extraction: fixed printing of arrow types
parent 1ccfd597
...@@ -8,6 +8,11 @@ theory BuiltIn ...@@ -8,6 +8,11 @@ theory BuiltIn
syntax predicate (=) "%1 = %2" syntax predicate (=) "%1 = %2"
end end
module HighOrd
syntax type (->) "%1 -> %2"
syntax val (@) "%1 %2"
theory option.Option theory option.Option
syntax type option "%1 option" syntax type option "%1 option"
syntax function None "None" syntax function None "None"
...@@ -356,6 +361,3 @@ module ocaml.Pervasives ...@@ -356,6 +361,3 @@ module ocaml.Pervasives
syntax val pred "pred %1" syntax val pred "pred %1"
end end
module HighOrd
\ No newline at end of file
...@@ -598,7 +598,7 @@ module Translate = struct ...@@ -598,7 +598,7 @@ module Translate = struct
| Eghost _ -> assert false | Eghost _ -> assert false
| Eassign al -> | Eassign al ->
ML.mk_expr (Mltree.Eassign al) (Mltree.I e.e_ity) eff lbl ML.mk_expr (Mltree.Eassign al) (Mltree.I e.e_ity) eff lbl
| Epure _ -> (* assert false (\*TODO*\) *) ML.mk_hole | Epure _ -> assert false
| Etry (etry, case, pvl_e_map) -> | Etry (etry, case, pvl_e_map) ->
assert (not case); (* TODO *) assert (not case); (* TODO *)
let etry = expr info etry in let etry = expr info etry in
...@@ -178,13 +178,11 @@ module Print = struct ...@@ -178,13 +178,11 @@ module Print = struct
| Ttuple tl -> | Ttuple tl ->
fprintf fmt (protect_on paren "@[%a@]") fprintf fmt (protect_on paren "@[%a@]")
(print_list star (print_ty ~paren:true info)) tl (print_list star (print_ty ~paren:true info)) tl
| Tapp (ts, [t1; t2]) when id_equal ts ts_func.ts_name ->
fprintf fmt (protect_on paren "@[%a ->@ %a@]")
(print_ty ~paren:true info) t1 (print_ty info) t2
| Tapp (ts, tl) -> | Tapp (ts, tl) ->
match query_syntax info.info_syn ts with match query_syntax info.info_syn ts with
| Some s -> | Some s ->
syntax_arguments s (print_ty ~paren:true info) fmt tl fprintf fmt (protect_on paren "%a")
(syntax_arguments s (print_ty ~paren:true info)) tl
| None -> | None ->
match tl with match tl with
...@@ -298,7 +296,7 @@ module Print = struct ...@@ -298,7 +296,7 @@ module Print = struct
| [], _ -> () | [], _ -> ()
| _, [] -> assert false | _, [] -> assert false
and print_apply ?(paren=false) info rs fmt pvl = and print_apply info rs fmt pvl =
let isfield = let isfield =
match rs.rs_field with match rs.rs_field with
| None -> false | None -> false
...@@ -333,10 +331,10 @@ module Print = struct ...@@ -333,10 +331,10 @@ module Print = struct
(print_uident info) fmt rs.rs_name (print_uident info) fmt rs.rs_name
| [], [t] -> | [], [t] ->
fprintf fmt (protect_on paren "@[<hov 2>%a %a@]") fprintf fmt "@[<hov 2>%a %a@]"
(print_uident info) rs.rs_name (print_expr ~paren:true info) t (print_uident info) rs.rs_name (print_expr ~paren:true info) t
| [], tl -> | [], tl ->
fprintf fmt (protect_on paren "@[<hov 2>%a (%a)@]") fprintf fmt "@[<hov 2>%a (%a)@]"
(print_uident info) rs.rs_name (print_list comma (print_expr info)) (print_uident info) rs.rs_name (print_list comma (print_expr info))
tl tl
| pjl, tl -> | pjl, tl ->
...@@ -347,7 +345,7 @@ module Print = struct ...@@ -347,7 +345,7 @@ module Print = struct
| _, None, [] -> | _, None, [] ->
(print_lident info) fmt rs.rs_name (print_lident info) fmt rs.rs_name
| _, None, tl -> | _, None, tl ->
(print_lident info) rs.rs_name (print_lident info) rs.rs_name
(print_apply_args info) (tl, rs.rs_cty.cty_args) (print_apply_args info) (tl, rs.rs_cty.cty_args)
(* (print_list space (print_expr ~paren:true info)) tl *) (* (print_list space (print_expr ~paren:true info)) tl *)
...@@ -424,9 +422,6 @@ module Print = struct ...@@ -424,9 +422,6 @@ module Print = struct
fprintf fmt "true" fprintf fmt "true"
| Eapp (rs, []) when rs_equal rs rs_false -> | Eapp (rs, []) when rs_equal rs rs_false ->
fprintf fmt "false" fprintf fmt "false"
| Eapp (rs, [e1; e2]) when rs_equal rs rs_func_app ->
fprintf fmt (protect_on paren "@[<hov 1>%a %a@]")
(print_expr info) e1 (print_expr ~paren:true info) e2
| Eapp (rs, []) -> | Eapp (rs, []) ->
(* avoids parenthesis around values *) (* avoids parenthesis around values *)
fprintf fmt "%a" (print_apply info (Hrs.find_def ht_rs rs rs)) [] fprintf fmt "%a" (print_apply info (Hrs.find_def ht_rs rs rs)) []
