Commit 64ccfa7d authored by Andrei Paskevich's avatar Andrei Paskevich
dot-syntax for application
parent d51304ee
...@@ -598,6 +598,24 @@ lexpr_arg: ...@@ -598,6 +598,24 @@ lexpr_arg:
{ mk_pp PPtrue } { mk_pp PPtrue }
| FALSE | FALSE
{ mk_pp PPfalse } { mk_pp PPfalse }
| OPPREF lexpr_arg
{ mk_pp (PPapp (Qident (mk_id (prefix $1) (loc_i 2)), [$2])) }
| lexpr_sub
{ $1 }
lexpr_dot:
| lqualid_rich
{ mk_pp (PPvar $1) }
| OPPREF lexpr_dot
| lexpr_sub
{ $1 }
lexpr_sub:
| lexpr_dot DOT lqualid
{ mk_pp (PPapp ($3, [$1])) }
| LEFTPAR lexpr RIGHTPAR | LEFTPAR lexpr RIGHTPAR
{ $2 } { $2 }
| LEFTPAR RIGHTPAR | LEFTPAR RIGHTPAR
...@@ -606,8 +624,6 @@ lexpr_arg: ...@@ -606,8 +624,6 @@ lexpr_arg:
{ mk_pp (PPtuple ($2 :: $4)) } { mk_pp (PPtuple ($2 :: $4)) }
| LEFTREC list1_field_value opt_semicolon RIGHTREC | LEFTREC list1_field_value opt_semicolon RIGHTREC
{ mk_pp (PPrecord (List.rev $2)) } { mk_pp (PPrecord (List.rev $2)) }
| OPPREF lexpr_arg
| lexpr_arg LEFTSQ lexpr RIGHTSQ | lexpr_arg LEFTSQ lexpr RIGHTSQ
{ mk_pp (PPapp (Qident (mk_id (misfix "[]") (loc ())), [$1; $3])) } { mk_pp (PPapp (Qident (mk_id (misfix "[]") (loc ())), [$1; $3])) }
| lexpr_arg LEFTSQ lexpr OP1 lexpr RIGHTSQ | lexpr_arg LEFTSQ lexpr OP1 lexpr RIGHTSQ
...@@ -834,6 +850,11 @@ tqualid: ...@@ -834,6 +850,11 @@ tqualid:
| any_qualid DOT uident { Qdot ($1, $3) } | any_qualid DOT uident { Qdot ($1, $3) }
lqualid_rich:
| lident_rich { Qident $1 }
| uqualid DOT lident_rich { Qdot ($1, $3) }
qualid: qualid:
| ident_rich { Qident $1 } | ident_rich { Qident $1 }
| uqualid DOT ident_rich { Qdot ($1, $3) } | uqualid DOT ident_rich { Qdot ($1, $3) }
...@@ -7,9 +7,11 @@ theory Records ...@@ -7,9 +7,11 @@ theory Records
use import bool.Bool use import bool.Bool
use import int.Int use import int.Int
namespace import R
type t 'a 'b = {| a : 'a; b : list 'b; |} type t 'a 'b = {| a : 'a; b : list 'b; |}
goal g1 : let t = {| b = Cons True Nil; a = 1; |} in a t = 1 goal g1 : let t = {| b = Cons True Nil; a = 1; |} in t.R.a = 1
end end
