Commit 621a53a7 authored by Sylvain Dailler's avatar Sylvain Dailler
subst_all substitute all local definitions.
Do not work on a lot of definitions of the language.
parent 571b6a6a
...@@ -223,44 +223,6 @@ let replace t1 t2 h = ...@@ -223,44 +223,6 @@ let replace t1 t2 h =
| _ -> [d]) None in | _ -> [d]) None in
Trans.par [g; ng] Trans.par [g; ng]
let subst to_subst =
let found_eq =
fold (fun d acc ->
match d.d_node with
| Dprop (Paxiom, pr, t) ->
let acc = (match t.t_node with
| Tapp (ls, [t1; t2]) when ls_equal ls ps_equ ->
(* Allow to rewrite from the right *)
begin
match t1.t_node, t2.t_node with
| Tapp (ls, []), _ when ls_equal ls to_subst ->
Some (pr, t1, t2)
| _, Tapp (ls, []) when ls_equal ls to_subst ->
Some (pr, t2, t1)
| _ -> acc
| _ -> acc) in
acc
| _ -> acc) None in
let subst found_eq =
match found_eq with
| None -> raise (Arg_trans "subst") (* TODO change exception *)
| Some (pr_eq, t1, t2) ->
begin
Trans.decl (fun d ->
match d.d_node with
(* Remove equality over which we subst *)
| Dprop (Paxiom, pr, _t) when pr_equal pr pr_eq ->
(* Replace in all hypothesis *)
| Dprop (kind, pr, t) ->
[create_prop_decl kind pr (t_replace t1 t2 t)]
(* TODO should replace every occurences of t1 everywhere *)
| _ -> [d]) None
in
Trans.bind found_eq subst
let t_replace_app unf ls_defn t = let t_replace_app unf ls_defn t =
let (vl, tls) = ls_defn in let (vl, tls) = ls_defn in
match t.t_node with match t.t_node with
...@@ -294,15 +256,170 @@ let unfold unf h = ...@@ -294,15 +256,170 @@ let unfold unf h =
end end
| _ -> [d]) None | _ -> [d]) None
let sort task =
let local_decls =
let ut = Task.used_symbols (Task.used_theories task) in
Task.local_decls task ut in
let l = ref [] in
Trans.decl
(fun d ->
match d.d_node with
| _ when not (List.exists (fun x -> Decl.d_equal x d) local_decls) ->
[d]
| Dprop (Paxiom, _, _)
| Dprop (Plemma, _, _)
| Dprop (Pskip, _, _) ->
(* This goes in the second group *)
l := !l @ [d];
| Dprop (Pgoal, _, _) ->
(* Last element, we concatenate the list of postponed elements *)
!l @ [d]
| _ -> [d]) None
let () = wrap_and_register ~desc:"unfold ls pr: unfold logic symbol ls in hypothesis pr. Experimental." (* TODO *) (* TODO is sort really needed ? It looked like it was for subst in some example where I wanted to subst the definition of a logic constant into an equality and it would fail because the equality is defined before the logic definition. This may be solved by current implementation of subst: to be tested *)
"unfold" let sort =
(Tlsymbol (Tprsymbol Ttrans)) unfold Trans.store (fun task -> Trans.apply (sort task) task)
let get_local task =
(* This function is used to find a specific ident in an equality:
(to_subst = term or term = to_subst) in order to subst and remove said
equality.
This function returns None if not found, Some (None, t1, t2) with t1 being
to_subst and t2 being term to substitute to if the equality found it a symbol
definition. If equality found is a a decl then it is returned:
Some (Some pr, t1, t2) *)
let find_eq (to_subst: Term.lsymbol) =
fold (fun d acc ->
match d.d_node with
| Dprop (k, pr, t) when k != Pgoal ->
begin
Some (Some pr, t2, t1)
| _ -> acc
| _ -> acc) in
acc
| Dlogic [(ls, ld)] when ls_equal to_subst ls ->
(* Function without arguments *)
let vl, e = open_ls_defn ld in
if vl = [] then
Some (None, t_app_infer ls [], e)
else
acc
| _ -> acc) None
(* This found any equality which at one side contains a single lsymbol and is
local. It gives same output as found_eq. *)
let find_eq2 is_local_decl =
fold (fun d acc ->
match d.d_node with
| Dprop (k, pr, t) when k != Pgoal && is_local_decl d ->
begin
(match t1.t_node, t2.t_node with
| Tapp (_, []), _ ->
(* t1 = t2. And t1 and t2 are constant litterals *)
| _ -> acc)
| _ -> acc) in
acc
| Dlogic [(ls, ld)] when is_local_decl d ->
if vl = [] then
else
acc
| _ -> acc) None
let subst_eq found_eq =
match found_eq with
| None -> raise (Arg_trans "subst_eq")
| Some (Some pr_eq, t1, t2) ->
begin
match d.d_node with
| Dprop (_k, pr, _t) when pr_equal pr pr_eq ->
(* TODO should replace every occurences of t1 in all constructs not only in Dprop... Dlogic etc *)
| _ -> [d]) None
| Some (None, t1, t2) ->
begin
match d.d_node with
| Dlogic [(ls, _ld)] when try (t1 = Term.t_app_infer ls []) with _ -> false ->
| _ -> [d]) None
let subst (to_subst: Term.lsymbol) =
Trans.bind (find_eq to_subst) subst_eq
let subst_all (is_local_decl: Decl.decl -> bool) =
Trans.bind (find_eq2 is_local_decl) subst_eq
let return_local_decl task =
let decl_list = get_local task in
let is_local_decl d = List.exists (fun x -> Decl.d_equal d x) decl_list in
is_local_decl
let return_local_decl = Trans.store return_local_decl
let subst_all = Trans.bind return_local_decl subst_all
let rec repeat f task =
try
let new_task = Trans.apply f task in
(* TODO this is probably expansive. Use a checksum or an integer ? *)
if Task.task_equal new_task task then
raise Exit
else
repeat f new_task
| _ -> task
let repeat f = Trans.store (repeat f)
let () = wrap_and_register ~desc:"remove a literal using an equality on it" let () = wrap_and_register ~desc:"remove a literal using an equality on it"
"subst" "subst"
(Tlsymbol Ttrans) subst (Tlsymbol Ttrans) subst
let subst_all = repeat subst_all
let () =
wrap_and_register ~desc:"substitute all ident equalities and remove them"
"subst_all"
(Ttrans) subst_all
let () = wrap_and_register ~desc:"sort declarations"
"sort"
(Ttrans) sort
"unfold"
let () = wrap_and_register let () = wrap_and_register
~desc:"replace <term1> <term2> <name> replaces occcurences of term1 by term2 in prop name" ~desc:"replace <term1> <term2> <name> replaces occcurences of term1 by term2 in prop name"
"replace" "replace"
