Commit 67ac2bf0 authored by Jean-Christophe Filliâtre's avatar Jean-Christophe Filliâtre
Schorr-Waite algorithm: proof completed
parent 341e25cd
...@@ -7,14 +7,23 @@ ...@@ -7,14 +7,23 @@
Author: Mario Pereira (UBI, then Université Paris Sud) Author: Mario Pereira (UBI, then Université Paris Sud)
The proof below closely follows that of Rustan Leino with dafny, The code, specification, and invariants below follow those of
which is described in this paper: the following two proofs:
- Thierry Hubert and Claude Marché, using Caduceus and Coq
A case study of C source code verification: the Schorr-Waite algorithm.
SEFM 2005. http://www.lri.fr/~marche/hubert05sefm.ps
- Rustan Leino, using Dafny
Dafny: An Automatic Program Verifier for Functional Correctness.
LPAR-16.
http://research.microsoft.com/en-us/um/people/leino/papers/krml203.pdf http://research.microsoft.com/en-us/um/people/leino/papers/krml203.pdf
module SchorrWaite module SchorrWaite
(*use import bool.Bool*)
use import seq.Seq use import seq.Seq
use import map.Map use import map.Map
use import ref.Ref use import ref.Ref
...@@ -24,55 +33,72 @@ module SchorrWaite ...@@ -24,55 +33,72 @@ module SchorrWaite
use import list.Append use import list.Append
use import set.Fset as S use import set.Fset as S
(** a small component-as-array memory model *) (** Why3 has no support for arbitrary pointers,
so we introduce a small component-as-array memory model *)
(** the type of pointers and the null pointer *)
type loc type loc
constant null: loc constant null: loc
(** each (non-null) location holds four fields: two Boolean marks m and c
and two pointers left and right *)
val m: ref (map loc bool) val m: ref (map loc bool)
val c: ref (map loc bool) val c: ref (map loc bool)
val left: ref (map loc loc) val left: ref (map loc loc)
val right: ref (map loc loc) val right: ref (map loc loc)
(** record the path from the root to a node *)
val ghost path_from_root : ref (map loc (list loc))
val get_left (p: loc) : loc val get_left (p: loc) : loc
requires { p <> null } requires { p <> null }
ensures { result = !left[p] } ensures { result = !left[p] }
val get_right (p: loc) : loc
ensures { result = !right[p] }
val get_path_from_root (p : loc) : list loc
(*requires { p <> null } ---> maybe I don't need this pre-condition *)
ensures { result = !path_from_root[p] }
val set_left (p: loc) (v: loc) : unit val set_left (p: loc) (v: loc) : unit
writes { left } writes { left }
ensures { !left = set (old !left) p v } ensures { !left = set (old !left) p v }
val set_right (p: loc) (v: loc) : unit val set_right (p: loc) (v: loc) : unit
writes { right } writes { right }
ensures { !right = set (old !right) p v } ensures { !right = set (old !right) p v }
val get_m (p: loc) : bool
ensures { result = !m[p] }
val set_m (p: loc) (v: bool) : unit val set_m (p: loc) (v: bool) : unit
writes { m } writes { m }
ensures { !m = set (old !m) p v } ensures { !m = set (old !m) p v }
val get_c (p: loc) : bool
ensures { result = !c[p] }
val set_c (p: loc) (v: bool) : unit val set_c (p: loc) (v: bool) : unit
writes { c } writes { c }
ensures { !c = set (old !c) p v } ensures { !c = set (old !c) p v }
(** for the purpose of the proof, we add a fifth, ghost, field,
which records the path from the root (when relevant) *)
val set_path_from_root (p: loc) (l : list loc) : unit val set_path_from_root (p: loc) (l : list loc) : unit
writes { path_from_root } writes { path_from_root }
ensures { !path_from_root = set (old !path_from_root) p l } ensures { !path_from_root = set (old !path_from_root) p l }
(** Stack of nodes, from the root to the current location, in
reverse order (i.e. the current location is the first element
in the stack) *)
type stacknodes = Seq.seq loc type stacknodes = Seq.seq loc
predicate not_in_stack (n: loc) (s: stacknodes) = predicate not_in_stack (n: loc) (s: stacknodes) =
...@@ -81,25 +107,25 @@ module SchorrWaite ...@@ -81,25 +107,25 @@ module SchorrWaite
let tl_stackNodes (stack: stacknodes) : stacknodes let tl_stackNodes (stack: stacknodes) : stacknodes
requires { Seq.length stack > 0 } requires { Seq.length stack > 0 }
ensures { result = stack[1 .. ] } ensures { result = stack[1 .. ] }
* the following post-condition is usefull to prove the
* invariant that stackNodes' elements are also graph elements
* for the push case. An equivalent lemma would say:
* lemma mem_tl : forall x : 'a, l : list 'a. mem x l -> mem x (tl l)
ensures { forall n. not_in_stack n stack -> not_in_stack n result } ensures { forall n. not_in_stack n stack -> not_in_stack n result }
stack[1 .. ] stack[1 .. ]
(* usefull to prove that right field of every node out of the stack (** two lemmas about stacks *)
remains the same after the push case *)
lemma cons_not_in: forall s: stacknodes, n t: loc. (*?????*) let lemma cons_not_in (s: stacknodes) (n t: loc)
Seq.length s > 0 -> requires { not_in_stack n (cons t s) }
not_in_stack n (cons t s) -> not_in_stack n s ensures { not_in_stack n s }
assert { forall i: int. 0 <= i < Seq.length s ->
Seq.get s i = Seq.get (cons t s) (i+1) }
lemma tl_cons: forall s1 s2: stacknodes, p: loc. let lemma tl_cons (s1 s2: stacknodes) (p: loc)
Seq.length s2 > 0 -> requires { Seq.length s2 > 0 }
s1 = s2[1 ..] -> p = Seq.get s2 0 -> s2 = cons p s1 requires { s1 = s2[1 ..] }
requires { p = Seq.get s2 0 }
ensures { s2 = cons p s1 }
= assert { Seq.(==) s2 (cons p s1) }
function last (s: stacknodes) : loc = function last (s: stacknodes) : loc =
Seq.get s (Seq.length s - 1) Seq.get s (Seq.length s - 1)
...@@ -108,6 +134,8 @@ module SchorrWaite ...@@ -108,6 +134,8 @@ module SchorrWaite
forall i j. 0 <= i < Seq.length s -> 0 <= j < Seq.length s -> i <> j -> forall i j. 0 <= i < Seq.length s -> 0 <= j < Seq.length s -> i <> j ->
Seq.get s i <> Seq.get s j Seq.get s i <> Seq.get s j
(** Paths *)
predicate edge (x y : loc) (left right : map loc loc) = predicate edge (x y : loc) (left right : map loc loc) =
x <> null /\ (left[x] = y \/ right[x] = y) x <> null /\ (left[x] = y \/ right[x] = y)
...@@ -129,81 +157,48 @@ module SchorrWaite ...@@ -129,81 +157,48 @@ module SchorrWaite
| _ -> () | _ -> ()
end end
(* the two following lemmas help proving the assertion in the push case *)
lemma path_edge : forall x y : loc, left right : map loc loc. lemma path_edge : forall x y : loc, left right : map loc loc.
edge x y left right -> path left right x y (Cons x Nil) edge x y left right -> path left right x y (Cons x Nil)
(* TODO: choose between reachable_via and path *)
predicate reachable_via (x y : loc) (l r : map loc loc) (p : list loc) =
path l r x y p
lemma path_edge_cons: lemma path_edge_cons:
forall n x y : loc, left right : map loc loc, pth : list loc. forall n x y : loc, left right : map loc loc, pth : list loc.
reachable_via n x left right pth -> edge x y left right -> path left right n x pth -> edge x y left right ->
reachable_via n y left right (pth ++ (Cons x Nil)) path left right n y (pth ++ (Cons x Nil))
predicate reachable (x y : loc) (l r : map loc loc) = predicate reachable (left right: map loc loc) (x y : loc) =
exists p : list loc. reachable_via x y l r p exists p : list loc. path left right x y p
(* auxiliary function the define the form of a stack *) (** Schorr-Waite algorithm *)
function next (l r : map loc loc) (c : map loc bool) (p : loc) : loc =
if c[p] then r[p] else l[p]
inductive stack_form
(l r : map loc loc) (c : map loc bool) (p : loc) (stack : stacknodes) =
| stack_nil:
forall l r : map loc loc, c : map loc bool, p : loc.
stack_form l r c p Seq.empty
| stack_cons :
forall l r : map loc loc, c : map loc bool, p : loc, s : stacknodes.
stack_form l r c (next l r c p) s ->
stack_form l r c p (Seq.cons p s)
predicate pair_in_list (p1 p2 : loc) (l : list loc) =
match l with
| Cons b (Cons c _ as m) -> (b = p1 /\ c = p2) \/ pair_in_list p1 p2 m
| _ -> false
let schorr_waite (root: loc) (ghost graph : set loc) : unit let schorr_waite (root: loc) (ghost graph : set loc) : unit
requires { root <> null /\ S.mem root graph } requires { root <> null /\ S.mem root graph }
(* what is set S --> closed under children of all vertices *) (* graph is closed under left and right *)
requires { forall n : loc. S.mem n graph -> requires { forall n : loc. S.mem n graph ->
n <> null /\ (* is this ok? won't this be a contradiction? *) n <> null /\
S.mem !left[n] graph /\ S.mem !left[n] graph /\
S.mem !right[n] graph } S.mem !right[n] graph }
(* graph starts with nothing marked and no child currently visited *) (* graph starts with nothing marked *)
requires { forall x : loc. x <> null -> S.mem x graph -> requires { forall x : loc. S.mem x graph -> not !m[x] }
not !m[x] /\ not !c[x] } (* the structure of the graph is not changed *)
(* the structure of the graph is not changed ensures { forall n : loc. S.mem n graph ->
TODO? actually, nothing is changed *)
ensures { forall n : loc. S.mem n graph -> n <> null ->
(old !left)[n] = !left[n] /\ (old !left)[n] = !left[n] /\
(old !right)[n] = !right[n] } (old !right)[n] = !right[n] }
(* all the non-null vertices reachable from root (* all the non-null vertices reachable from root
are marked at the end of the algorithm, and only these *) are marked at the end of the algorithm, and only these *)
(* update: following Leino's paper, I will specify that all reachable nodes ensures { forall n : loc. S.mem n graph -> !m[n] ->
* are marked as a transitive property, rather than using reachability *) reachable (old !left) (old !right) root n }
ensures { forall n : loc. S.mem n graph -> n <> null -> !m[n] ->
reachable root n (old !left) (old !right) }
ensures { !m[root] } ensures { !m[root] }
ensures { forall n : loc. S.mem n graph -> n <> null -> !m[n] -> ensures { forall n : loc. S.mem n graph -> !m[n] ->
(forall ch : loc. edge n ch !left !right -> ch <> null -> !m[ch]) } (forall ch : loc. edge n ch !left !right -> ch <> null -> !m[ch]) }
(* FIXME: remove unnecessary n<>null above *)
= 'Init: = 'Init:
let t = ref root in let t = ref root in
let p = ref null in let p = ref null in
let ghost stackNodes = ref Seq.empty in let ghost stackNodes = ref Seq.empty in
let ghost pth = ref Nil in let ghost pth = ref Nil in
set_path_from_root !t !pth; ghost set_path_from_root !t !pth;
let ghost unmarked_nodes = ref graph in let ghost unmarked_nodes = ref graph in
let ghost c_false_nodes = ref graph in let ghost c_false_nodes = ref graph in
while !p <> null || (!t <> null && not !m[!t]) do while !p <> null || (!t <> null && not get_m !t) do
invariant { forall n. mem n graph -> not_in_stack n !stackNodes \/ invariant { forall n. mem n graph -> not_in_stack n !stackNodes \/
exists i : int. Seq.get !stackNodes i = n } exists i : int. Seq.get !stackNodes i = n }
invariant { not_in_stack null !stackNodes } invariant { not_in_stack null !stackNodes }
...@@ -211,21 +206,24 @@ module SchorrWaite ...@@ -211,21 +206,24 @@ module SchorrWaite
invariant { S.mem !t graph } invariant { S.mem !t graph }
invariant { !p <> null -> S.mem !p graph } invariant { !p <> null -> S.mem !p graph }
invariant { Seq.length !stackNodes <> 0 -> Seq.get !stackNodes 0 = !p } invariant { Seq.length !stackNodes <> 0 -> Seq.get !stackNodes 0 = !p }
invariant { forall n : loc. S.mem n graph /\ n <> null /\ not !m[n] -> S.mem n !unmarked_nodes } invariant { forall n : loc. S.mem n graph -> not !m[n] ->
invariant { forall n : loc. S.mem n graph /\ n <> null /\ not !c[n] -> S.mem n !c_false_nodes } S.mem n !unmarked_nodes }
invariant { forall i. 0 <= i < Seq.length !stackNodes -> S.mem (Seq.get !stackNodes i) graph } invariant { forall n : loc. S.mem n graph -> not !c[n] ->
invariant { forall i. 0 <= i < Seq.length !stackNodes - 1 -> invariant { forall i. 0 <= i < Seq.length !stackNodes - 1 ->
let p1 = Seq.get !stackNodes i in let p2 = Seq.get !stackNodes (i+1) in let p1 = Seq.get !stackNodes i in
(!c[p2] -> (at !left 'Init)[p2] = !left[p2] /\ (at !right 'Init)[p2] = p1) /\ let p2 = Seq.get !stackNodes (i+1) in
(not !c[p2] -> (at !left 'Init)[p2] = p1 /\ (at !right 'Init)[p2] = !right[p2]) } (!c[p2] -> (at !left 'Init)[p2] = !left[p2] /\
invariant { !path_from_root[root] = Nil } invariant { !path_from_root[root] = Nil }
(*invariant { not L.mem !t !stackNodes }*) (* this will be usefull to prove that !t is in graph after the push ---> but this is false! think of the case when the graph is cyclic *) invariant { forall n : loc. S.mem n graph ->
(* I4d from Hubert and Marché's paper and something related to line 63-65 from Leino's *)
invariant { forall n : loc. S.mem n graph -> (*n <> null -> *)
not_in_stack n !stackNodes -> not_in_stack n !stackNodes ->
!left[n] = (at !left 'Init)[n] /\ !right[n] = (at !right 'Init)[n] } !left[n] = (at !left 'Init)[n] /\
(* I4a from Hubert and Marché's paper; useful to prove that !stackNodes = !p::... *) !right[n] = (at !right 'Init)[n] }
(* invariant { stack_form !left !right !c !p !stackNodes } *)
(* something like Leino's line 74; this is useful to prove that (* something like Leino's line 74; this is useful to prove that
* the stack is empty iff p = null *) * the stack is empty iff p = null *)
invariant { Seq.length !stackNodes <> 0 -> invariant { Seq.length !stackNodes <> 0 ->
...@@ -233,109 +231,91 @@ module SchorrWaite ...@@ -233,109 +231,91 @@ module SchorrWaite
if !c[first] then !right[first] = null if !c[first] then !right[first] = null
else !left[first] = null } else !left[first] = null }
invariant { Seq.length !stackNodes <> 0 -> last !stackNodes = root } invariant { Seq.length !stackNodes <> 0 -> last !stackNodes = root }
(* something like lines 75-76 from Leino's paper --> with this invariant I believe there (* something like lines 75-76 from Leino's paper *)
* is no need to use 'stack_form' *)
invariant { forall k : int. 0 <= k < Seq.length !stackNodes - 1 -> invariant { forall k : int. 0 <= k < Seq.length !stackNodes - 1 ->
if !c[Seq.get !stackNodes k] if !c[Seq.get !stackNodes k]
then !right[Seq.get !stackNodes k] = Seq.get !stackNodes (k+1) then !right[Seq.get !stackNodes k] = Seq.get !stackNodes (k+1)
else !left [Seq.get !stackNodes k] = Seq.get !stackNodes (k+1) } else !left [Seq.get !stackNodes k] = Seq.get !stackNodes (k+1) }
(* all nodes in the stack are marked ---> I4a from Hubert and Marché's paper (* all nodes in the stack are marked
* and something alike line 57 from Leino's paper *) * (I4a in Hubert and Marché and something alike line 57 in Leino) *)
invariant { forall i. 0 <= i < Seq.length !stackNodes -> !m[Seq.get !stackNodes i] } invariant { forall i. 0 <= i < Seq.length !stackNodes ->
(* stack has no duplicates ---> line 55 from Leino's paper *) (* stack has no duplicates ---> line 55 from Leino's paper *)
invariant { distinct !stackNodes } invariant { distinct !stackNodes }
(* something like Leino's line 68; I believe this is useful to prove (* something like Leino's line 68 *)
* that in the pop case the left child of p is the initial one *)
invariant { forall i. 0 <= i < Seq.length !stackNodes -> invariant { forall i. 0 <= i < Seq.length !stackNodes ->
let n = Seq.get !stackNodes i in let n = Seq.get !stackNodes i in
if !c[n] then !left[n] = (at !left 'Init)[n] if !c[n] then !left[n] = (at !left 'Init)[n]
else !right[n] = (at !right 'Init)[n] } else !right[n] = (at !right 'Init)[n] }
(* lines 80-81 from Leino's paper *) (* lines 80-81 from Leino's paper *)
invariant { Seq.length !stackNodes <> 0 -> if !c[!p] then (at !right 'Init)[!p] = !t invariant { Seq.length !stackNodes <> 0 ->
else (at !left 'Init)[!p] = !t } else (at !left 'Init)[!p] = !t }
(* lines 78-79 from Leino's paper *) (* lines 78-79 from Leino's paper *)
invariant { forall k : int. 0 < k < Seq.length !stackNodes -> invariant { forall k : int. 0 < k < Seq.length !stackNodes ->
let n = Seq.get !stackNodes k in let n = Seq.get !stackNodes k in
if !c[n] then Seq.get !stackNodes (k - 1) = (at !right 'Init)[n] if !c[n]
else Seq.get !stackNodes (k - 1) = (at !left 'Init)[n] } else Seq.get !stackNodes (k - 1) = (at !left 'Init)[n] }
(* help establishing the next invariant for the push case --> (* line 70 from Leino's paper *)
* line 70 from Leino's paper *) invariant { !p <> null ->
invariant { !p <> null -> reachable_via root !p (at !left 'Init) (at !right 'Init) !pth } path (at !left 'Init) (at !right 'Init) root !p !pth }
(* line 72 from Leino's paper --> used to prove the post that very marked node was (* line 72 from Leino's paper *)
* reachable from 'root' in the pre-state *) invariant { forall n : loc. S.mem n graph -> !m[n] ->
invariant { forall n : loc. S.mem n graph /\ !m[n] /\ n <> null -> reachable (at !left 'Init) (at !right 'Init) root n }
reachable root n (at !left 'Init) (at !right 'Init) }
(* help establishing the previous invariant when p = null, ie
* for the firts push of the loop *)
invariant { !p = null -> !t = root } invariant { !p = null -> !t = root }
(* help establishing the previous invariant for the pop case --> (* line 70 from Leino's paper *)
invariant { forall n : loc, pth : list loc. invariant { forall n : loc, pth : list loc.
S.mem n graph /\ n <> null /\ !m[n] /\ pth = !path_from_root[n] -> S.mem n graph -> !m[n] ->
reachable_via root n (at !left 'Init) (at !right 'Init) pth } pth = !path_from_root[n] ->
(* lines 61-62 from Leinos' paper --> help establish the post that path (at !left 'Init) (at !right 'Init) root n pth }
* all nodes reachable from root are marked *) (* lines 61-62 from Leinos' paper *)
invariant { forall n : loc. S.mem n graph -> n <> null -> !m[n] -> invariant { forall n : loc. S.mem n graph -> n <> null -> !m[n] ->
(*n <> !t*) (*---> do I really need this 'n <> !t'? *)
(*(forall ch : loc. edge n ch !left !right /\ ch <> null -> !m[ch]) }*)
(!left[n] <> null -> !m[!left[n]]) /\ (!left[n] <> null -> !m[!left[n]]) /\
(!right[n] <> null -> !m[!right[n]]) } (!right[n] <> null -> !m[!right[n]]) }
(* help establishing the previous invariant for the pop case ---> (* something like Leino's lines 57-59 *)
!c[n] -> !c[n] ->
(* (forall ch : loc. edge n ch !left !right /\ ch <> null -> !m[ch]) } *)
(* termination proved using lexicographic order over a triple *) (* termination proved using lexicographic order over a triple *)
variant { S.cardinal !unmarked_nodes, variant { S.cardinal !unmarked_nodes,
S.cardinal !c_false_nodes, S.cardinal !c_false_nodes,
Seq.length !stackNodes } Seq.length !stackNodes }
if !t = null || !m[!t] then begin if !t = null || get_m !t then begin
if !c[!p] then begin (* pop *) if get_c !p then begin (* pop *)
let q = !t in let q = !t in
t := !p; t := !p;
assert { !p = Seq.get !stackNodes 0 }; ghost stackNodes := tl_stackNodes !stackNodes;
assert { Seq.length !stackNodes > 0 };
assert { not_in_stack !p !stackNodes }; assert { not_in_stack !p !stackNodes };
p := !right[!p]; p := !right[!p];
assert { !p = Seq.get !stackNodes 0 \/ !p = null }; assert { !p = Seq.get !stackNodes 0 \/ !p = null };
set_right !t q; set_right !t q;
pth := get_path_from_root !p; ghost pth := get_path_from_root !p;
end else begin (* swing *) end else begin (* swing *)
(* the following assertion is automatically discharged
* and it is useful to prove that t is in the set graph *)
(* assert { pair_in_list !t !p (Seq.cons !t !stackNodes) }; *)
t := get_right !p; t := get_right !p;
set_right !p (get_left !p); set_right !p (get_left !p);
set_left !p q; set_left !p q;
c_false_nodes := S.remove !p !c_false_nodes; ghost c_false_nodes := S.remove !p !c_false_nodes;
set_c !p true; set_c !p true;
end end
end else begin (* push *) end else begin (* push *)
let q = !p in let q = !p in
(*if !p <> null then pth := !pth ++ (Cons q Nil);*)
p := !t; p := !t;
stackNodes := Seq.cons !p !stackNodes; ghost stackNodes := Seq.cons !p !stackNodes;
t := get_left !t; t := get_left !t;
set_m !p true; set_m !p true;
if !p <> root then pth := !pth ++ (Cons q Nil) else pth := Nil; ghost if !p <> root then pth := !pth ++ (Cons q Nil) else pth := Nil;
set_path_from_root !p !pth; ghost set_path_from_root !p !pth;
(* this is assertion is automatically discharged and it helps
* proving that all marked nodes are reachable from root *)
assert { !p = Seq.get !stackNodes 0 }; assert { !p = Seq.get !stackNodes 0 };
assert { path (at !left 'Init) (at !right 'Init) root !p !pth }; assert { path (at !left 'Init) (at !right 'Init) root !p !pth };
set_c !p false; (* update: explicitly changing !c[p] to false and adding it to the set_c !p false;
* set of false nodes (even if it is already there) helps in proving ghost c_false_nodes := S.add !p !c_false_nodes;
* the invariant that all nodes in the stack with !c=1 have their ghost unmarked_nodes := S.remove !p !unmarked_nodes
* children marked *)
end end
done done
