Commit 6791bf05 authored by Andrei Paskevich's avatar Andrei Paskevich
some minor additions
parent ff1489d7
...@@ -105,6 +105,12 @@ module Ty = struct ...@@ -105,6 +105,12 @@ module Ty = struct
let ty_exists pr ty = let ty_exists pr ty =
try ty_fold (exists_fn pr) false ty with FoldSkip -> true try ty_fold (exists_fn pr) false ty with FoldSkip -> true
(* set of free type variables *)
let rec ty_vars acc ty = match ty.ty_node with
| Tyvar u -> Name.S.add u acc
| _ -> ty_fold ty_vars acc ty
(* smart constructors *) (* smart constructors *)
exception BadTypeArity exception BadTypeArity
...@@ -660,14 +666,14 @@ let f_subst m f = let _ = Mvs.iter vt_check m in f_subst m 0 f ...@@ -660,14 +666,14 @@ let f_subst m f = let _ = Mvs.iter vt_check m in f_subst m 0 f
(* set of free variables *) (* set of free variables *)
let rec t_freevars lvl acc t = match t.t_node with let rec t_vars lvl acc t = match t.t_node with
| Tvar u -> Svs.add u acc | Tvar u -> Svs.add u acc
| _ -> t_fold_unsafe t_freevars f_freevars lvl acc t | _ -> t_fold_unsafe t_vars f_vars lvl acc t
and f_freevars lvl acc t = f_fold_unsafe t_freevars f_freevars lvl acc t and f_vars lvl acc t = f_fold_unsafe t_vars f_vars lvl acc t
let t_freevars t = t_freevars 0 Svs.empty t let t_vars s t = t_vars 0 s t
let f_freevars f = f_freevars 0 Svs.empty f let f_vars s f = f_vars 0 s f
(* USE PHYSICAL EQUALITY *) (* USE PHYSICAL EQUALITY *)
...@@ -1017,35 +1023,32 @@ let f_app p tl = ...@@ -1017,35 +1023,32 @@ let f_app p tl =
in in
f_app p tl f_app p tl
let varmap_for_pattern p = let pat_varmap p =
let i = ref (-1) in let i = ref (-1) in
let rec make acc p = match p.pat_node with let rec mk_map acc p = match p.pat_node with
| Pwild ->
acc
| Pvar n -> | Pvar n ->
assert (not (Mvs.mem n acc)); if Mvs.mem n acc then raise NonLinearPattern;
incr i; Mvs.add n !i acc incr i; Mvs.add n !i acc
| Papp (_, pl) ->
List.fold_left make acc pl
| Pas (p, n) -> | Pas (p, n) ->
incr i; make (Mvs.add n !i acc) p incr i; mk_map (Mvs.add n !i acc) p
| _ -> pat_fold mk_map acc p
in in
let m = make Mvs.empty p in let m = mk_map Mvs.empty p in
m, !i + 1 m, !i + 1
let t_case t bl ty = let t_case t bl ty =
let t_make_branch (p, tbr) = let t_make_branch (p, tbr) =
if tbr.t_ty != ty then raise Ty.TypeMismatch else if tbr.t_ty != ty then raise Ty.TypeMismatch else
if p.pat_ty != t.t_ty then raise Ty.TypeMismatch else if p.pat_ty != t.t_ty then raise Ty.TypeMismatch else
let m, nv = varmap_for_pattern p in (p, nv, t_abst m 0 tbr) let m, nv = pat_varmap p in (p, nv, t_abst m 0 tbr)
in in
t_case t (List.map t_make_branch bl) ty t_case t (List.map t_make_branch bl) ty
let f_case t bl = let f_case t bl =
let f_make_branch (p, fbr) = let f_make_branch (p, fbr) =
let m, nv = varmap_for_pattern p in (p, nv, f_abst m 0 fbr) let m, nv = pat_varmap p in (p, nv, f_abst m 0 fbr)
in in
f_case t (List.map f_make_branch bl) f_case t (List.map f_make_branch bl)
...@@ -1058,18 +1061,12 @@ let f_open_bound (v, f) = ...@@ -1058,18 +1061,12 @@ let f_open_bound (v, f) =
let v = fresh_vsymbol v in v, f_inst_single v f let v = fresh_vsymbol v in v, f_inst_single v f
let rec pat_rename ns p = match p.pat_node with let rec pat_rename ns p = match p.pat_node with
| Pwild -> | Pvar n -> pat_var (Mvs.find n ns)
p | Pas (p, n) -> pat_as (pat_rename ns p) (Mvs.find n ns)
| Pvar n -> | _ -> pat_map_unsafe (pat_rename ns) p
(try pat_var (Mvs.find n ns) with Not_found -> assert false)
| Papp (f, pl) -> let pat_substs pat =
pat_app f (List.map (pat_rename ns) pl) p.pat_ty let m, _ = pat_varmap pat in
| Pas (p, n) ->
(try Mvs.find n ns with Not_found -> assert false)
let substs_for_pattern pat =
let m, _ = varmap_for_pattern pat in
Mvs.fold Mvs.fold
(fun x i (vars, s, ns) -> (fun x i (vars, s, ns) ->
let x' = fresh_vsymbol x in let x' = fresh_vsymbol x in
...@@ -1078,11 +1075,11 @@ let substs_for_pattern pat = ...@@ -1078,11 +1075,11 @@ let substs_for_pattern pat =
(Svs.empty, Im.empty, Mvs.empty) (Svs.empty, Im.empty, Mvs.empty)
let t_open_branch (pat, _, t) = let t_open_branch (pat, _, t) =
let vars, s, ns = substs_for_pattern pat in let vars, s, ns = pat_substs pat in
(pat_rename ns pat, vars, t_inst s 0 t) (pat_rename ns pat, vars, t_inst s 0 t)
let f_open_branch (pat, _, f) = let f_open_branch (pat, _, f) =
(pat_rename ns pat, vars, f_inst s 0 f) (pat_rename ns pat, vars, f_inst s 0 f)
(* safe opening map *) (* safe opening map *)
...@@ -47,6 +47,9 @@ module Ty : sig ...@@ -47,6 +47,9 @@ module Ty : sig
val ty_map : (ty -> ty) -> ty -> ty val ty_map : (ty -> ty) -> ty -> ty
val ty_fold : ('a -> ty -> 'a) -> 'a -> ty -> 'a val ty_fold : ('a -> ty -> 'a) -> 'a -> ty -> 'a
val ty_forall : (ty -> bool) -> ty -> bool
val ty_exists : (ty -> bool) -> ty -> bool
val ty_vars : Name.S.t -> ty -> Name.S.t
val ty_match : ty -> ty -> ty Name.M.t -> ty Name.M.t option val ty_match : ty -> ty -> ty Name.M.t -> ty Name.M.t option
...@@ -113,6 +116,8 @@ val pat_as : pattern -> vsymbol -> pattern ...@@ -113,6 +116,8 @@ val pat_as : pattern -> vsymbol -> pattern
val pat_map : (pattern -> pattern) -> pattern -> pattern val pat_map : (pattern -> pattern) -> pattern -> pattern
val pat_fold : ('a -> pattern -> 'a) -> 'a -> pattern -> 'a val pat_fold : ('a -> pattern -> 'a) -> 'a -> pattern -> 'a
val pat_forall : (pattern -> bool) -> pattern -> bool
val pat_exists : (pattern -> bool) -> pattern -> bool
val pat_equal_alpha : pattern -> pattern -> bool val pat_equal_alpha : pattern -> pattern -> bool
...@@ -263,8 +268,8 @@ val f_subst_single : vsymbol -> term -> fmla -> fmla ...@@ -263,8 +268,8 @@ val f_subst_single : vsymbol -> term -> fmla -> fmla
val t_freevars : term -> Svs.t val t_vars : Svs.t -> term -> Svs.t
val f_freevars : fmla -> Svs.t val f_vars : Svs.t -> fmla -> Svs.t
