GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
Why3
why3
5b56b45d
5b56b45d
Andrei Paskevich
accumulate the cloning history in split_theory
cba5e2df
2
src/core/task.ml
5b56b45d
@@ -40,11 +40,19 @@ let cloned_from cl i1 i2 =
try
i1
i2
Sid
mem
i2
Mid
find
i1
cl
cl_map
try
i1
i2
Sid
mem
i2
Mid
find
i1
cl
cl_map
Not_found
false
Not_found
false
let
add_clone
let
merge_clone
let
add
m
id
s
acc
let
s
try
Sid
union
s
Mid
find
id
m
Not_found
s
in
Mid
add
id
s
acc
in
let
r
ref
in
let
r
ref
in
fun
cl
th
sl
fun
cl
th
incr
r
if
Mid
is_empty
th
th_clone
then
cl
else
cl_map
merge_clone
cl
cl_map
th
sl
cl_tag
r
cl_map
Mid
fold
add
cl
cl_map
th
th_clone
cl
cl_map
cl_tag
incr
r
r
(** Known identifiers *)
@@ -207,9 +215,10 @@ let rec use_export names acc td =
Use
th
when
Sid
mem
th
th_name
used
Use
th
when
Sid
mem
th
th_name
used
acc
acc
Use
th
Use
th
let
names
Some
Spr
empty
in
let
used
Sid
add
th
th_name
used
in
let
used
Sid
add
th
th_name
used
in
let
cl
merge_clone
cl
th
in
let
acc
used
cl
res
task
in
let
acc
used
cl
res
task
in
let
names
Some
Spr
empty
in
fold_left
use_export
names
acc
th
th_decls
fold_left
use_export
names
acc
th
th_decls
Decl
d
Decl
d
begin
match
d
d_node
begin
match
d
d_node
src/core/theory.mli
5b56b45d
@@ -90,8 +90,6 @@ val clone_export : theory_uc -> theory -> th_inst -> theory_uc
val
clone_fold
a
clone_map
tdecl
a
clone_map
val
clone_fold
a
clone_map
tdecl
a
clone_map
a
clone_map
theory
th_inst
a
clone_map
a
clone_map
theory
th_inst
a
clone_map
val
merge_clone
clone_map
theory
ident
ident
list
clone_map
(* exceptions *)
(* exceptions *)
exception
NonLocal
of
ident
exception
NonLocal
of
ident
