Commit 6d269278 authored by Andrei Paskevich's avatar Andrei Paskevich
whyml: polymorphic recursion (EXPERIMENTAL)
parent 8ad5eebf
...@@ -40,9 +40,6 @@ and rvar = ...@@ -40,9 +40,6 @@ and rvar =
let create_user_type_variable x op = let create_user_type_variable x op =
Duvar (Typing.create_user_tv x.id, op) Duvar (Typing.create_user_tv x.id, op)
let create_type_variable () =
Dvar (ref (Dtvs (create_tvsymbol (id_fresh "a"))))
let create_dreg dity = let create_dreg dity =
Rvar (ref (Rtvs (create_tvsymbol (id_fresh "rho"), dity))) Rvar (ref (Rtvs (create_tvsymbol (id_fresh "rho"), dity)))
...@@ -88,13 +85,6 @@ let ts_app s dl = ...@@ -88,13 +85,6 @@ let ts_app s dl =
| None -> | None ->
ts_app_real s dl ts_app_real s dl
let rec dity_refresh = function
| Dvar { contents = Dtvs _ } as dity -> dity
| Dvar { contents = Dval dty } -> dity_refresh dty
| Duvar _ as dity -> dity
| Dits (its,dl,_) -> its_app its (List.map dity_refresh dl)
| Dts (ts,dl) -> ts_app_real ts (List.map dity_refresh dl)
let rec opaque_tvs acc = function let rec opaque_tvs acc = function
| Dvar { contents = Dtvs _ } -> acc | Dvar { contents = Dtvs _ } -> acc
| Dvar { contents = Dval dty } -> opaque_tvs acc dty | Dvar { contents = Dval dty } -> opaque_tvs acc dty
...@@ -104,29 +94,27 @@ let rec opaque_tvs acc = function ...@@ -104,29 +94,27 @@ let rec opaque_tvs acc = function
(* create ity *) (* create ity *)
let ity_of_dity dity = let rec ity_of_dity = function
let rec get_ity = function | Dvar { contents = Dtvs _ } ->
| Dvar { contents = Dtvs _ } -> Loc.errorm "undefined type variable"
Loc.errorm "undefined type variable" | Dvar { contents = Dval dty } ->
| Dvar { contents = Dval dty } -> ity_of_dity dty
get_ity dty | Duvar (tv,_) ->
| Duvar (tv,_) -> ity_var tv
ity_var tv | Dits (its,dl,rl) ->
| Dits (its,dl,rl) -> ity_app its (List.map ity_of_dity dl) (List.map reg_of_dreg rl)
ity_app its (List.map get_ity dl) (List.map get_reg rl) | Dts (ts,dl) ->
| Dts (ts,dl) -> ity_pur ts (List.map ity_of_dity dl)
ity_pur ts (List.map get_ity dl)
and get_reg = function and reg_of_dreg = function
| Rreg (r,_) -> | Rreg (r,_) ->
r r
| Rvar ({ contents = Rtvs (tv,dty) } as r) -> | Rvar ({ contents = Rtvs (tv,dty) } as r) ->
let reg = create_region (id_clone tv.tv_name) (get_ity dty) in let reg = create_region (id_clone tv.tv_name) (ity_of_dity dty) in
r := Rval (Rreg (reg,dty)); r := Rval (Rreg (reg,dty));
reg reg
| Rvar { contents = Rval dreg } -> | Rvar { contents = Rval dreg } ->
get_reg dreg reg_of_dreg dreg
in
get_ity dity
(* unification *) (* unification *)
...@@ -136,69 +124,105 @@ let rec occur_check tv = function ...@@ -136,69 +124,105 @@ let rec occur_check tv = function
| Dvar { contents = Dtvs tv' } | Duvar (tv',_) -> | Dvar { contents = Dtvs tv' } | Duvar (tv',_) ->
if tv_equal tv tv' then raise Exit if tv_equal tv tv' then raise Exit
let rec occur_check_reg tv = function let rec unify d1 d2 = match d1,d2 with
| Dvar { contents = Dval d } -> occur_check_reg tv d
| Dvar { contents = Dtvs _ } | Duvar _ -> ()
| Dits (_,dl,rl) ->
let rec check = function
| Rvar { contents = Rval dreg } -> check dreg
| Rvar { contents = Rtvs (tv',dity) } ->
if tv_equal tv tv' then raise Exit;
occur_check_reg tv dity
| Rreg _ -> ()
in
List.iter (occur_check_reg tv) dl;
List.iter check rl
| Dts (_,dl) ->
let rec unify ~weak d1 d2 = match d1,d2 with
| Dvar { contents = Dval d1 }, d2 | Dvar { contents = Dval d1 }, d2
| d1, Dvar { contents = Dval d2 } -> | d1, Dvar { contents = Dval d2 } ->
unify ~weak d1 d2 unify d1 d2
| Dvar { contents = Dtvs tv1 }, | Dvar { contents = Dtvs tv1 },
Dvar { contents = Dtvs tv2 } when tv_equal tv1 tv2 -> Dvar { contents = Dtvs tv2 } when tv_equal tv1 tv2 ->
| Dvar ({ contents = Dtvs tv } as r), d | Dvar ({ contents = Dtvs tv } as r), d
| d, Dvar ({ contents = Dtvs tv } as r) -> | d, Dvar ({ contents = Dtvs tv } as r) ->
occur_check tv d; r := Dval d occur_check tv d;
| Duvar (tv1,_), Duvar (tv2,_) when tv_equal tv1 tv2 -> () r := Dval d
| Dits (its1, dl1, rl1), Dits (its2, dl2, rl2) when its_equal its1 its2 -> | Duvar (tv1,_), Duvar (tv2,_) when tv_equal tv1 tv2 ->
assert (List.length rl1 = List.length rl2); ()
assert (List.length dl1 = List.length dl2); | Dits (its1,dl1,_), Dits (its2,dl2,_) when its_equal its1 its2 ->
List.iter2 (unify ~weak) dl1 dl2; List.iter2 unify dl1 dl2
if not weak then List.iter2 unify_reg rl1 rl2 | Dts (ts1,dl1), Dts (ts2,dl2) when ts_equal ts1 ts2 ->
| Dts (ts1, dl1), Dts (ts2, dl2) when ts_equal ts1 ts2 -> List.iter2 unify dl1 dl2
| _ -> raise Exit | _ -> raise Exit
and unify_reg r1 r2 =
let rec dity_of_reg = function
| Rvar { contents = Rval r } -> dity_of_reg r
| Rvar { contents = Rtvs (_,dity) }
| Rreg (_,dity) -> dity
in
match r1,r2 with
| Rvar { contents = Rval r1 }, r2
| r1, Rvar { contents = Rval r2 } ->
unify_reg r1 r2
| Rvar { contents = Rtvs (tv1,_) },
Rvar { contents = Rtvs (tv2,_) } when tv_equal tv1 tv2 ->
| Rvar ({ contents = Rtvs (tv,rd) } as r), d
| d, Rvar ({ contents = Rtvs (tv,rd) } as r) ->
let dity = dity_of_reg d in
occur_check_reg tv dity;
unify ~weak:false rd dity;
r := Rval d
| Rreg (reg1,_), Rreg (reg2,_) when reg_equal reg1 reg2 -> ()
| _ -> raise Exit
exception DTypeMismatch of dity * dity exception DTypeMismatch of dity * dity
let unify d1 d2 =
try unify d1 d2 with Exit -> raise (DTypeMismatch (d1,d2))
(** Reunify regions *)
let dtvs_queue : dvar ref Queue.t = Queue.create ()
let r = ref (Dtvs (create_tvsymbol (id_fresh "a"))) in
Queue.add r dtvs_queue;
Dvar r
let refresh_dtvs () =
let refr r = match !r with
| Dval dty -> r := Dval (dity_refresh dty)
| Dtvs _ -> () in
Queue.iter refr dtvs_queue;
Queue.clear dtvs_queue
let unify_queue : (dity * dity) Queue.t = Queue.create ()
let unify ?(weak=false) d1 d2 = let unify ?(weak=false) d1 d2 =
try unify ~weak d1 d2 with Exit -> raise (DTypeMismatch (d1,d2)) unify d1 d2;
if not weak then Queue.add (d1,d2) unify_queue
let rec reunify d1 d2 = match d1,d2 with
reunify d1 d2
| Dvar { contents = Dtvs tv1 }, Dvar { contents = Dtvs tv2 }
| Duvar (tv1,_), Duvar (tv2,_) ->
assert (tv_equal tv1 tv2)
| Dits (its1,dl1,rl1), Dits (its2,dl2,rl2) ->
assert (its_equal its1 its2);
List.iter2 reunify dl1 dl2;
| Dts (ts1,dl1), Dts (ts2,dl2) ->
assert (ts_equal ts1 ts2);
| _ -> assert false
and unify_reg r1 r2 = match r1,r2 with
unify_reg r1 r2
| Rvar ({ contents = Rtvs (_,d1) } as r),
(Rvar { contents = Rtvs (_,d2) } as d)
| Rvar ({ contents = Rtvs (_,d1) } as r), (Rreg (_,d2) as d)
| (Rreg (_,d1) as d), Rvar ({ contents = Rtvs (_,d2) } as r) ->
reunify d1 d2;
r := Rval d
| Rreg _, Rreg _ -> ()
(* we don't check whether the regions are the same,
because we won't have a good location for the error.
Let the core API raise the exception later. *)
let reunify_regs () =
Queue.iter (fun (d1,d2) -> reunify d1 d2) unify_queue;
Queue.clear unify_queue
if not (Queue.is_empty unify_queue) then begin
refresh_dtvs ();
reunify_regs ()
end;
ity_of_dity dity
(** Arrow types *)
type dvty = dity list * dity (* A -> B -> C == ([A;B],C) *) type dvty = dity list * dity (* A -> B -> C == ([A;B],C) *)
...@@ -218,46 +242,38 @@ let empty_tvars = [] ...@@ -218,46 +242,38 @@ let empty_tvars = []
let add_dity tvs dity = dity :: tvs let add_dity tvs dity = dity :: tvs
let add_dvty tvs (argl,res) = res :: List.rev_append argl tvs let add_dvty tvs (argl,res) = res :: List.rev_append argl tvs
let rec add_dity_vars tvs = function
| Dvar { contents = Dtvs _ } as dity -> dity :: tvs
| Dvar { contents = Dval dity } -> add_dity_vars tvs dity
| Duvar _ as dity -> dity :: tvs
| Dits (_,dl,_)
| Dts (_,dl) -> List.fold_left add_dity_vars tvs dl
let add_dvty_vars tvs (argl,res) =
add_dity_vars (List.fold_left add_dity_vars tvs argl) res
let tv_in_tvars tv tvs = let tv_in_tvars tv tvs =
try List.iter (occur_check tv) tvs; false with Exit -> true try List.iter (occur_check tv) tvs; false with Exit -> true
let reg_in_tvars tv tvs =
try List.iter (occur_check_reg tv) tvs; false with Exit -> true
let specialize_scheme tvs (argl,res) = let specialize_scheme tvs (argl,res) =
let htvs = Htv.create 17 in let htvs = Htv.create 17 in
let hreg = Htv.create 17 in let hreg = Htv.create 17 in
let rec specialize = function let rec specialize = function
| Dvar { contents = Dval d } -> specialize d | Dvar { contents = Dval d } ->
specialize d
| Dvar { contents = Dtvs tv } | Duvar (tv,_) as d -> | Dvar { contents = Dtvs tv } | Duvar (tv,_) as d ->
if tv_in_tvars tv tvs then d else
begin try Htv.find htvs tv with Not_found -> begin try Htv.find htvs tv with Not_found ->
let v = create_type_variable () in let v = create_type_variable () in
Htv.add htvs tv v; v (* can't use d directly, might differ in regions *)
if tv_in_tvars tv tvs then unify ~weak:true v d;
Htv.add htvs tv v;
v
end end
| Dits (its, dl, rl) -> | Dits (its,dl,rl) ->
its_app_real its (List.map specialize dl) (List.map spec_reg rl) its_app_real its (List.map specialize dl) (List.map spec_reg rl)
| Dts (ts, dl) -> | Dts (ts,dl) ->
ts_app_real ts (List.map specialize dl) ts_app_real ts (List.map specialize dl)
and spec_reg r = match r with and spec_reg = function
| Rvar { contents = Rval r } -> spec_reg r | Rvar { contents = Rval r } ->
spec_reg r
| Rvar { contents = Rtvs (tv,dity) } -> | Rvar { contents = Rtvs (tv,dity) } ->
if reg_in_tvars tv tvs then r else
begin try Htv.find hreg tv with Not_found -> begin try Htv.find hreg tv with Not_found ->
let v = create_dreg (specialize dity) in let v = create_dreg (specialize dity) in
Htv.add hreg tv v; v Htv.add hreg tv v;
v
end end
| Rreg _ -> r | Rreg _ as r ->
r
in in
List.map specialize argl, specialize res List.map specialize argl, specialize res
...@@ -27,15 +27,12 @@ type tvars (* a set of type variables *) ...@@ -27,15 +27,12 @@ type tvars (* a set of type variables *)
val empty_tvars: tvars val empty_tvars: tvars
val add_dity: tvars -> dity -> tvars val add_dity: tvars -> dity -> tvars
val add_dvty: tvars -> dvty -> tvars val add_dvty: tvars -> dvty -> tvars
val add_dvty_vars: tvars -> dvty -> tvars (* add only variables *)
val create_type_variable: unit -> dity val create_type_variable: unit -> dity
val create_user_type_variable: Ptree.ident -> (* opaque *) bool -> dity val create_user_type_variable: Ptree.ident -> (* opaque *) bool -> dity
val its_app: itysymbol -> dity list -> dity val its_app: itysymbol -> dity list -> dity
val ts_app: tysymbol -> dity list -> dity val ts_app: tysymbol -> dity list -> dity
val dity_refresh: dity -> dity (* refresh regions *)
val opaque_tvs: Stv.t -> dity -> Stv.t val opaque_tvs: Stv.t -> dity -> Stv.t
val is_chainable: dvty -> bool (* non-bool * non-bool -> bool *) val is_chainable: dvty -> bool (* non-bool * non-bool -> bool *)
...@@ -46,7 +43,7 @@ val unify: ?weak:bool -> dity -> dity -> unit ...@@ -46,7 +43,7 @@ val unify: ?weak:bool -> dity -> dity -> unit
(* when [weak] is true, don't unify regions *) (* when [weak] is true, don't unify regions *)
val ity_of_dity: dity -> ity val ity_of_dity: dity -> ity
(* only use once unification is done *) (* only use once all unification is done *)
val specialize_scheme: tvars -> dvty -> dvty val specialize_scheme: tvars -> dvty -> dvty
...@@ -175,15 +175,15 @@ let rec extract_labels labs loc e = match e.Ptree.expr_desc with ...@@ -175,15 +175,15 @@ let rec extract_labels labs loc e = match e.Ptree.expr_desc with
labs, loc, Ptree.Ecast ({ e with Ptree.expr_desc = d }, ty) labs, loc, Ptree.Ecast ({ e with Ptree.expr_desc = d }, ty)
| e -> labs, loc, e | e -> labs, loc, e
let rec find_top_pty e = match e.Ptree.expr_desc with
| Ptree.Enamed (_, e) -> find_top_pty e
| Ptree.Ecast (_, pty) -> Some pty
| _ -> None
(* Hack alert. Since the result type in "let [rec] fn x y : ty = ..." (* Hack alert. Since the result type in "let [rec] fn x y : ty = ..."
is moved to Ecast and then usually lost in destructive unification, is moved to Ecast and then usually lost in destructive unification,
we try to preserve opacity annotations by moving them to binders. *) we try to preserve opacity annotations by moving them to binders. *)
let pass_opacity (e,_) bl = let pass_opacity (e,_) bl = match find_top_pty e with
let rec find e = match e.Ptree.expr_desc with
| Ptree.Enamed (_, e) -> find e
| _ -> None in
match find e with
| Some pty -> | Some pty ->
let ht = Hstr.create 3 in let ht = Hstr.create 3 in
let rec fill = function let rec fill = function
...@@ -277,6 +277,12 @@ let add_mono id dvty denv = ...@@ -277,6 +277,12 @@ let add_mono id dvty denv =
let locals = Mstr.add id.id (None, dvty) denv.locals in let locals = Mstr.add id.id (None, dvty) denv.locals in
{ denv with locals = locals; tvars = add_dvty denv.tvars dvty } { denv with locals = locals; tvars = add_dvty denv.tvars dvty }
let add_rec_mono id dvty denv =
(* fix type variables but not regions *)
let tvars = add_dvty denv.tvars dvty in
let locals = Mstr.add id.id (Some tvars, dvty) denv.locals in
{ denv with locals = locals; tvars = tvars }
let add_var id dity denv = add_mono id ([],dity) denv let add_var id dity denv = add_mono id ([],dity) denv
let specialize_qualid uc p = match uc_find_ps uc p with let specialize_qualid uc p = match uc_find_ps uc p with
...@@ -698,224 +704,37 @@ and de_desc denv loc = function ...@@ -698,224 +704,37 @@ and de_desc denv loc = function
and dletrec ~top denv fdl = and dletrec ~top denv fdl =
(* add all functions into the environment *) (* add all functions into the environment *)
let add_one denv (_,id,_,bl,_) = let add_one denv (_,id,_,bl,tr) =
let argl = List.map (fun _ -> create_type_variable ()) bl in let _,argl,tyl = dbinders denv (pass_opacity tr bl) in
let dvty = argl, create_type_variable () in let rpty = find_top_pty (fst tr) in
add_mono id dvty denv, dvty in let dvty = tyl, match rpty with
| Some pty -> dity_of_pty denv pty
| None -> create_type_variable () in
let check (_,_,_,apty) = apty = None in
let denv = if rpty = None || List.exists check bl
then add_rec_mono id dvty denv
else add_poly id dvty denv in
denv, (argl, dvty) in
let denv, dvtyl = Lists.map_fold_left add_one denv fdl in let denv, dvtyl = Lists.map_fold_left add_one denv fdl in
(* then unify the binders *)
let bind_one (_,_,_,bl,tr) (argl,res) =
let denv,bl,tyl = dbinders denv (pass_opacity tr bl) in
List.iter2 unify argl tyl;
denv,bl,tyl,res in
let denvl = List.map2 bind_one fdl dvtyl in
(* then type-check the bodies *) (* then type-check the bodies *)
let type_one (loc,id,gh,_,tr) (denv,bl,tyl,tyv) = let type_one (loc,id,gh,bl,tr) (argl,((tyl,tyv) as dvty)) =
let add denv (_,id,_,_) dity = match id with
| Some id -> add_var id dity denv
| None -> denv in
let denv = List.fold_left2 add denv bl tyl in
let id, gh = add_lemma_label ~top id gh in let id, gh = add_lemma_label ~top id gh in
let tr, (argl, res) = dtriple denv tr in let tr, (badl, res) = dtriple denv tr in
if argl <> [] then errorm ~loc if badl <> [] then errorm ~loc
"The body of a recursive function must be a first-order value"; "The body of a recursive function must be a first-order value";
unify_loc unify loc tyv res; unify_loc unify loc tyv res;
id, gh, (tyl, tyv), bl, tr in id, gh, dvty, argl, tr in
List.map2 type_one fdl denvl List.map2 type_one fdl dvtyl
and dtriple denv (e, sp) = and dtriple denv (e, sp) =
let e = dexpr denv e in let e = dexpr denv e in
let sp = dspec denv.uc sp in let sp = dspec denv.uc sp in
(e, sp), e.de_type (e, sp), e.de_type
(** stage 1.5 *)
(* After the stage 1, we know precisely the types of all binders
and program expressions. However, the regions in recursive functions
might be over-unified, since we do not support recursive polymorphism.
For example, the letrec below will require that a and b share the region.
let rec main a b : int = if !a = 0 then main b a else 5
To avoid this, we retype the whole dexpr generated at the stage 1.
Every binder keeps its previous type with all regions refreshed.
Every non-arrow expression keeps its previous type modulo regions.
When we type-check recursive functions, we add them to the denv
as polymorphic, but freeze every type variable. In other words,
only regions are specialized during recursive calls. *)
let add_preid id dity denv =
add_var (mk_id (Ident.preid_name id) Loc.dummy_position) dity denv
let rec rpattern denv pp dity = match pp with
| PPwild -> denv
| PPvar id -> add_preid id dity denv
| PPlapp (ls, ppl) -> rpat_app denv (specialize_lsymbol ls) ppl dity
| PPpapp (pl, ppl) -> rpat_app denv (specialize_plsymbol pl) ppl dity
| PPor (pp1, pp2) -> rpattern (rpattern denv pp1 dity) pp2 dity
| PPas (pp1, id) -> add_preid id dity (rpattern denv pp1 dity)
and rpat_app denv (argl,res) ppl dity =
unify res dity;
List.fold_left2 rpattern denv ppl argl
let rbinders denv bl =
let rbinder (id,gh,dity) (denv,bl,tyl) =
let dity = dity_refresh dity in
add_var id dity denv, (id,gh,dity)::bl, dity::tyl in
List.fold_right rbinder bl (denv,[],[])
let rec rtype_c denv (tyv, sp) =
let tyv, dvty = rtype_v denv tyv in (tyv, sp), dvty
and rtype_v denv = function
| DSpecV dity ->
DSpecV dity, ([],dity)
| DSpecA (bl,tyc) ->
let denv,bl,tyl = rbinders denv bl in
let tyc,(argl,res) = rtype_c denv tyc in
DSpecA (bl,tyc), (tyl @ argl,res)
let rec rexpr denv ({ de_type = (argl,res) } as de) =
let desc, dvty = re_desc denv de in
let de = { de with de_desc = desc; de_type = dvty } in
if argl = [] then expected_type ~weak:true de (dity_refresh res);
de
and re_desc denv de = match de.de_desc with
| DElocal x as d ->
let dvty = match Mstr.find x denv.locals with
| Some tvs, dvty -> specialize_scheme tvs dvty
| None, dvty -> dvty in
d, dvty
| DEglobal_pv pv as d -> d, ([],specialize_pvsymbol pv)
| DEglobal_ps ps as d -> d, specialize_psymbol ps
| DEglobal_pl pl as d -> d, specialize_plsymbol pl
| DEglobal_ls ls as d -> d, specialize_lsymbol ls
| DEconstant _ as d -> d, de.de_type
| DEapply (e1, el) ->
let e1 = rexpr denv e1 in
let el = List.map (rexpr denv) el in
de_app de.de_loc e1 el
| DEfun (bl, (e1, sp)) ->
let denv, bl, tyl = rbinders denv bl in
let argl, res = e1.de_type in
DEfun (bl, (e1, sp)), (tyl @ argl, res)
| DElet (id, gh, e1, e2) ->
let denv = match e1.de_desc with
| DEfun _ -> add_poly id e1.de_type denv
| _ -> add_mono id e1.de_type denv in
let e2 = rexpr denv e2 in
DElet (id, gh, e1, e2), e2.de_type
| DEletrec (fdl, e1) ->
let fdl = rletrec denv fdl in
let add_one denv (id,_,dvty,_,_) = add_poly id dvty denv in
let denv = List.fold_left add_one denv fdl in
DEletrec (fdl, e1), e1.de_type
| DEassign (pl, e1, e2) ->
(* no need to weakly reunify e1.pl with e2,
since both dexprs retain their "pure" types *)
DEassign (pl, e1, e2), ([], dity_unit)
| DEif (e1, e2, e3) ->
expected_type e1 dity_bool;
let e3 = rexpr denv e3 in
let res = create_type_variable () in
expected_type e2 res;
expected_type e3 res;
DEif (e1, e2, e3), e2.de_type
| DElazy (op, e1, e2) ->
expected_type e2 dity_bool;
DElazy (op, e1, e2), ([], dity_bool)
| DEnot e1 ->
DEnot e1, ([], dity_bool)
| DEmatch (e1, bl) ->
let ety = create_type_variable () in
expected_type e1 ety;
let branch (pp,e) =
