Commit 64d9baaa authored by David Hauzar's avatar David Hauzar
Getting type part of model element name from model_trace label.
parent a78178fb
...@@ -112,17 +112,16 @@ type model_element = { ...@@ -112,17 +112,16 @@ type model_element = {
me_text_info: bool; me_text_info: bool;
let split_me_name name = let split_model_trace_name mt_name =
let splitted = Str.bounded_split (Str.regexp_string "@") name 2 in (** Mt_name is of the form "name[@type[@*]]". Return (name, type) *)
let splitted = Str.bounded_split (Str.regexp_string "@") mt_name 3 in
match splitted with match splitted with
| [first] -> (first, "") | [first] -> (first, "")
| [first;second] -> | first::second::_ -> (first, second)
(first, second) | [] -> ("", "")
| _ -> (* here, "_" can only stand for [] *)
let create_model_element ~name ~value ?location ?term () = let create_model_element ~name ~value ?location ?term () =
let (name, type_s) = split_me_name name in let (name, type_s) = split_model_trace_name name in
let me_kind = match type_s with let me_kind = match type_s with
| "result" -> Result | "result" -> Result
| "old" -> Old | "old" -> Old
