\item[Preferences] opens a window for modifying preferred
]\item[Preferences] opens a window for modifying preferred
configuration parameters, see details below.
\item[Reload] reloads the input files from disk, and update the session state accordingly.
\item[Save session] saves current session state on disk. The policy to decide when to save the session is configurable, as described in the preferences below.
