Commit 659597a2 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Ensure that tool pictures are centered in the HTML documentation.
parent 90a9ab7a
...@@ -34,6 +34,7 @@ friendly way. This section presents the basic use of this GUI. Please ...@@ -34,6 +34,7 @@ friendly way. This section presents the basic use of this GUI. Please
refer to Section~\ref{sec:ideref} for a more complete description. refer to Section~\ref{sec:ideref} for a more complete description.
\begin{figure}[tbp] \begin{figure}[tbp]
%HEVEA\centering
\includegraphics[width=\textwidth]{gui-0-70-1.png} \includegraphics[width=\textwidth]{gui-0-70-1.png}
\caption{The GUI when started the very first time} \caption{The GUI when started the very first time}
\label{fig:gui1} \label{fig:gui1}
...@@ -65,6 +66,7 @@ contains one theory, itself containg three goals. ...@@ -65,6 +66,7 @@ contains one theory, itself containg three goals.
%HEVEA\centering
\includegraphics[width=\textwidth]{gui-0-70-2.png} \includegraphics[width=\textwidth]{gui-0-70-2.png}
\caption{The GUI with goal G1 selected} \caption{The GUI with goal G1 selected}
\label{fig:gui2} \label{fig:gui2}
...@@ -87,6 +89,7 @@ click on the \textsf{Simplify} button. After a short time, you should ...@@ -87,6 +89,7 @@ click on the \textsf{Simplify} button. After a short time, you should
get the display of Figure~\ref{fig:gui3}. get the display of Figure~\ref{fig:gui3}.
%HEVEA\centering
\includegraphics[width=\textwidth]{gui-0-70-3.png} \includegraphics[width=\textwidth]{gui-0-70-3.png}
\caption{The GUI after Simplify prover is run on each goal} \caption{The GUI after Simplify prover is run on each goal}
\label{fig:gui3} \label{fig:gui3}
...@@ -112,6 +115,7 @@ Simplify. We already have a lot of goals and proof attempts, so it is a good ide ...@@ -112,6 +115,7 @@ Simplify. We already have a lot of goals and proof attempts, so it is a good ide
You should see now what is displayed on Figure~\ref{fig:gui4}. You should see now what is displayed on Figure~\ref{fig:gui4}.
%HEVEA\centering
\includegraphics[width=\textwidth]{gui-0-70-4.png} \includegraphics[width=\textwidth]{gui-0-70-4.png}
\caption{The GUI after splitting goal $G_2$ and collapsing proved goals} \caption{The GUI after splitting goal $G_2$ and collapsing proved goals}
\label{fig:gui4} \label{fig:gui4}
...@@ -133,6 +137,7 @@ part you modify, in order to regenerate the file if the goal is ...@@ -133,6 +137,7 @@ part you modify, in order to regenerate the file if the goal is
changed. changed.
%HEVEA\centering
\includegraphics[width=\textwidth]{coqide-0-70.png} \includegraphics[width=\textwidth]{coqide-0-70.png}
\caption{CoqIDE on subgoal 1 of $G_2$} \caption{CoqIDE on subgoal 1 of $G_2$}
\label{fig:coqide} \label{fig:coqide}
...@@ -154,6 +159,7 @@ false, \eg ...@@ -154,6 +159,7 @@ false, \eg
We can reload the modified file in the IDE using menu \textsf{File/Reload}, or the shortcut ``Ctrl-R''. We get the tree view shown on Figure~\ref{fig:gui5}. We can reload the modified file in the IDE using menu \textsf{File/Reload}, or the shortcut ``Ctrl-R''. We get the tree view shown on Figure~\ref{fig:gui5}.
%HEVEA\centering
\includegraphics[width=\textwidth]{gui-0-70-5.png} \includegraphics[width=\textwidth]{gui-0-70-5.png}
\caption{File reloaded after modifying goal $G_2$} \caption{File reloaded after modifying goal $G_2$}
\label{fig:gui5} \label{fig:gui5}
...@@ -183,7 +189,7 @@ Notice that replaying can be done in batch mode, using the ...@@ -183,7 +189,7 @@ Notice that replaying can be done in batch mode, using the
\texttt{why3replayer} tool (see Section~\ref{sec:why3replayer}) For \texttt{why3replayer} tool (see Section~\ref{sec:why3replayer}) For
example, running the replayer on the \texttt{hello\_proof} example is example, running the replayer on the \texttt{hello\_proof} example is
as follows (assuming $G_2$ still is as follows (assuming $G_2$ still is
\lstinline{(true -> false) /\ (true \/ false)}). \lstinline|(true -> false) /\ (true \/ false)|).
\begin{verbatim} \begin{verbatim}
$ why3replayer hello_proof $ why3replayer hello_proof
Info: found directory 'hello_proof' for the project Info: found directory 'hello_proof' for the project
