support for Princess (in progress)
parent 31a17623
(* Why3 driver for princess
see http://www.philipp.ruemmer.org/princess.shtml *)
printer "tptp-tff"
filename "%f-%t-%g.p"
valid "Proof found"
invalid "Completion found"
valid "^No countermodel exists, formula is valid"
invalid "^Formula is invalid, found a countermodel:"
valid "^% SZS status Theorem"
valid "^% SZS status Unsatisfiable"
unknown "^% SZS status CounterSatisfiable" ""
unknown "^% SZS status Satisfiable" ""
timeout "^% SZS status Timeout"
unknown "^% SZS status GaveUp" ""
fail "^% SZS status Error" ""
timeout "Ran out of time"
timeout "CPU time limit exceeded"
outofmemory "Out of Memory"
unknown "No Proof Found" ""
fail "Failure.*" "\"\\0\""
time "why3cpulimit time : %s s"
(* transformations *)
transformation "inline_trivial"
transformation "eliminate_builtin"
transformation "eliminate_definition"
transformation "eliminate_inductive"
transformation "eliminate_algebraic"
(* currently, princess does not support $let and $ite *)
transformation "eliminate_let"
transformation "eliminate_if"
transformation "encoding_smt"
transformation "encoding_sort"
theory BuiltIn
syntax predicate (=) "(%1 = %2)"
syntax type int "$int"
syntax type real "$real"
meta "encoding : kept" type int
meta "encoding : kept" type real
meta "eliminate_algebraic" "no_index"
meta "select_inst" "all"
meta "select_lskept" "all"
meta "select_lsinst" "all"
meta "select_kept" "all"
theory int.Int
syntax function zero "0"
syntax function one "1"
syntax function (+) "$sum(%1,%2)"
syntax function (-) "$difference(%1,%2)"
syntax function (*) "$product(%1,%2)"
syntax function (-_) "$uminus(%1)"
syntax predicate (<=) "$lesseq(%1,%2)"
syntax predicate (<) "$less(%1,%2)"
syntax predicate (>=) "$greatereq(%1,%2)"
syntax predicate (>) "$greater(%1,%2)"
remove prop CommutativeGroup.Comm.Comm
remove prop CommutativeGroup.Assoc
remove prop CommutativeGroup.Unit_def_l
remove prop CommutativeGroup.Unit_def_r
remove prop CommutativeGroup.Inv_def_l
remove prop CommutativeGroup.Inv_def_r
remove prop Assoc.Assoc
remove prop Mul_distr_l
remove prop Mul_distr_r
remove prop Comm.Comm
remove prop Unitary
remove prop Refl
remove prop Trans
remove prop Antisymm
remove prop Total
remove prop NonTrivialRing
remove prop CompatOrderAdd
remove prop ZeroLessOne
theory real.Real
syntax function zero "0.0"
syntax function one "1.0"
syntax function (/) "$quotient(%1,%2)"
syntax function inv "$quotient(1.0,%1)"
remove prop Unitary
remove prop Inverse
remove prop Refl
remove prop Trans
remove prop Total
theory int.EuclideanDivision
syntax function div "$quotient_e(%1,%2)"
syntax function mod "$remainder_e(%1,%2)"
remove prop Div_mod
remove prop Div_bound
remove prop Mod_bound
remove prop Mod_1
remove prop Div_1
remove prop Div_inf
remove prop Div_inf_neg
remove prop Mod_0
remove prop Div_1_left
remove prop Div_minus1_left
remove prop Mod_1_left
remove prop Mod_minus1_left
theory tptp.Univ
syntax type iType "$i"
meta "encoding : kept" type iType
theory tptp.IntTrunc
syntax function floor "$floor(%1)"
syntax function ceil "$ceil(%1)"
syntax function truncate "$truncate(%1)"
syntax function round "$round(%1)"
syntax function to_int "$to_int(%1)"
syntax predicate is_int "$is_int(%1)"
syntax predicate is_rat "$is_rat(%1)"
theory tptp.IntDivT
syntax function div_t "$quotient_t(%1,%2)"
syntax function mod_t "$remainder_t(%1,%2)"
theory tptp.IntDivF
syntax function div_f "$quotient_f(%1,%2)"
syntax function mod_f "$remainder_f(%1,%2)"
theory tptp.Rat
syntax type rat "$rat"
syntax function zero "0/1"
syntax function one "1/1"
syntax function to_rat "$to_rat(%1)"
remove prop Unitary
remove prop Refl
remove prop Trans
remove prop Total
meta "encoding : kept" type rat
theory tptp.RatTrunc
theory tptp.RatDivE
theory tptp.RatDivT
theory tptp.RatDivF
theory tptp.Real
syntax function to_real "$to_real(%1)"
theory real.Truncate
theory tptp.RealTrunc
theory tptp.RealDivE
theory tptp.RealDivT
theory tptp.RealDivF
theory tptp.IntToRat
theory tptp.IntToReal
theory tptp.RealToRat
theory tptp.RatToReal
...@@ -228,6 +228,15 @@ command = "'@LOCALBIN@why3-cpulimit' %T %m -s %e -t %t" ...@@ -228,6 +228,15 @@ command = "'@LOCALBIN@why3-cpulimit' %T %m -s %e -t %t"
driver = "drivers/vampire.drv" driver = "drivers/vampire.drv"
version_ok = "0.6" version_ok = "0.6"
[ATP princess]
name = "Princess"
exec = "princess"
# version_switch = "-h"
version_regexp = "(release \\([0-9-]+\\))"
command = "'@LOCALBIN@why3-cpulimit' %t 0 -s %e %f"
driver = "drivers/princess.drv"
version_ok = "2013-04-21"
[ATP verit] [ATP verit]
name = "veriT" name = "veriT"
exec = "veriT" exec = "veriT"
