Attention une mise à jour du serveur va être effectuée le vendredi 16 avril entre 12h et 12h30. Cette mise à jour va générer une interruption du service de quelques minutes.
Commit 6b0c7b82 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Realize some more theories about lists. Fix an inconsistent axiom along the way.
parent 25472f1d
...@@ -828,7 +828,7 @@ COQLIBS_SET = $(addprefix lib/coq/set/, $(COQLIBS_SET_FILES)) ...@@ -828,7 +828,7 @@ COQLIBS_SET = $(addprefix lib/coq/set/, $(COQLIBS_SET_FILES))
COQLIBS_MAP_FILES = Map MapPermut COQLIBS_MAP_FILES = Map MapPermut
COQLIBS_MAP = $(addprefix lib/coq/map/, $(COQLIBS_MAP_FILES)) COQLIBS_MAP = $(addprefix lib/coq/map/, $(COQLIBS_MAP_FILES))
COQLIBS_LIST_FILES = List Length Nth NthLength COQLIBS_LIST_FILES = List Length Mem Nth NthLength HdTl NthHdTl Append
COQLIBS_LIST = $(addprefix lib/coq/list/, $(COQLIBS_LIST_FILES)) COQLIBS_LIST = $(addprefix lib/coq/list/, $(COQLIBS_LIST_FILES))
COQLIBS_OPTION_FILES = Option COQLIBS_OPTION_FILES = Option
...@@ -273,15 +273,21 @@ end ...@@ -273,15 +273,21 @@ end
theory list.List theory list.List
syntax type list "list %1" syntax type list "(list %1)"
syntax function Nil "nil" syntax function Nil "nil"
syntax function Cons "(cons %1 %2)" syntax function Cons "(cons %1 %2)"
end end
theory list.Append
syntax function (++) "(List.app %1 %2)"
theory option.Option theory option.Option
syntax type option "option %1" syntax type option "(option %1)"
syntax function None "None" syntax function None "None"
syntax function Some "(Some %1)" syntax function Some "(Some %1)"
(* This file is generated by Why3's Coq-realize driver *)
(* Beware! Only edit allowed sections below *)
Require Import BuiltIn.
Require BuiltIn.
Require int.Int.
Require list.List.
Require list.Length.
Require list.Mem.
(* Why3 goal *)
Lemma infix_plpl_def {a:Type} {a_WT:WhyType a}: forall (l1:(list a))
(l2:(list a)),
((List.app l1 l2) = match l1 with
| nil => l2
| (cons x1 r1) => (cons x1 (List.app r1 l2))
end).
Proof.
now intros [|h1 q1] l2.
Qed.
Require Import Lists.List.
(* Why3 goal *)
Lemma Append_assoc : forall {a:Type} {a_WT:WhyType a}, forall (l1:(list a))
(l2:(list a)) (l3:(list a)),
((List.app l1 (List.app l2 l3)) = (List.app (List.app l1 l2) l3)).
Proof.
intros a a_WT l1 l2 l3.
apply app_assoc.
Qed.
(* Why3 goal *)
Lemma Append_l_nil : forall {a:Type} {a_WT:WhyType a}, forall (l:(list a)),
((List.app l nil) = l).
Proof.
intros a a_WT l.
apply app_nil_r.
Qed.
(* Why3 goal *)
Lemma Append_length : forall {a:Type} {a_WT:WhyType a}, forall (l1:(list a))
(l2:(list a)),
((list.Length.length (List.app l1 l2)) = ((list.Length.length l1) + (list.Length.length l2))%Z).
Proof.
intros a a_WT l1 l2.
rewrite 3!Length.length_std.
now rewrite app_length, inj_plus.
Qed.
(* Why3 goal *)
Lemma mem_append : forall {a:Type} {a_WT:WhyType a}, forall (x:a)
(l1:(list a)) (l2:(list a)), (list.Mem.mem x (List.app l1 l2)) <->
((list.Mem.mem x l1) \/ (list.Mem.mem x l2)).
Proof.
intros a a_WT x l1 l2.
split.
intros H.
apply Mem.mem_std in H.
apply in_app_or in H.
destruct H as [H|H].
left.
now apply Mem.mem_std.
right.
intros H.
apply Mem.mem_std.
apply in_or_app.
left.
right.
Qed.
(* Why3 goal *)
Lemma mem_decomp : forall {a:Type} {a_WT:WhyType a}, forall (x:a)
(l:(list a)), (list.Mem.mem x l) -> exists l1:(list a), exists l2:(list a),
(l = (List.app l1 (cons x l2))).
Proof.
intros a a_WT x l h1.
apply in_split.
Qed.
Require BuiltIn.
Require list.List.
Require option.Option.
(* Why3 assumption *)
Definition hd {a:Type} {a_WT:WhyType a} (l:(list a)): (option a) :=
match l with
| nil => None
| (cons h _) => (Some h)
end.
Definition tl {a:Type} {a_WT:WhyType a} (l:(list a)): (option (list a)) :=
match l with
| nil => None
| (cons _ t) => (Some t)
end.
...@@ -6,26 +6,34 @@ Require int.Int. ...@@ -6,26 +6,34 @@ Require int.Int.
Require list.List. Require list.List.
(* Why3 assumption *) (* Why3 assumption *)
Fixpoint length {a:Type} {a_WT:WhyType a} (l:list a) {struct l}: Z := Fixpoint length {a:Type} {a_WT:WhyType a} (l:(list a)) {struct l}: Z :=
match l with match l with
| nil => 0%Z | nil => 0%Z
| (cons _ r) => (1%Z + (length r))%Z | (cons _ r) => (1%Z + (length r))%Z
end. end.
Lemma length_std :
forall {a:Type} {a_WT:WhyType a} (l:list a),
length l = Z_of_nat (List.length l).
Proof.
intros a a_WT l.
induction l.
easy.
change (1 + length l = Z.of_nat (S (List.length l)))%Z.
now rewrite inj_S, Zplus_comm, IHl.
Qed.
(* Why3 goal *) (* Why3 goal *)
Lemma Length_nonnegative : forall {a:Type} {a_WT:WhyType a}, Lemma Length_nonnegative : forall {a:Type} {a_WT:WhyType a},
forall (l:list a), (0%Z <= (length l))%Z. forall (l:(list a)), (0%Z <= (length l))%Z.
Proof. Proof.
intros a a_WT l. intros a a_WT l.
induction l as [|h t]. rewrite length_std.
apply Zle_refl. apply Zle_0_nat.
unfold length.
fold length.
omega.
Qed. Qed.
Lemma Length_nil : forall {a:Type} {a_WT:WhyType a}, forall (l:list a), Lemma Length_nil : forall {a:Type} {a_WT:WhyType a}, forall (l:(list a)),
((length l) = 0%Z) <-> (l = nil). ((length l) = 0%Z) <-> (l = nil).
Proof. Proof.
intros a a_WT [|h t] ; split ; try easy. intros a a_WT [|h t] ; split ; try easy.
Require BuiltIn.
Require list.List.
Fixpoint mem {a:Type} {a_WT:WhyType a} (x:a) (l:(list a)) {struct l}: Prop :=
match l with
| nil => False
| (cons y r) => (x = y) \/ (mem x r)
end.
Lemma mem_std :
forall {a:Type} {a_WT:WhyType a} (x:a) (l:list a),
mem x l <-> List.In x l.
Proof.
intros a a_WT x l.
induction l as [|h q].
easy.
simpl.
split ; intros [H|H].
now left.
right.
now apply IHq.
now left.
right.
now apply IHq.
Qed.
...@@ -7,13 +7,14 @@ Require list.List. ...@@ -7,13 +7,14 @@ Require list.List.
Require option.Option. Require option.Option.
Definition nth: forall {a:Type} {a_WT:WhyType a}, Z -> list a -> option a. Definition nth: forall {a:Type} {a_WT:WhyType a}, Z -> (list a)
-> (option a).
intros a a_WT. intros a a_WT.
exact (fix nth n l := match l with nil => None | cons h t => if Zeq_bool n Z0 then Some h else nth (n - 1)%Z t end). exact (fix nth n l := match l with nil => None | cons h t => if Zeq_bool n Z0 then Some h else nth (n - 1)%Z t end).
Defined. Defined.
Lemma nth_def : forall {a:Type} {a_WT:WhyType a}, forall (n:Z) (l:list a), Lemma nth_def : forall {a:Type} {a_WT:WhyType a}, forall (n:Z) (l:(list a)),
| nil => ((nth n l) = None) | nil => ((nth n l) = None)
| (cons x r) => ((n = 0%Z) -> ((nth n l) = (Some x))) /\ ((~ (n = 0%Z)) -> | (cons x r) => ((n = 0%Z) -> ((nth n l) = (Some x))) /\ ((~ (n = 0%Z)) ->
Require BuiltIn.
Require int.Int.
Require list.List.
Require list.Nth.
Require list.HdTl.
(* Why3 goal *)
Lemma Nth_tl : forall {a:Type} {a_WT:WhyType a}, forall (l1:(list a))
(l2:(list a)), ((list.HdTl.tl l1) = (Some l2)) -> forall (i:Z),
(~ (i = (-1%Z)%Z)) -> ((list.Nth.nth i l2) = (list.Nth.nth (i + 1%Z)%Z
l1)).
Proof.
intros a a_WT [|x1 l1] l2 h1 i h2.
easy.
simpl.
generalize (Zeq_bool_if (i + 1) 0).
case Zeq_bool.
omega.
intros _.
simpl in h1.
inversion h1.
apply (f_equal (fun i => Nth.nth i l2)).
exact (Zpred_succ i).
Qed.
(* Why3 goal *)
Lemma Nth0_head : forall {a:Type} {a_WT:WhyType a}, forall (l:(list a)),
((list.Nth.nth 0%Z l) = (list.HdTl.hd l)).
Proof.
now intros a a_WT [|h t].
Qed.
...@@ -9,8 +9,8 @@ Require list.Nth. ...@@ -9,8 +9,8 @@ Require list.Nth.
Lemma nth_none_1 : forall {a:Type} {a_WT:WhyType a}, forall (l:list a) (i:Z), Lemma nth_none_1 : forall {a:Type} {a_WT:WhyType a}, forall (l:(list a))
(i < 0%Z)%Z -> ((list.Nth.nth i l) = None). (i:Z), (i < 0%Z)%Z -> ((list.Nth.nth i l) = None).
Proof. Proof.
induction l as [|h q]. induction l as [|h q].
...@@ -27,8 +27,8 @@ omega. ...@@ -27,8 +27,8 @@ omega.
Qed. Qed.
Lemma nth_none_2 : forall {a:Type} {a_WT:WhyType a}, forall (l:list a) (i:Z), Lemma nth_none_2 : forall {a:Type} {a_WT:WhyType a}, forall (l:(list a))
((list.Length.length l) <= i)%Z -> ((list.Nth.nth i l) = None). (i:Z), ((list.Length.length l) <= i)%Z -> ((list.Nth.nth i l) = None).
Proof. Proof.
...@@ -49,8 +49,8 @@ omega. ...@@ -49,8 +49,8 @@ omega.
Qed. Qed.
Lemma nth_none_3 : forall {a:Type} {a_WT:WhyType a}, forall (l:list a) (i:Z), Lemma nth_none_3 : forall {a:Type} {a_WT:WhyType a}, forall (l:(list a))
((list.Nth.nth i l) = None) -> ((i < 0%Z)%Z \/ (i:Z), ((list.Nth.nth i l) = None) -> ((i < 0%Z)%Z \/
((list.Length.length l) <= i)%Z). ((list.Length.length l) <= i)%Z).
Proof. Proof.
...@@ -118,7 +118,7 @@ theory NthHdTl ...@@ -118,7 +118,7 @@ theory NthHdTl
lemma Nth_tl: lemma Nth_tl:
forall l1 l2: list 'a. tl l1 = Some l2 -> forall l1 l2: list 'a. tl l1 = Some l2 ->
forall i: int. nth i l2 = nth (i+1) l1 forall i: int. i <> -1 -> nth i l2 = nth (i+1) l1
lemma Nth0_head: lemma Nth0_head:
forall l: list 'a. nth 0 l = hd l forall l: list 'a. nth 0 l = hd l
