Commit 59a46a0e authored by David Hauzar's avatar David Hauzar
Counterexample support for cvc4 moved to cvc4-1.5
parent d0812227
...@@ -12,19 +12,6 @@ prelude "(set-logic AUFBVDTNIRA)" ...@@ -12,19 +12,6 @@ prelude "(set-logic AUFBVDTNIRA)"
does not seem to include DT does not seem to include DT
(* Counterexamples: enable model construction *)
prelude ";; Enable model construction"
prelude "(set-option :produce-models true)"
(* Counterexamples: makes it possible to get rid of more quantifiers while introducing premises *)
(* transformation "split_intro" *)
(* Counterexamples: get rid of some quantifiers - makes it possible to query model values of the variables in premises *)
transformation "introduce_premises"
(* Counterexamples: set model parser *)
model_parser "cvc4_z3"
import "smt-libv2.drv" import "smt-libv2.drv"
import "discrimination.gen" import "discrimination.gen"
This diff is collapsed.
...@@ -87,7 +87,7 @@ version_switch = "--version" ...@@ -87,7 +87,7 @@ version_switch = "--version"
version_regexp = "This is CVC4 version \\([^ \n\r]+\\)" version_regexp = "This is CVC4 version \\([^ \n\r]+\\)"
version_ok = "1.5-prerelease" version_ok = "1.5-prerelease"
version_ok = "1.5" version_ok = "1.5"
driver = "drivers/cvc4_14.drv" driver = "drivers/cvc4_15.drv"
# --random-seed=42 is not needed as soon as --random-freq=0.0 by default # --random-seed=42 is not needed as soon as --random-freq=0.0 by default
# to try: --inst-when=full-last-call # to try: --inst-when=full-last-call
command = "%l/why3-cpulimit %T %m -s %e --stats --tlimit-per=%t000 --lang=smt2 %f" command = "%l/why3-cpulimit %T %m -s %e --stats --tlimit-per=%t000 --lang=smt2 %f"
