Commit 6a6b268f authored by François Bobot's avatar François Bobot
why3html : very very minimalist html output
parent d2e3986b
...@@ -69,6 +69,9 @@ why3.conf ...@@ -69,6 +69,9 @@ why3.conf
/bin/why3replayer.byte /bin/why3replayer.byte
/bin/why3replayer.opt /bin/why3replayer.opt
/bin/why3replayer /bin/why3replayer
/bin/why3html.byte
/bin/why3html.opt
/bin/why3html
# /doc/ # /doc/
/doc/version.tex /doc/version.tex
...@@ -568,6 +568,56 @@ install_no_local:: ...@@ -568,6 +568,56 @@ install_no_local::
install_local: bin/why3replayer install_local: bin/why3replayer
# Html
HTML_FILES = xml termcode session session_ro html_session
HTMLMODULES = $(addprefix src/ide/, $(HTML_FILES))
HTMLML = $(addsuffix .ml, $(HTMLMODULES))
HTMLMLI = $(addsuffix .mli, $(HTMLMODULES))
HTMLCMO = $(addsuffix .cmo, $(HTMLMODULES))
HTMLCMX = $(addsuffix .cmx, $(HTMLMODULES))
$(HTMLCMO) $(HTMLCMX): INCLUDES += -I src/ide
# build targets
byte: bin/why3html.byte
opt: bin/why3html.opt
bin/why3html.opt: src/why3.cmxa $(PGMCMX) $(HTMLCMX)
$(if $(QUIET), @echo 'Linking $@' &&) \
$(OCAMLOPT) $(OFLAGS) -o $@ $(EXTCMXA) $^
$(STRIP) $@
bin/why3html.byte: src/why3.cma $(PGMCMO) $(HTMLCMO)
$(if $(QUIET),@echo 'Linking $@' &&) \
$(OCAMLC) $(BFLAGS) -o $@ $(EXTCMA) $^
bin/why3html: bin/why3html.@OCAMLBEST@
ln -sf why3html.@OCAMLBEST@ $@
# depend and clean targets
include .depend.html
.depend.html: src/ide/xml.ml
$(OCAMLDEP) -slash -I src -I src/ide $(HTMLML) $(HTMLMLI) > $@
depend: .depend.html
clean::
rm -f bin/why3html.byte bin/why3html.opt bin/why3html
rm -f .depend.html
install_no_local::
cp -f bin/why3html.@OCAMLBEST@ $(BINDIR)/why3html
install_local: bin/why3html
# Bench # Bench
(* Copyright (C) 2010-2011 *)
(* François Bobot *)
(* Jean-Christophe Filliâtre *)
(* Claude Marché *)
(* Andrei Paskevich *)
(* This software is free software; you can redistribute it and/or *)
(* modify it under the terms of the GNU Library General Public *)
(* License version 2.1, with the special exception on linking *)
(* described in file LICENSE. *)
(* This software is distributed in the hope that it will be useful, *)
(* but WITHOUT ANY WARRANTY; without even the implied warranty of *)
(* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. *)
open Why3
let includes = ref []
let files = Queue.create ()
let opt_version = ref false
let output_dir = ref ""
let allow_obsolete = ref true
let opt_config = ref None
let spec = Arg.align [
("-I",
Arg.String (fun s -> includes := s :: !includes),
"<s> add s to loadpath") ;
("-v",
Arg.Set opt_version,
" print version information") ;
("-o",
Arg.Set_string output_dir,
" the directory to output the files");
("--strict",
Arg.Clear allow_obsolete,
" forbid obsolete session");
"-C", Arg.String (fun s -> opt_config := Some s),
"<file> Read configuration from <file>";
"--config", Arg.String (fun s -> opt_config := Some s),
" same as -C";
let version_msg = Format.sprintf
"Why3 html session output, version %s (build date: %s)"
Config.version Config.builddate
let usage_str = Format.sprintf
"Usage: %s [options] [<file.why>|<project directory>] ... "
(Filename.basename Sys.argv.(0))
let set_file f = Queue.push f files
let () = Arg.parse spec set_file usage_str
let () =
if !opt_version then begin
Format.printf "%s@." version_msg;
exit 0
let output_dir =
if !output_dir = "" then begin
Format.printf "output_dir must be set@.";
exit 0
else !output_dir
let allow_obsolete = !allow_obsolete
let includes = List.rev !includes
open Session_ro
let env = read_config ~includes !opt_config
open Format
open Util
let print_prover fmt = function
| Detected_prover pd -> fprintf fmt "%s" pd.prover_name
| Undetected_prover s -> fprintf fmt "%s" s
let print_proof_status fmt = function
| Undone -> fprintf fmt "Undone"
| Done pr -> fprintf fmt "Done : %a" Call_provers.print_prover_result pr
| InternalFailure exn ->
fprintf fmt "Failure : %a"Exn_printer.exn_printer exn
let print_proof_attempt fmt pa =
fprintf fmt "<il>%a : %a</il>"
print_prover pa.prover
print_proof_status pa.proof_state
let rec print_transf fmt tr =
fprintf fmt "<il>%s : <ul>%a</ul></il>"
tr.transf_name
(Pp.print_list Pp.newline print_goal) tr.subgoals
and print_goal fmt g =
fprintf fmt "<il>%s : <ul>%a%a</ul></il>"
g.goal_name
(Pp.print_iter2 Mstr.iter Pp.newline Pp.nothing
Pp.nothing print_proof_attempt)
g.external_proofs
Pp.nothing print_transf)
g.transformations
let print_theory fmt th =
th.theory_name
(Pp.print_list Pp.newline print_goal) th.goals
let print_file fmt f =
f.file_name
(Pp.print_list Pp.newline print_theory) f.theories
let print_session fmt s =
fprintf fmt "<p><ul>%a</ul></p>"
(Pp.print_list Pp.newline print_file) s
let run_file f =
let session_path = get_project_dir f in
let session = read_project_dir ~allow_obsolete ~env session_path in
let basename = Filename.basename session_path in
let cout = open_out (Filename.concat output_dir (basename^".html")) in
let fmt = formatter_of_out_channel cout in
fprintf fmt
"<!DOCTYPE html
PUBLIC \"-//W3C//DTD XHTML 1.0 Strict//EN\"
\"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd\">
<html xmlns=\"http://www.w3.org/1999/xhtml\">
<head>
<title>A template for why3html</title>
</head>
<body>
%a
</body>
</html>
print_session session
let () = Queue.iter run_file files
