GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
66b79960
66b79960
MARCHE Claude
Strategies: steplimit is not meaningfull -> removed
f64a0c8a
5
src/ide/gmain.ml
66b79960
@@ -1530,6 +1530,7 @@ let split_strategy =
let
inline_strategy
let
inline_strategy
Strategy
Itransform
inline_transformation
Strategy
Itransform
let test_strategy () =
let config = gconfig.Gconfig.config in
let altergo =
let altergo =
@@ -1541,12 +1542,13 @@ let test_strategy () =
Whyconf.filter_one_prover config fp
in
in
Strategy
Icall_prover
altergo
Whyconf
prover
1000
Strategy.Icall_prover(altergo.Whyconf.prover,1,1000);
Strategy
Icall_prover
cvc4
Whyconf
prover
Strategy.Icall_prover(cvc4.Whyconf.prover,1,1000);
Strategy.Itransform(split_transformation,0); (* goto 0 on success *)
Strategy
Icall_prover
altergo
Whyconf
prover
10
4000
Strategy.Icall_prover(altergo.Whyconf.prover,10,4000);
Strategy
Icall_prover
cvc4
Whyconf
prover
10
4000
Strategy.Icall_prover(cvc4.Whyconf.prover,10,4000);
let strategies () :
let strategies () :
src/session/session_scheduler.ml
66b79960
@@ -940,7 +940,7 @@ let convert_unknown_prover =
Todo
_done
todo
Todo
_done
todo
else
else
match
Array
get
strat
pc
match
Array
get
strat
pc
Icall_prover
p
timelimit
steplimit
memlimit
Icall_prover
p
timelimit
memlimit
let
callback
_pa
res
let
callback
_pa
res
match
res
match
res
Scheduled
Running
Scheduled
Running
@@ -957,7 +957,7 @@ let convert_unknown_prover =
(* should not happen *)
assert
false
assert
false
in
in
prover_on_goal
es
sched
callback
timelimit
steplimit
memlimit
p
g
prover_on_goal
es
sched
callback
timelimit
steplimit
memlimit
p
g
Itransform
trname
pcsuccess
Itransform
trname
pcsuccess
let
callback
ntr
let
callback
ntr
match
ntr
match
ntr
src/session/strategy.ml
66b79960
@@ -12,7 +12,7 @@
@@ -12,7 +12,7 @@
(** {2 User-defined strategies} *)
type
instruction
type
instruction
Icall_prover
of
Whyconf
prover
int
int
int
(** timelimit,
steplimi,
memlimit *)
Icall_prover
of
Whyconf
prover
int
int
(** timelimit, memlimit *)
Itransform
of
string
int
(** successor state on success *)
Itransform
of
string
int
Igoto
of
int
(** goto state *)
Igoto
of
int
(** goto state *)
src/session/strategy.mli
66b79960
@@ -27,7 +27,7 @@
@@ -27,7 +27,7 @@
type
instruction
type
instruction
Icall_prover
of
Whyconf
prover
int
int
int
(** timelimit,
steplimi,
memlimit *)
Icall_prover
of
Whyconf
prover
int
int
Itransform
of
string
int
Itransform
of
string
int
Igoto
of
int
(** goto state *)
Igoto
of
int
(** goto state *)
src/session/strategy_parser.mll
66b79960
@@ -120,15 +120,13 @@ rule scan code = parse
goto
space
ident
as
id
goto
space
ident
as
id
add_instr
code
Igoto
find_label
code
id
add_instr
code
Igoto
find_label
code
id
scan
code
lexbuf
scan
code
lexbuf
call
space
ident
as
p
space
integer
as
t
space
integer
as
s
space
integer
as
m
call
space
ident
as
p
space
integer
as
t
space
integer
as
m
let
p
prover
code
p
in
let
p
prover
code
p
in
let
t
integer
"timelimit"
t
in
let
t
integer
"timelimit"
t
in
if
t
then
error
"timelimit %d is invalid"
t
if
t
then
error
t
let
s
integer
"steplimit"
s
in
if
s
then
error
"steplimit %d is invalid"
s
let
m
integer
"memlimit"
m
in
let
m
integer
"memlimit"
m
in
if
m
then
error
"memlimit %d is invalid"
m
if
m
then
error
m
add_instr
code
Icall_prover
p
Whyconf
prover
t
s
m
add_instr
code
Icall_prover
p
Whyconf
prover
t
m
scan
code
lexbuf
scan
code
lexbuf
transform
space
ident
as
t
space
ident
as
l
transform
space
ident
as
t
space
ident
as
l
transform
code
t
transform
code
t
Supports
