GitLab
What's new
10
Support
Community forum
Keyboard shortcuts
Why3
why3
6368b28c
6368b28c
Benedikt Becker
Tune mlw_printer
3af6b8c9
4
Expand all
4 changed files
243 additions
235 deletions
+243
-235
bench/bench
bench/bench
+2
-10
bench/test_mlw_printer
+4
-1
examples/use_api/oracles/test-api-mlw_tree.stdout
+7
-7
src/parser/mlw_printer.ml
+230
-217
bench/bench
6368b28c
@@ -298,16 +298,8 @@ list_stuff () {
test_mlw_printer
python3
-m
sexpdata
return
"bench/valid/booleans.mlw"
exit
"bench/valid/complex_arg_1.mlw"
exit
"bench/valid/complex_arg_2.mlw"
exit
"bench/valid/division.mlw"
exit
"bench/valid/exns.mlw"
exit
"bench/valid/oldify.mlw"
exit
"bench/valid/recfun.mlw"
exit
"bench/valid/see.mlw"
exit
"bench/valid/type_invariant.mlw"
exit
"bench/valid/wpcalls.mlw"
exit
bench/test_mlw_printer bench/valid/
.mlw
bench/test_mlw_printer bench/typing/good/
.mlw
echo
"=== Checking stdlib ==="
6368b28c
@@ -53,11 +53,14 @@ def trace(path, sexp, sexp1):
def
test
filename
sexp0
read
filename
sexp1
print_and_read
filename
try
sexp1
print_and_read
filename
assert_equal
sexp0
sexp1
print
"OK:"
filename
return
True
except
AssertionError
print
"CANT REPARSE:"
filename
return
False
except
NotEqual
as
e
print
"FAILED:"
filename
# sexpdata.dump(trace(e.path, sexp0, e.sexp1), sys.stdout)
6368b28c
@@ -8,9 +8,9 @@ module M2
use int.Int
let f (x : int)
requires {
x = 6
ensures {
result = 42
Int.(*) x 7
requires {
x = 6
ensures { result = 42 } =
Int.(*) x 7
module M3
@@ -18,8 +18,8 @@ module M3
use ref.Ref
let f (_ : ())
ensures {
Int.(>=) result 0
let x =
Ref.ref 42
in Ref.(!) x
ensures { Int.(>=) result 0 } =
let x = Ref.ref 42 in Ref.(!) x
module M4
@@ -27,9 +27,9 @@ module M4
use array.Array
let f (a : Array.array int)
requires {
Int.(>=) (Array.length a) 1
requires {
returns { _ -> (Array.([]) a 0) = 42 } =
Array.([]<-) a 0 42
Array.([]<-) a 0 42
Tasks are:
Task 1: theory Task
6368b28c
This diff is collapsed.
