Commit 5ed29aaf authored by François Bobot's avatar François Bobot
print function and predicate labels
parent 1e29c0d3
...@@ -320,14 +320,16 @@ let ls_kind ls = if ls.ls_value = None then "predicate" else "function" ...@@ -320,14 +320,16 @@ let ls_kind ls = if ls.ls_value = None then "predicate" else "function"
let print_logic_decl fst fmt (ls,ld) = match ld with let print_logic_decl fst fmt (ls,ld) = match ld with
| Some ld -> | Some ld ->
let vl,e = open_ls_defn ld in let vl,e = open_ls_defn ld in
fprintf fmt "@[<hov 2>%s %a%a%a =@ %a@]" fprintf fmt "@[<hov 2>%s %a%a%a%a =@ %a@]"
(if fst then ls_kind ls else "with") print_ls ls (if fst then ls_kind ls else "with") print_ls ls
print_ident_labels ls.ls_name
(print_list nothing print_vs_arg) vl (print_list nothing print_vs_arg) vl
(print_option print_ls_type) ls.ls_value print_term e; (print_option print_ls_type) ls.ls_value print_term e;
List.iter forget_var vl List.iter forget_var vl
| None -> | None ->
fprintf fmt "@[<hov 2>%s %a%a%a@]" fprintf fmt "@[<hov 2>%s %a%a%a%a@]"
(print_list nothing print_ty_arg) ls.ls_args (print_list nothing print_ty_arg) ls.ls_args
(print_option print_ls_type) ls.ls_value (print_option print_ls_type) ls.ls_value
