GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
68385317
Martin Clochard
Renamed transformation curry into prop_curry
92eb6f5d
2
Makefile.in
68385317
@@ -156,7 +156,7 @@ LIB_TRANSFORM = simplify_formula inlining split_goal induction \
introduction abstraction close_epsilon lift_epsilon
eliminate_epsilon
eval_match instantiate_predicate smoke_detector
reduction_engine compute induction_pr curry
prop_
curry
LIB_PRINTER
alt_ergo why3printer smtv1 smtv2 coq pvs isabelle
simplify gappa cvc3 yices mathematica
src/transform/curry.ml
src/transform/
prop_
curry.ml
68385317
open
Term
open
Decl
let
rec
curry
t
match
t
t_node
Tbinop
Timplies
lhs
rhs
expand
t
lhs
curry
rhs
_
t_map
curry
t
@@ -10,11 +10,10 @@ and expand orig l r = match l.t_node with
Tbinop
Tand
a
b
expand
orig
a
expand
orig
b
r
_
t_label_copy
orig
t_implies
curry
l
r
let
curry
Trans
goal
fun
pr
t
create_prop_decl
Pgoal
pr
curry
t
let
Trans
register_transform
"curry"
curry
desc
"Currify."
Trans
register_transform
"prop_curry"
curry
desc
"Transform@ conjunctions@ in@ implication@ premises@ into@ \
sequences@ of@ premises."
