Commit 5bb5768b authored by Francois Bobot's avatar Francois Bobot
filter_trigger : correction du test de non modification
parent 038928db
...@@ -27,15 +27,16 @@ and rf keep f = ...@@ -27,15 +27,16 @@ and rf keep f =
| Fquant (Fforall,fq) -> | Fquant (Fforall,fq) ->
let vsl,trl,f2 = f_open_quant fq in let vsl,trl,f2 = f_open_quant fq in
let one_false = ref false in let one_false = ref false in
let keep = keep one_false in let keep x = let b = keep x in
if b then b else (one_false := true; b) in
let trl = List.filter (List.for_all keep) trl in let trl = List.filter (List.for_all keep) trl in
if not (!one_false) then f else f_forall vsl trl f2 if not (!one_false) then f else f_forall vsl trl f2
| _ -> f | _ -> f
let keep_no_predicate one_false = function let keep_no_predicate = function
| Term _ -> true | Term _ -> true
| _ -> one_false := true; false | _ -> false
let filter_trigger_no_predicate = let filter_trigger_no_predicate =
...@@ -47,10 +48,10 @@ let () = Register.register_transform "filter_trigger_no_predicate" ...@@ -47,10 +48,10 @@ let () = Register.register_transform "filter_trigger_no_predicate"
filter_trigger_no_predicate filter_trigger_no_predicate
let keep_no_fmla one_false = function let keep_no_fmla = function
| Fmla {f_node = Fapp (ps,_)} -> not (ls_equal ps ps_equ) | Fmla {f_node = Fapp (ps,_)} -> not (ls_equal ps ps_equ)
let filter_trigger = Register.store let filter_trigger = Register.store
...@@ -59,11 +60,11 @@ let filter_trigger = Register.store ...@@ -59,11 +60,11 @@ let filter_trigger = Register.store
let () = Register.register_transform "filter_trigger" filter_trigger let () = Register.register_transform "filter_trigger" filter_trigger
let keep_no_builtin query one_false = function let keep_no_builtin query = function
| Fmla {f_node = Fapp (ps,_)} -> | Fmla {f_node = Fapp (ps,_)} ->
Driver.query_syntax query ps.ls_name = None Driver.query_syntax query ps.ls_name = None
let filter_trigger_builtin = let filter_trigger_builtin =
