Commit 59a18fe3 authored by Sylvain Dailler's avatar Sylvain Dailler
ce-bench: change oracles directory. Add possibility to xfail tests for ce
parent 25411b40
...@@ -26,28 +26,43 @@ if test "$files" = "" ; then ...@@ -26,28 +26,43 @@ if test "$files" = "" ; then
files="$dir/ce/*.mlw" files="$dir/ce/*.mlw"
fi fi
is_xfail=false
# $1 = prover, $2 = file # TODO this function should disappear as counterexamples should eventually get
# more reproducible.
decide_fail () {
case "$1" in
# Inconsistent results between two runs
"bench/ce/algebraic_type_Z3,4.6.0_SP")
is_xfail=true;;
"bench/ce/algebraic_type_Z3,4.6.0_WP")
is_xfail=true;;
"bench/ce/ref_mono_Z3,4.6.0_WP")
is_xfail=true;;
esac
# $1 = prover, $2 = dir, $3 = filename, $4 = true for WP; false for SP
run () { run () {
is_xfail=false
printf " $2 ($1)... " printf " $2 ($1)... "
f="$2_$1" file_path="$2/$3"
printf "WP $2 ($1)... " if $4; then
echo "Weakest Precondition" > "$f.out" f="${file_path}_$1_WP"
$dir/../bin/why3prove.opt --debug print_model_attrs -P "$1,counterexamples" --timelimit 1 -a split_vc "$2.mlw" | \ oracle_file="$2/oracles/$3_$1_WP.oracle"
# This ad hoc sed removes any timing information from counterexamples output. wp_sp=""
# Counterexamples in JSON format cannot match this regexp. echo "Weakest Precondition" > "$f.out"
sed 's/ ([0-9]\+\.[0-9]\+s)//' | \ printf "Weakest Precondition ${file_path} ($1)... "
# This ad hoc sed removes diff between Timeout and Unknown (unknown) else
# when running from platform with different speed. f="${file_path}_$1_SP"
sed -r 's/(Timeout|Unknown \(unknown\))/Timeout or Unknown/' | \ oracle_file="$2/oracles/$3_$1_SP.oracle"
# ad hoc sed to remove the directory of the stdlib that can be found wp_sp=" --debug vc_sp"
# inside labels attribute [@at:'Old:loc:/home/.../stdlib/array.mlw echo "Strongest Postcondition" > "$f.out"
# TODO temporary as this comes from incorrect locations generated in printf "Strongest Postcondition ${file_path} ($1)... "
# a[i] <- x like terms. fi
sed -r 's/\:loc\:.*\]/\:loc\:location\]/' >> "$f.out" $dir/../bin/why3prove.opt --debug print_model_attrs${wp_sp} -P "$1,counterexamples" --timelimit 1 -a split_vc "${file_path}.mlw" | \
printf "SP $2 ($1)... "
echo "Strongest Postcondition" >> "$f.out"
$dir/../bin/why3prove.opt --debug print_model_attrs --debug vc_sp -P "$1,counterexamples" --timelimit 1 -a split_vc "$2.mlw" | \
# This ad hoc sed removes any timing information from counterexamples output. # This ad hoc sed removes any timing information from counterexamples output.
# Counterexamples in JSON format cannot match this regexp. # Counterexamples in JSON format cannot match this regexp.
sed 's/ ([0-9]\+\.[0-9]\+s)//' | \ sed 's/ ([0-9]\+\.[0-9]\+s)//' | \
...@@ -59,17 +74,23 @@ run () { ...@@ -59,17 +74,23 @@ run () {
# TODO temporary as this comes from incorrect locations generated in # TODO temporary as this comes from incorrect locations generated in
# a[i] <- x like terms. # a[i] <- x like terms.
sed -r 's/\:loc\:.*\]/\:loc\:location\]/' >> "$f.out" sed -r 's/\:loc\:.*\]/\:loc\:location\]/' >> "$f.out"
if cmp "$f.oracle" "$f.out" > /dev/null 2>&1 ; then if cmp "${oracle_file}" "$f.out" > /dev/null 2>&1 ; then
echo "ok" echo "ok"
else else
if $updateoracle; then if $updateoracle; then
echo "Updating oracle for $2, prover $1" echo "Updating oracle for ${file_path}, prover $1"
mv "$f.out" "$f.oracle" mv "$f.out" "${oracle_file}"
else else
echo "FAILED!" echo "FAILED!"
echo "diff is the following:" echo "diff is the following:"
diff "$f.oracle" "$f.out" echo "${f}"
success=false diff "${oracle_file}" "$f.out"
decide_fail ${f}
if $is_xfail; then
echo "Failed but bench is ok because asserted as an XFAIL."
else
success=false
fi
fi fi
fi fi
...@@ -78,8 +99,10 @@ for file in $files; do ...@@ -78,8 +99,10 @@ for file in $files; do
filedir=`dirname $file` filedir=`dirname $file`
filebase=`basename $file .mlw` filebase=`basename $file .mlw`
printf "Running provers on $filedir/$filebase.mlw\n"; printf "Running provers on $filedir/$filebase.mlw\n";
run CVC4,1.5 $filedir/$filebase run CVC4,1.5 $filedir $filebase true
run Z3,4.6.0 $filedir/$filebase run CVC4,1.5 $filedir $filebase false
run Z3,4.6.0 $filedir $filebase true
run Z3,4.6.0 $filedir $filebase false
done done
if $success; then if $success; then
exit 0 exit 0
bench/ce/algebraic_type.mlw M G: Timeout or Unknown
Counter-example model:File algebraic_type.mlw:
Line 6:
x, [[@introduced], [@model_trace:x]] = {"type" : "Apply" ,
"val" : {"apply" : "Integer" , "list" : [{"type" : "Integer" ,
"val" : "0" }] } }
bench/ce/algebraic_type.mlw M g2: Timeout or Unknown
Line 10:
"val" : {"apply" : "B" , "list" : [{"type" : "Integer" ,
"val" : "0" }] } }
bench/ce/algebraic_type.mlw M g4: Timeout or Unknown
Line 12:
"val" : {"apply" : "A" ,
"list" : [] } }
bench/ce/algebraic_type.mlw M g5: Timeout or Unknown
Line 16:
"val" : {"apply" : "Au" , "list" : [{"type" : "Integer" , "val" : "0" },
"val" : "1" }] } }
bench/ce/algebraic_type.mlw M g1: Timeout or Unknown
Line 25:
l, [[@introduced], [@model_trace:l]] = {"type" : "Apply" ,
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "-1" },
{"type" : "Apply" , "val" : {"apply" : "Nil" ,
"list" : [] } }] } }
bench/ce/algebraic_type.mlw M g7: Timeout or Unknown
Line 27:
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "0" },
bench/ce/algebraic_type.mlw M g: Timeout or Unknown
Strongest Postcondition Strongest Postcondition
bench/ce/algebraic_type.mlw M G: Timeout or Unknown bench/ce/algebraic_type.mlw M G: Timeout or Unknown
Counter-example model:File algebraic_type.mlw: Counter-example model:File algebraic_type.mlw:
Line 6:
"val" : "0" }] } }
Line 10:
"val" : "0" }] } }
Line 12:
"list" : [] } }
Line 16:
"val" : "1" }] } }
Line 25:
Line 27:
bench/ce/algebraic_type.mlw M G: Unknown (sat)
Line 6:
"val" : "0" }] } }
bench/ce/algebraic_type.mlw M g2: Unknown (sat)
Line 10:
"val" : "0" }] } }
bench/ce/algebraic_type.mlw M g4: Unknown (sat)
Line 12:
"list" : [] } }
bench/ce/algebraic_type.mlw M g5: Unknown (sat)
Line 16:
"val" : {"apply" : "Au" , "list" : [{"type" : "Integer" , "val" : "1" },
"val" : "0" }] } }
Line 25:
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "17" },
{"type" : "Apply" , "val" : {"apply" : "Cons" ,
"list" : [{"type" : "Integer" , "val" : "164" }, {"type" : "Apply" ,
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "162" },
"list" : [{"type" : "Integer" , "val" : "160" }, {"type" : "Apply" ,
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "158" },
"list" : [] } }] } }] } }] } }] } }] } }
Line 27:
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "21" },
"list" : [{"type" : "Integer" , "val" : "10" }, {"type" : "Apply" ,
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "9" },
"list" : [{"type" : "Integer" , "val" : "7" }, {"type" : "Apply" ,
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "8" },
bench/ce/algebraic_type.mlw M G: Unknown (sat) bench/ce/algebraic_type.mlw M G: Unknown (sat)
...@@ -93,11 +34,11 @@ Line 25: ...@@ -93,11 +34,11 @@ Line 25:
l, [[@introduced], [@model_trace:l]] = {"type" : "Apply" , l, [[@introduced], [@model_trace:l]] = {"type" : "Apply" ,
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "17" }, "val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "17" },
{"type" : "Apply" , "val" : {"apply" : "Cons" , {"type" : "Apply" , "val" : {"apply" : "Cons" ,
"list" : [{"type" : "Integer" , "val" : "160" }, {"type" : "Apply" , "list" : [{"type" : "Integer" , "val" : "160" }, {"type" : "Apply" ,
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "158" }, "val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "158" },
"list" : [{"type" : "Integer" , "val" : "156" }, {"type" : "Apply" ,
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "154" },
{"type" : "Apply" , "val" : {"apply" : "Nil" , {"type" : "Apply" , "val" : {"apply" : "Nil" ,
"list" : [] } }] } }] } }] } }] } }] } } "list" : [] } }] } }] } }] } }] } }] } }
Line 6:
"val" : "0" }] } }
Line 10:
"val" : "0" }] } }
Line 12:
"list" : [] } }
Line 16:
"val" : "0" }] } }
Line 25:
"list" : [{"type" : "Integer" , "val" : "165" }, {"type" : "Apply" ,
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "163" },
"list" : [{"type" : "Integer" , "val" : "161" }, {"type" : "Apply" ,
"val" : {"apply" : "Cons" , "list" : [{"type" : "Integer" , "val" : "159" },
Line 27:
bench/ce/array_mono.mlw Array VC array: Valid
bench/ce/array_mono.mlw A VC f1: Timeout or Unknown
Counter-example model:File array_mono.mlw:
Line 35:
a, [[@introduced], [@model_trace:a]] = {"type" : "Record" ,
"val" : {"Field" : [{"field" : "elts" , "value" : {"type" : "Array" ,
"val" : [{"others" : {"type" : "Integer" , "val" : "0" } }] } },
{"field" : "length" , "value" : {"type" : "Integer" ,
Line 36:
bench/ce/array_mono.mlw A VC f2: Valid
bench/ce/array_mono.mlw A VC f2: Timeout or Unknown
Line 38:
a, [[@introduced], [@model_trace:a],
[@at:'Old:loc:location],
[@at:'Old:loc:location] = {"type" : "Record" ,
"val" : [{"indice" : "0" , "value" : {"type" : "Integer" , "val" : "42" } },
{"indice" : "1" , "value" : {"type" : "Integer" , "val" : "42" } },
{"others" : {"type" : "Integer" , "val" : "0" } }] } }, {"field" : "length" ,
"val" : "2" } }] } }
Line 40:
...@@ -45,42 +45,3 @@ a, [[@introduced], [@model_trace:a]] = {"type" : "Record" , ...@@ -45,42 +45,3 @@ a, [[@introduced], [@model_trace:a]] = {"type" : "Record" ,
"value" : {"type" : "Integer" , "value" : {"type" : "Integer" ,
"val" : "2" } }] } } "val" : "2" } }] } }
Line 35:
Line 36:
Line 38:
Line 40:
Line 35:
Line 36:
Line 38:
{"others" : {"type" : "Integer" , "val" : "4" } }] } }, {"field" : "length" ,
Line 40:
...@@ -42,40 +42,3 @@ a, [[@introduced], [@model_trace:a]] = {"type" : "Record" , ...@@ -42,40 +42,3 @@ a, [[@introduced], [@model_trace:a]] = {"type" : "Record" ,
Line 35:
Line 36:
Line 38:
Line 40:
bench/ce/array_records.mlw Array_records VC var_overwrite: Timeout or Unknown
Counter-example model:File array_records.mlw:
Line 23:
"val" : {"Field" : [{"field" : "first_value" ,
"value" : {"type" : "Integer" , "val" : "3" } }, {"field" : "flag" ,
"value" : {"type" : "Boolean" , "val" : true } }, {"field" : "second_value" ,
"value" : {"type" : "Integer" , "val" : "5" } }] } }
i, [[@introduced],
[@model_trace:i]] = {"type" : "Integer" ,
"val" : "-1" }
Line 27:
i, [[@introduced],
"val" : "-1" }
Line 23:
i, [[@introduced],
"val" : "-1" }
Line 27:
i, [[@introduced],
"val" : "-1" }
Line 23:
i, [[@introduced],
"val" : "-1" }
Line 27:
i, [[@introduced],
"val" : "-1" }
Line 23:
i, [[@introduced],
