Commit 5efd8958 authored by François Bobot's avatar François Bobot
Session rewrite fix : only one proof attempt by prover by goal (or is it a bad idea?)
parent 13c872fa
...@@ -538,7 +538,7 @@ let add_external_proof ...@@ -538,7 +538,7 @@ let add_external_proof
proof_edited_as = edit; proof_edited_as = edit;
in in
PHprover.add g.goal_external_proofs p a; PHprover.replace g.goal_external_proofs p a;
check_goal_proved notify g; check_goal_proved notify g;
a a
...@@ -620,7 +620,7 @@ let raw_add_transformation ~(keygen:'a keygen) g name exp = ...@@ -620,7 +620,7 @@ let raw_add_transformation ~(keygen:'a keygen) g name exp =
transf_expanded = exp; transf_expanded = exp;
in in
PHstr.add g.goal_transformations name tr; PHstr.replace g.goal_transformations name tr;
tr tr
let raw_add_theory ~(keygen:'a keygen) mfile thname exp = let raw_add_theory ~(keygen:'a keygen) mfile thname exp =
Supports Markdown
