GitLab
What's new
7
Support
Community forum
Keyboard shortcuts
Why3
why3
5cae7968
5cae7968
MARCHE Claude
why3session html: output file is now why3session.html
ba9543a2
4
4 changed files
13 additions
5 deletions
+13
-5
CHANGES
CHANGES
+4
Makefile.in
Makefile.in
+4
-4
doc/manpages.tex
doc/manpages.tex
+4
src/why3session/why3session_html.ml
+1
-1
CHANGES
5cae7968
* marks an incompatible change
tools
* file generated by "why3session html f.mlw" is now
"f/why3session.html" and not "f/f.html"
library
* renamed array.ArraySorted -> array.IntArraySorted
array.ArraySorted is now generic, with type and order relation parameters
Makefile.in
5cae7968
@@ -458,10 +458,10 @@ gallery::
why3session html
x
echo
"exporting
f"
mkdir
-p
$(GALLERYDIR)
f
cp
examples/
f.mlw examples/
f/
f
.html
$(GALLERYDIR)
f/
cp
examples/
f.mlw examples/
f/
why3session
.html
$(GALLERYDIR)
f/
rm
-f
$(GALLERYDIR)
f/
f.zip
cd
examples/
zip
-r
$(GALLERYDIR)
f/
f.zip
f.mlw
f/
f.html
f
zip
-r
$(GALLERYDIR)
f/
f.zip
f.mlw
f
cd
done
@@ -475,10 +475,10 @@ gallery::
mkdir
-p
$(GALLERYDIR)
f
if
test
-f
examples/
f.mlw
then
cp
examples/
f.mlw
$(GALLERYDIR)
f/
fi
if
test
-f
examples/
f.why
then
cp
examples/
f.why
$(GALLERYDIR)
f/
fi
cp
examples/
f/
f
.html
$(GALLERYDIR)
f/
cp
examples/
f/
why3session
.html
$(GALLERYDIR)
f/
rm
-f
$(GALLERYDIR)
f/
f.zip
cd
examples/
zip
-r
$(GALLERYDIR)
f/
f.zip
f.mlw
f
f.html
f
zip
-r
$(GALLERYDIR)
f/
f.zip
f.mlw
f
# XML DTD validation
doc/manpages.tex
5cae7968
@@ -844,6 +844,10 @@ This command produces a summary of the proof session in HTML syntax.
There are three styles of output: `table', `simpletree', and
`jstree'. The default is `table'.
The file generated is named
\texttt
why3session.html
and is written
in the session directory by default (see option
\texttt
-o
to
override this default).
\begin{figure}
[t]
%BEGIN LATEX
\begin{center}
5cae7968
@@ -78,7 +78,7 @@ let run_file (context : context) print_session fname =
let
basename
Filename
basename
project_dir
in
let
cout
if
output_dir
then
stdout
else
open_out
Filename
concat
output_dir
basename
.html"
open_out
Filename
concat
output_dir
"why3session
.html"
in
let
fmt
formatter_of_out_channel
cout
in
if
opt_context
