Commit 5e956b50 authored by Jean-Christophe Filliâtre's avatar Jean-Christophe Filliâtre
added theory list.ListRich
parent 854a61f0
...@@ -4,11 +4,7 @@ module M ...@@ -4,11 +4,7 @@ module M
Problem 5: amortized queue *) Problem 5: amortized queue *)
use import int.Int use import int.Int
use export list.List use export list.ListRich
use export list.Length
use export list.Append
use export list.Reverse
use export list.HdTl
type queue 'a = Q (front : list 'a) (lenf : int) type queue 'a = Q (front : list 'a) (lenf : int)
(rear : list 'a) (lenr : int) (rear : list 'a) (lenr : int)
...@@ -58,9 +58,13 @@ theory HdTl "head and tail" ...@@ -58,9 +58,13 @@ theory HdTl "head and tail"
| Cons _ t -> Some t | Cons _ t -> Some t
end end
(* TODO: move these lemmas into another theory? *) end
use import Nth
theory NthHdTl
use import Nth
use import HdTl
lemma Nth_tl : lemma Nth_tl :
forall l1 l2 : list 'a. tl l1 = Some l2 -> forall l1 l2 : list 'a. tl l1 = Some l2 ->
...@@ -219,3 +223,17 @@ end ...@@ -219,3 +223,17 @@ end
theory Fold theory Fold
(* TODO (a la Map) *) (* TODO (a la Map) *)
end end
theory ListRich
use export List
use export Length
use export Mem
use export Nth
use export HdTl
use export NthHdTl
use export Append
use export Reverse
use export Sorted
use export NumOcc
use export Permut
