Attention une mise à jour du service Gitlab va être effectuée le mardi 14 décembre entre 13h30 et 14h00. Cette mise à jour va générer une interruption du service dont nous ne maîtrisons pas complètement la durée mais qui ne devrait pas excéder quelques minutes.
Commit 6e3ce28d authored by Andrei Paskevich's avatar Andrei Paskevich
fix the coq execution time in two broken sessions
parent 6b98a07c
...@@ -213,7 +213,7 @@ ...@@ -213,7 +213,7 @@
<proof prover="8"><result status="valid" time="0.88"/></proof> <proof prover="8"><result status="valid" time="0.88"/></proof>
</goal> </goal>
<goal name="lemma2"> <goal name="lemma2">
<proof prover="3" edited="double_of_int_DoubleOfInt_lemma2_1.v"><result status="valid" time="1.74"/></proof> <proof prover="3" edited="double_of_int_DoubleOfInt_lemma2_1.v"><result status="valid" time="17.64"/></proof>
</goal> </goal>
<goal name="nth_var4"> <goal name="nth_var4">
<proof prover="1"><result status="valid" time="1.11" steps="148"/></proof> <proof prover="1"><result status="valid" time="1.11" steps="148"/></proof>
...@@ -439,7 +439,7 @@ ...@@ -439,7 +439,7 @@
<goal name="sub_valid_coloring.3.1.1.1" expl="1."> <goal name="sub_valid_coloring.3.1.1.1" expl="1.">
<transf name="split_goal_wp"> <transf name="split_goal_wp">
<goal name="sub_valid_coloring.3.1.1.1.1" expl="1."> <goal name="sub_valid_coloring.3.1.1.1.1" expl="1.">
<proof prover="9" edited="koda_ruskey_KodaRuskey_Spec_sub_valid_coloring_1.v"><result status="valid" time="1.55"/></proof> <proof prover="9" edited="koda_ruskey_KodaRuskey_Spec_sub_valid_coloring_1.v"><result status="valid" time="4.89"/></proof>
</goal> </goal>
<goal name="sub_valid_coloring.3.1.1.1.2" expl="2."> <goal name="sub_valid_coloring.3.1.1.1.2" expl="2.">
<proof prover="0" timelimit="6"><result status="valid" time="0.04"/></proof> <proof prover="0" timelimit="6"><result status="valid" time="0.04"/></proof>
...@@ -504,7 +504,7 @@ ...@@ -504,7 +504,7 @@
<proof prover="1" timelimit="11"><result status="valid" time="0.01" steps="12"/></proof> <proof prover="1" timelimit="11"><result status="valid" time="0.01" steps="12"/></proof>
</goal> </goal>
<goal name="WP_parameter sub_valid_coloring_white.10" expl="10. postcondition"> <goal name="WP_parameter sub_valid_coloring_white.10" expl="10. postcondition">
<proof prover="9" edited="koda_ruskey_KodaRuskey_Spec_WP_parameter_sub_valid_coloring_white_1.v"><result status="valid" time="3.47"/></proof> <proof prover="9" edited="koda_ruskey_KodaRuskey_Spec_WP_parameter_sub_valid_coloring_white_1.v"><result status="valid" time="3.81"/></proof>
</goal> </goal>
</transf> </transf>
</goal> </goal>
