Commit 648ecbd5 authored by Guillaume Melquiond's avatar Guillaume Melquiond
Fix most spurious or missing spaces in Coq output.
parent c7e3e0bf
...@@ -66,11 +66,6 @@ let print_ne_params fmt stv = ...@@ -66,11 +66,6 @@ let print_ne_params fmt stv =
(fun tv -> fprintf fmt "@ %a" print_implicit_tv_binder tv) (fun tv -> fprintf fmt "@ %a" print_implicit_tv_binder tv)
stv stv
let print_ne_params_list fmt ltv =
List.iter
(fun tv -> fprintf fmt "@ %a" print_tv_binder tv)
ltv
let print_params fmt stv = let print_params fmt stv =
if Stv.is_empty stv then () else if Stv.is_empty stv then () else
fprintf fmt "forall%a,@ " print_ne_params stv fprintf fmt "forall%a,@ " print_ne_params stv
...@@ -81,7 +76,7 @@ let print_implicit_params fmt stv = ...@@ -81,7 +76,7 @@ let print_implicit_params fmt stv =
let print_params_list fmt ltv = let print_params_list fmt ltv =
match ltv with match ltv with
| _ -> fprintf fmt "forall%a,@ " print_ne_params_list ltv | _ -> fprintf fmt "forall %a,@ " (print_list space print_tv_binder) ltv
let forget_tvs () = let forget_tvs () =
Sid.iter (forget_id iprinter) !tv_set; Sid.iter (forget_id iprinter) !tv_set;
...@@ -186,7 +181,6 @@ let print_paren_r fmt x = ...@@ -186,7 +181,6 @@ let print_paren_r fmt x =
let arrow fmt () = fprintf fmt "@ -> " let arrow fmt () = fprintf fmt "@ -> "
let print_arrow_list fmt x = print_list arrow fmt x let print_arrow_list fmt x = print_list arrow fmt x
let print_space_list fmt x = print_list space fmt x
let rec print_pat info fmt p = match p.pat_node with let rec print_pat info fmt p = match p.pat_node with
| Pwild -> fprintf fmt "_" | Pwild -> fprintf fmt "_"
...@@ -295,9 +289,9 @@ and print_tnode opl opr info fmt t = match t.t_node with ...@@ -295,9 +289,9 @@ and print_tnode opl opr info fmt t = match t.t_node with
then then
if tl = [] then fprintf fmt "%a" (print_ls_real info) fs if tl = [] then fprintf fmt "%a" (print_ls_real info) fs
else fprintf fmt "(%a %a)" (print_ls_real info) fs else fprintf fmt "(%a %a)" (print_ls_real info) fs
(print_space_list (print_term info)) tl (print_list space (print_term info)) tl
else fprintf fmt (protect_on opl "(%a %a:%a)") (print_ls_real info) fs else fprintf fmt (protect_on opl "(%a %a:%a)") (print_ls_real info) fs
(print_space_list (print_term info)) tl (print_ty info) (t_type t) (print_list space (print_term info)) tl (print_ty info) (t_type t)
end end
| Tquant _ | Tbinop _ | Tnot _ | Ttrue | Tfalse -> raise (TermExpected t) | Tquant _ | Tbinop _ | Tnot _ | Ttrue | Tfalse -> raise (TermExpected t)
...@@ -305,7 +299,7 @@ and print_fnode opl opr info fmt f = match f.t_node with ...@@ -305,7 +299,7 @@ and print_fnode opl opr info fmt f = match f.t_node with
| Tquant (Tforall,fq) -> | Tquant (Tforall,fq) ->
let vl,_tl,f = t_open_quant fq in let vl,_tl,f = t_open_quant fq in
fprintf fmt (protect_on opr "forall %a,@ %a") fprintf fmt (protect_on opr "forall %a,@ %a")
(print_space_list (print_vsty info)) vl (print_list space (print_vsty info)) vl
(* (print_tl info) tl *) (print_fmla info) f; (* (print_tl info) tl *) (print_fmla info) f;
List.iter forget_var vl List.iter forget_var vl
| Tquant (Texists,fq) -> | Tquant (Texists,fq) ->
...@@ -344,8 +338,8 @@ and print_fnode opl opr info fmt f = match f.t_node with ...@@ -344,8 +338,8 @@ and print_fnode opl opr info fmt f = match f.t_node with
| Tapp (ps, tl) -> | Tapp (ps, tl) ->
begin match query_syntax info.info_syn ps.ls_name with begin match query_syntax info.info_syn ps.ls_name with
| Some s -> syntax_arguments s (print_term info) fmt tl | Some s -> syntax_arguments s (print_term info) fmt tl
| _ -> fprintf fmt "(%a %a)" (print_ls_real info) ps | _ -> fprintf fmt "(%a%a)" (print_ls_real info) ps
(print_space_list (print_term info)) tl (print_list_pre space (print_term info)) tl
end end
| Tvar _ | Tconst _ | Teps _ -> raise (FmlaExpected f) | Tvar _ | Tconst _ | Teps _ -> raise (FmlaExpected f)
...@@ -369,12 +363,12 @@ let print_expr info fmt = ...@@ -369,12 +363,12 @@ let print_expr info fmt =
let print_constr info ts fmt (cs,_) = let print_constr info ts fmt (cs,_) =
match cs.ls_args with match cs.ls_args with
fprintf fmt "@[<hov 4>| %a : %a %a@]" print_ls cs fprintf fmt "@[<hov 4>| %a : %a%a@]" print_ls cs
print_ts ts (print_list space print_tv) ts.ts_args print_ts ts (print_list_pre space print_tv) ts.ts_args
| l -> | l ->
fprintf fmt "@[<hov 4>| %a : %a -> %a %a@]" print_ls cs fprintf fmt "@[<hov 4>| %a : %a -> %a%a@]" print_ls cs
(print_arrow_list (print_ty info)) l (print_arrow_list (print_ty info)) l
let ls_ty_vars ls = let ls_ty_vars ls =
let ty_vars_args = List.fold_left Ty.ty_freevars Stv.empty ls.ls_args in let ty_vars_args = List.fold_left Ty.ty_freevars Stv.empty ls.ls_args in
...@@ -668,8 +662,8 @@ let print_type_decl ~prev info fmt ts = ...@@ -668,8 +662,8 @@ let print_type_decl ~prev info fmt ts =
print_ts ts print_params_list ts.ts_args print_ts_tv ts print_ts ts print_params_list ts.ts_args print_ts_tv ts
print_ts ts print_ts ts
| Some ty -> | Some ty ->
fprintf fmt "(* Why3 assumption *)@\n@[<hov 2>Definition %a %a :=@ %a.@]@\n@\n" fprintf fmt "(* Why3 assumption *)@\n@[<hov 2>Definition %a%a :=@ %a.@]@\n@\n"
print_ts ts (print_list space print_tv_binder) ts.ts_args print_ts ts (print_list_pre space print_tv_binder) ts.ts_args
(print_ty info) ty (print_ty info) ty
let print_type_decl ~prev info fmt ts = let print_type_decl ~prev info fmt ts =
...@@ -681,8 +675,8 @@ let print_data_decl ~first info fmt ts csl = ...@@ -681,8 +675,8 @@ let print_data_decl ~first info fmt ts csl =
if first then if first then
fprintf fmt "(* Why3 assumption *)@\n@[<hov 2>Inductive" fprintf fmt "(* Why3 assumption *)@\n@[<hov 2>Inductive"
else fprintf fmt "@\nwith"; else fprintf fmt "@\nwith";
fprintf fmt " %s %a :=@\n@[<hov>%a@]" fprintf fmt " %s%a :=@\n@[<hov>%a@]"
name (print_list space print_tv_binder) ts.ts_args name (print_list_pre space print_tv_binder) ts.ts_args
(print_list newline (print_constr info ts)) csl; (print_list newline (print_constr info ts)) csl;
name name
...@@ -769,7 +763,7 @@ let print_logic_decl info fmt (ls,ld) = ...@@ -769,7 +763,7 @@ let print_logic_decl info fmt (ls,ld) =
fprintf fmt "(* Why3 assumption *)@\n@[<hov 2>Definition %a%a%a: %a :=@ %a.@]@\n" fprintf fmt "(* Why3 assumption *)@\n@[<hov 2>Definition %a%a%a: %a :=@ %a.@]@\n"
print_ls ls print_ls ls
print_ne_params all_ty_params print_ne_params all_ty_params
(print_space_list (print_vsty info)) vl (print_list_pre space (print_vsty info)) vl
(print_ls_type info) ls.ls_value (print_ls_type info) ls.ls_value
(print_expr info) e; (print_expr info) e;
List.iter forget_var vl; List.iter forget_var vl;
...@@ -812,7 +806,7 @@ let print_recursive_decl info fmt (ls,ld) = ...@@ -812,7 +806,7 @@ let print_recursive_decl info fmt (ls,ld) =
fprintf fmt "%a%a%a {struct %a}: %a :=@ %a@]" fprintf fmt "%a%a%a {struct %a}: %a :=@ %a@]"
print_vs (List.nth vl i) print_vs (List.nth vl i)
