Commit 5b04269b authored by Andrei Paskevich's avatar Andrei Paskevich
Dexpr: compute VCs for type invariants
parent 2072b42d
...@@ -919,28 +919,32 @@ let check_user_ps recu ps = ...@@ -919,28 +919,32 @@ let check_user_ps recu ps =
(** Environment *) (** Environment *)
type local_env = { type local_env = {
kn : Mlw_decl.known_map;
lkn : Decl.known_map;
psm : psymbol Mstr.t; psm : psymbol Mstr.t;
pvm : pvsymbol Mstr.t; pvm : pvsymbol Mstr.t;
vsm : vsymbol Mstr.t; vsm : vsymbol Mstr.t;
let env_empty = { let env_empty lkn kn = {
kn = kn;
lkn = lkn;
psm = Mstr.empty; psm = Mstr.empty;
pvm = Mstr.empty; pvm = Mstr.empty;
vsm = Mstr.empty; vsm = Mstr.empty;
let add_psymbol {psm = psm; pvm = pvm; vsm = vsm} ps = let add_psymbol ({psm = psm} as lenv) ps =
let n = ps.ps_name.id_string in let n = ps.ps_name.id_string in
{ psm = Mstr.add n ps psm; pvm = pvm; vsm = vsm } { lenv with psm = Mstr.add n ps psm }
let add_pvsymbol {psm = psm; pvm = pvm; vsm = vsm} pv = let add_pvsymbol ({pvm = pvm; vsm = vsm} as lenv) pv =
let n = pv.pv_vs.vs_name.id_string in let n = pv.pv_vs.vs_name.id_string in
{ psm = psm; pvm = Mstr.add n pv pvm; vsm = Mstr.add n pv.pv_vs vsm } { lenv with pvm = Mstr.add n pv pvm; vsm = Mstr.add n pv.pv_vs vsm }
let add_pv_map {psm = psm; pvm = pvm; vsm = vsm} vm = let add_pv_map ({pvm = pvm; vsm = vsm} as lenv) vm =
let um = Mstr.map (fun pv -> pv.pv_vs) vm in let um = Mstr.map (fun pv -> pv.pv_vs) vm in
{ psm = psm; pvm = Mstr.set_union vm pvm; vsm = Mstr.set_union um vsm } { lenv with pvm = Mstr.set_union vm pvm; vsm = Mstr.set_union um vsm }
let add_let_sym env = function let add_let_sym env = function
| LetV pv -> add_pvsymbol env pv | LetV pv -> add_pvsymbol env pv
...@@ -950,6 +954,70 @@ let add_fundef env fd = add_psymbol env fd.fun_ps ...@@ -950,6 +954,70 @@ let add_fundef env fd = add_psymbol env fd.fun_ps
let add_fundefs env fdl = List.fold_left add_fundef env fdl let add_fundefs env fdl = List.fold_left add_fundef env fdl
let add_binders env pvl = List.fold_left add_pvsymbol env pvl let add_binders env pvl = List.fold_left add_pvsymbol env pvl
(** Invariant handling *)
let env_invariant {lkn = lkn; kn = kn} eff pvs =
let regs = Sreg.union eff.eff_writes eff.eff_ghostw in
let add_pv pv (pinv,qinv) =
let ity = pv.pv_ity in
let written r = reg_occurs r ity.ity_vars in
let inv = Mlw_wp.full_invariant lkn kn pv.pv_vs ity in
let qinv = (* we reprove invariants for modified non-reset variables *)
if Sreg.exists written regs && not (eff_stale_region eff ity.ity_vars)
then t_and_simp qinv inv else qinv in
t_and_simp pinv inv, qinv
in
Spv.fold add_pv pvs (t_true,t_true)
let rec check_reset rvs t = match t.t_node with
| Tvar vs when Svs.mem vs rvs ->
Loc.errorm "Variable %s is reset and can only be used \
under `old' in the postcondition" vs.vs_name.id_string
| Tapp (ls,_) when ls_equal ls Mlw_wp.fs_at -> false
| Tlet _ | Tcase _ | Teps _ | Tquant _ ->
let rvs = Mvs.set_inter rvs t.t_vars in
if Mvs.is_empty rvs then false else
t_any (check_reset rvs) t
| _ ->
let post_invariant {lkn = lkn; kn = kn} rvs inv ity q =
ignore (check_reset rvs q);
let vs, q = open_post q in
let res_inv = Mlw_wp.full_invariant lkn kn vs ity in
let q = t_and_asym_simp (t_and_simp res_inv inv) q in
Mlw_ty.create_post vs q
let reset_vars eff pvs =
let add pv s =
if eff_stale_region eff pv.pv_ity.ity_vars
then Svs.add pv.pv_vs s else s in
if Mreg.is_empty eff.eff_resets then Svs.empty else
Spv.fold add pvs Svs.empty
let spec_invariant env pvs vty spec =
let ity = ity_of_vty vty in
let pvs = spec_pvset pvs spec in
let rvs = reset_vars spec.c_effect pvs in
let pinv,qinv = env_invariant env spec.c_effect pvs in
let post_inv = post_invariant env rvs qinv in
let xpost_inv xs q = post_inv xs.xs_ity q in
{ spec with c_pre = t_and_asym_simp pinv spec.c_pre;
c_post = post_inv ity spec.c_post;
c_xpost = Mexn.mapi xpost_inv spec.c_xpost }
let abstr_invariant env e spec0 =
let pvs = spec_pvset e.e_syms.syms_pv spec0 in
let spec = spec_invariant env pvs e.e_vty spec0 in
(* we do not require invariants on free variables *)
{ spec with c_pre = spec0.c_pre }
let lambda_invariant env lam =
let { l_spec = spec; l_expr = e } = lam in
let pvs = spec_pvset e.e_syms.syms_pv spec in
let spec = spec_invariant env pvs e.e_vty spec in
{ lam with l_spec = { spec with c_letrec = 0 }}
(** Abstract values *) (** Abstract values *)
let rec type_c env pvs vars otv (dtyv, dsp) = let rec type_c env pvs vars otv (dtyv, dsp) =
...@@ -982,7 +1050,8 @@ let rec type_c env pvs vars otv (dtyv, dsp) = ...@@ -982,7 +1050,8 @@ let rec type_c env pvs vars otv (dtyv, dsp) =
let add_vs vs varl = (t_var vs, None) :: varl in let add_vs vs varl = (t_var vs, None) :: varl in
let varl = Svs.fold add_vs esvs spec.c_variant in let varl = Svs.fold add_vs esvs spec.c_variant in
let spec = { spec with c_variant = varl } in let spec = { spec with c_variant = varl } in
spec, vty (* add the invariants *)
spec_invariant env pvs vty spec, vty
and type_v env pvs vars otv = function and type_v env pvs vars otv = function
| DSpecV v -> | DSpecV v ->
...@@ -1172,6 +1241,7 @@ and try_expr keep_loc uloc env (argl,res) node = ...@@ -1172,6 +1241,7 @@ and try_expr keep_loc uloc env (argl,res) node =
"variants are not allowed in `abstract'"; "variants are not allowed in `abstract'";
let spec = spec_of_dspec e.e_effect tyv dsp in let spec = spec_of_dspec e.e_effect tyv dsp in
check_user_effect e spec false dsp; check_user_effect e spec false dsp;
let spec = abstr_invariant env e spec in
e_abstract e spec e_abstract e spec
| DEmark (id,de) -> | DEmark (id,de) ->
let ld = create_let_defn id Mlw_wp.e_now in let ld = create_let_defn id Mlw_wp.e_now in
...@@ -1221,10 +1291,12 @@ and expr_rec ~keep_loc uloc env dfdl = ...@@ -1221,10 +1291,12 @@ and expr_rec ~keep_loc uloc env dfdl =
let fd = create_fun_defn (id_clone ps.ps_name) lam in let fd = create_fun_defn (id_clone ps.ps_name) lam in
Loc.try2 ~loc check_user_ps true fd.fun_ps) fdl; Loc.try2 ~loc check_user_ps true fd.fun_ps) fdl;
raise exn in raise exn in
let step3 fd (id,_,bl,de,dsp) = let step3 fd = fd.fun_ps, lambda_invariant env fd.fun_lambda in
let fdl = create_rec_defn (List.map step3 fdl) in
let step4 fd (id,_,bl,de,dsp) =
Loc.try3 ?loc:de.de_loc check_lambda_effect fd bl dsp; Loc.try3 ?loc:de.de_loc check_lambda_effect fd bl dsp;
Loc.try2 ?loc:id.id_loc check_user_ps true fd.fun_ps in Loc.try2 ?loc:id.id_loc check_user_ps true fd.fun_ps in
List.iter2 step3 fdl dfdl; List.iter2 step4 fdl dfdl;
fdl fdl
and expr_fun ~keep_loc uloc env (id,gh,bl,de,dsp) = and expr_fun ~keep_loc uloc env (id,gh,bl,de,dsp) =
...@@ -1243,6 +1315,7 @@ and expr_fun ~keep_loc uloc env (id,gh,bl,de,dsp) = ...@@ -1243,6 +1315,7 @@ and expr_fun ~keep_loc uloc env (id,gh,bl,de,dsp) =
let post = Mlw_ty.create_post vs f in let post = Mlw_ty.create_post vs f in
let spec = { lam.l_spec with c_post = post } in let spec = { lam.l_spec with c_post = post } in
{ lam with l_spec = spec } in { lam with l_spec = spec } in
let lam = lambda_invariant env lam in
let fd = create_fun_defn id lam in let fd = create_fun_defn id lam in
Loc.try2 ?loc:id.pre_loc check_user_ps false fd.fun_ps; Loc.try2 ?loc:id.pre_loc check_user_ps false fd.fun_ps;
...@@ -1258,26 +1331,26 @@ and expr_lam ~keep_loc uloc env gh pvl de dsp = ...@@ -1258,26 +1331,26 @@ and expr_lam ~keep_loc uloc env gh pvl de dsp =
{ l_args = pvl; l_expr = e; l_spec = spec }, dsp { l_args = pvl; l_expr = e; l_spec = spec }, dsp
let val_decl ~keep_loc:_ vald = let val_decl ~keep_loc:_ lkn kn vald =
reunify_regions (); reunify_regions ();
val_decl env_empty vald val_decl (env_empty lkn kn) vald
let let_defn ~keep_loc (id,gh,de) = let let_defn ~keep_loc lkn kn (id,gh,de) =
let e = expr ~keep_loc None env_empty de in let e = expr ~keep_loc None (env_empty lkn kn) de in
let e = e_ghostify gh e in let e = e_ghostify gh e in
if e.e_ghost && not gh then (* TODO: localize better *) if e.e_ghost && not gh then (* TODO: localize better *)
Loc.errorm ?loc:id.pre_loc "%s must be a ghost variable" id.pre_name; Loc.errorm ?loc:id.pre_loc "%s must be a ghost variable" id.pre_name;
create_let_defn id e create_let_defn id e
let fun_defn ~keep_loc dfd = let fun_defn ~keep_loc lkn kn dfd =
expr_fun ~keep_loc None env_empty dfd expr_fun ~keep_loc None (env_empty lkn kn) dfd
let rec_defn ~keep_loc dfdl = let rec_defn ~keep_loc lkn kn dfdl =
expr_rec ~keep_loc None env_empty dfdl expr_rec ~keep_loc None (env_empty lkn kn) dfdl
let expr ~keep_loc de = let expr ~keep_loc lkn kn de =
expr ~keep_loc None env_empty de expr ~keep_loc None (env_empty lkn kn) de
...@@ -177,8 +177,17 @@ val dexpr : ?loc:Loc.position -> dexpr_node -> dexpr ...@@ -177,8 +177,17 @@ val dexpr : ?loc:Loc.position -> dexpr_node -> dexpr
(** Final stage *) (** Final stage *)
val expr : keep_loc:bool -> dexpr -> expr val expr : keep_loc:bool ->
val val_decl : keep_loc:bool -> dval_decl -> let_sym Decl.known_map -> Mlw_decl.known_map -> dexpr -> expr
val let_defn : keep_loc:bool -> dlet_defn -> let_defn
val fun_defn : keep_loc:bool -> dfun_defn -> fun_defn val val_decl : keep_loc:bool ->
val rec_defn : keep_loc:bool -> dfun_defn list -> fun_defn list Decl.known_map -> Mlw_decl.known_map -> dval_decl -> let_sym
Decl.known_map -> Mlw_decl.known_map -> dlet_defn -> let_defn
Decl.known_map -> Mlw_decl.known_map -> dfun_defn -> fun_defn
Decl.known_map -> Mlw_decl.known_map -> dfun_defn list -> fun_defn list
