untyped logic. The polymorphic (** transformation from polymorphic logic to untyped logic. The polymorphic
logic must not have finite support types. *) logic must not have finite support types. *)
