Commit 58fbf6cb authored by Andrei Paskevich's avatar Andrei Paskevich
move option utilities from Util to Opt
+ rename Debug.Opt to Debug.Args to avoid conflicts
parent 4468018f
......@@ -108,7 +108,7 @@ LIBGENERATED = src/util/config.ml src/util/rc.ml src/parser/lexer.ml \
src/driver/driver_parser.mli src/driver/driver_parser.ml \
src/driver/driver_lexer.ml src/session/xml.ml
LIB_UTIL = config stdlib exn_printer pp debug loc print_tree \
LIB_UTIL = config opt stdlib exn_printer pp debug loc print_tree \
cmdline hashweak hashcons util warning sysutil rc plugin
LIB_CORE = ident ty term pattern decl theory task pretty env trans printer
......@@ -90,9 +90,9 @@ let option_list = Arg.align [
" same as -m";
"-j", Arg.Int (fun i -> opt_j := Some i),
"<int> Set the number of worker to use (default:1)";
Debug.Opt.desc_debug_list;
Debug.Opt.desc_debug_all;
Debug.Opt.desc_debug;
Debug.Args.desc_debug_list;
Debug.Args.desc_debug_all;
Debug.Args.desc_debug;
type runnable_prover =
......@@ -109,12 +109,12 @@ let env,provers = try
let main = get_main config in
Whyconf.load_plugins main;
Debug.Opt.set_flags_selected ();
Debug.Args.set_flags_selected ();
(** listings*)
let opt_list = ref false in
opt_list := Debug.Opt.option_list () || !opt_list;
opt_list := Debug.Args.option_list () || !opt_list;
if !opt_list then exit 0;
if Queue.is_empty opt_queue then begin
......@@ -270,7 +270,7 @@ let find_dobj ~loc denv env impl s =
| _ -> assert false (* impossible *)
let ty_check loc s ty1 t =
Loc.try3 loc ty_match s ty1 (of_option t.t_ty)
Loc.try3 loc ty_match s ty1 (Opt.get t.t_ty)
let rec ty denv env impl { e_loc = loc; e_node = n } = match n with
| Eapp (aw,al) ->
......@@ -303,7 +303,7 @@ let rec term denv env impl { e_loc = loc; e_node = n } = match n with
| Enum (Nint s) ->
t_int_const s
| Enum (Nreal (i,f,e)) ->
t_real_const (RConstDecimal (i,Util.def_option "0" f,e))
t_real_const (RConstDecimal (i,Opt.get_def "0" f,e))
| Enum (Nrat (n,d)) ->
let n = t_int_const n and d = t_int_const d in
let frac = ns_find_ls denv.th_rat.th_export ["frac"] in
......@@ -314,7 +314,7 @@ let rec term denv env impl { e_loc = loc; e_node = n } = match n with
begin match Mstr.find s env with
| SletF ([],_,[],t) ->
let id = id_user s def.e_loc in
let vs = create_vsymbol id (of_option t.t_ty) in
let vs = create_vsymbol id (Opt.get t.t_ty) in
let env = Mstr.add s (SVar vs) env in
let t1 = term denv env impl e in
t_let_close vs t t1
......@@ -345,7 +345,7 @@ and fmla denv env impl pol tvl { e_loc = loc; e_node = n } = match n with
let f,b = fmla denv env impl pol tvl e in
t_let_close vs t f, b
......@@ -394,8 +394,8 @@ and fmla denv env impl pol tvl { e_loc = loc; e_node = n } = match n with
let f1,b1 = fmla denv env impl pol tvl e1 in
let f2,b2 = fmla denv env impl pol tvl e2 in
if b1 || b2 then
let g1,_ = fmla denv env impl (option_map not pol) tvl e1 in
let g2,_ = fmla denv env impl (option_map not pol) tvl e2 in
let g1,_ = fmla denv env impl (Opt.map not pol) tvl e1 in
let g2,_ = fmla denv env impl (Opt.map not pol) tvl e2 in
t_and (t_implies g1 f2) (t_implies g2 f1), true
else
t_iff f1 f2, false
......@@ -403,18 +403,18 @@ and fmla denv env impl pol tvl { e_loc = loc; e_node = n } = match n with
if b1 || b2 then
t_not (t_and (t_implies f1 g2) (t_implies f2 g1)), true
else
t_not (t_iff f1 f2), false
| Ebin (BOimp,e1,e2) ->
let f1,b1 = fmla denv env impl (option_map not pol) tvl e1 in
let f1,b1 = fmla denv env impl (Opt.map not pol) tvl e1 in
t_implies f1 f2, b1 || b2
| Ebin (BOpmi,e1,e2) ->
let f2,b2 = fmla denv env impl (option_map not pol) tvl e2 in
let f2,b2 = fmla denv env impl (Opt.map not pol) tvl e2 in
t_implies f2 f1, b1 || b2
| Ebin (BOand,e1,e2) ->
......@@ -425,15 +425,15 @@ and fmla denv env impl pol tvl { e_loc = loc; e_node = n } = match n with
t_or f1 f2, b1 || b2
| Ebin (BOnand,e1,e2) ->
t_not (t_and f1 f2), b1 || b2
| Ebin (BOnor,e1,e2) ->
t_not (t_or f1 f2), b1 || b2
| Enot e1 ->
t_not f1, b1
| Eequ (e1,e2) ->
let t1 = term denv env impl e1 in
......@@ -499,7 +499,7 @@ and ls_args denv env impl loc fs tvl gl mvs al =
fs_app denv.fs_ghost [] (ty_app denv.ts_ghost [Mtv.find v tvm]) in
let tl = List.map ghost gl @ List.map (term denv env impl) al in
let tvm = List.fold_left2 (ty_check loc) tvm fs.ls_args tl in
let ty = option_map (ty_inst tvm) fs.ls_value in
let ty = Opt.map (ty_inst tvm) fs.ls_value in
t_app fs tl ty
| _ -> error ~loc BadArity
in
......@@ -560,7 +560,7 @@ and tr_global_ts dep env r =
(* Format.printf "decl = %a@." Pretty.print_decl decl; *)
List.iter (add_new_decl dep !dep') tl;
List.iter (add_dep dep') tl;
Util.option_iter (add_new_decl dep !dep') decl;
Opt.iter (add_new_decl dep !dep') decl;
lookup_table global_ts r
(* the function/predicate symbol for r *)
......@@ -599,14 +599,14 @@ and tr_global_ls dep env r =
let pl, d = decompose_definition dep' env c in
List.iter (add_new_decl dep !dep') pl;
List.iter (add_dep dep') pl;
Util.option_iter (add_new_decl dep !dep') d;
Opt.iter (add_new_decl dep !dep') d;
lookup_table global_ls r
| IndRef i ->
assert (is_Prop t);
let pl, d = decompose_inductive dep' env i in
| VarRef _ ->
make_one_ls dep' env r;
......@@ -316,7 +316,7 @@ module Hsdecl = Hashcons.Make (struct
type t = decl
let cs_equal (cs1,pl1) (cs2,pl2) =
ls_equal cs1 cs2 && list_all2 (option_eq ls_equal) pl1 pl2
ls_equal cs1 cs2 && list_all2 (Opt.equal ls_equal) pl1 pl2
let eq_td (ts1,td1) (ts2,td2) =
ts_equal ts1 ts2 && list_all2 cs_equal td1 td2
......@@ -413,7 +413,7 @@ let syms_ty s ty = ty_s_fold syms_ts s ty
let syms_term s t = t_s_fold syms_ty syms_ls s t
let create_ty_decl ts =
let syms = Util.option_fold syms_ty Sid.empty ts.ts_def in
let syms = Opt.fold syms_ty Sid.empty ts.ts_def in
let news = Sid.singleton ts.ts_name in
mk_decl (Dtype ts) syms news
......@@ -430,7 +430,7 @@ let create_data_decl tdl =
| Some ls -> raise (BadRecordField ls)
in
let check_constr tys ty pjs (syms,news) (fs,pl) =
ty_equal_check ty (exn_option (BadConstructor fs) fs.ls_value);
ty_equal_check ty (Opt.get_exn (BadConstructor fs) fs.ls_value);
let fs_pjs =
try List.fold_left2 (check_proj fs ty) Sls.empty fs.ls_args pl
with Invalid_argument _ -> raise (BadConstructor fs) in
......@@ -455,7 +455,7 @@ let create_data_decl tdl =
if ts.ts_def <> None then raise (IllegalTypeAlias ts);
let news = news_id news ts.ts_name in
let pjs = List.fold_left (fun s (_,pl) -> List.fold_left
(option_fold (fun s ls -> Sls.add ls s)) s pl) Sls.empty cl in
(Opt.fold (fun s ls -> Sls.add ls s)) s pl) Sls.empty cl in
let news = Sls.fold (fun pj s -> news_id s pj.ls_name) pjs news in
let ty = ty_app ts (List.map ty_var ts.ts_args) in
List.fold_left (check_constr ts ty pjs) (syms,news) cl
......@@ -464,7 +464,7 @@ let create_data_decl tdl =
mk_decl (Ddata tdl) syms news
let create_param_decl ls =
let syms = Util.option_fold syms_ty Sid.empty ls.ls_value in
let syms = Opt.fold syms_ty Sid.empty ls.ls_value in
let syms = List.fold_left syms_ty syms ls.ls_args in
let news = Sid.singleton ls.ls_name in
mk_decl (Dparam ls) syms news
......@@ -494,9 +494,9 @@ let rec f_pos_ps sps pol f = match f.t_node, pol with
| Tbinop (Tiff, f, g), _ ->
f_pos_ps sps None f && f_pos_ps sps None g
| Tbinop (Timplies, f, g), _ ->
f_pos_ps sps (option_map not pol) f && f_pos_ps sps pol g
f_pos_ps sps (Opt.map not pol) f && f_pos_ps sps pol g
| Tnot f, _ ->
| Tif (f,g,h), _ ->
f_pos_ps sps None f && f_pos_ps sps pol g && f_pos_ps sps pol h
| _ -> TermTF.t_all (t_pos_ps sps) (f_pos_ps sps pol) f
......@@ -775,7 +775,7 @@ let parse_record kn fll =
| [{ ty_node = Tyapp (ts,_) }] -> ts
| _ -> raise (BadRecordField fs) in
let cs, pjl = match find_constructors kn ts with
| [cs,pjl] -> cs, List.map (exn_option (BadRecordField fs)) pjl
| [cs,pjl] -> cs, List.map (Opt.get_exn (BadRecordField fs)) pjl
let pjs = List.fold_left (fun s pj -> Sls.add pj s) Sls.empty pjl in
let flm = List.fold_left (fun m (pj,v) ->
......@@ -797,10 +797,10 @@ let make_record_update kn t fll ty =
let make_record_pattern kn fll ty =
let cs,pjl,flm = parse_record kn fll in
let s = ty_match Mtv.empty (of_option cs.ls_value) ty in
let s = ty_match Mtv.empty (Opt.get cs.ls_value) ty in
let get_arg pj = match Mls.find_opt pj flm with
| Some v -> v
| None -> pat_wild (ty_inst s (of_option pj.ls_value))
| None -> pat_wild (ty_inst s (Opt.get pj.ls_value))
in
pat_app cs (List.map get_arg pjl) ty
......@@ -104,7 +104,7 @@ module Compile (X : Action) = struct
with NonExhaustive pl ->
let find_cs cs =
if Mls.mem cs types then () else
let tm = ty_match Mtv.empty (of_option cs.ls_value) ty in
let tm = ty_match Mtv.empty (Opt.get cs.ls_value) ty in
let wild ty = pat_wild (ty_inst tm ty) in
let pw = pat_app cs (List.map wild cs.ls_args) ty in
raise (NonExhaustive (pw :: pl))
......@@ -58,7 +58,7 @@ let print_ident_labels fmt id =
not (Slab.is_empty id.id_label) then
fprintf fmt "@ %a" print_labels id.id_label;
if Debug.test_flag debug_print_locs then
Util.option_iter (fprintf fmt "@ %a" print_loc) id.id_loc
Opt.iter (fprintf fmt "@ %a" print_loc) id.id_loc
(* type variables always start with a quote *)
let print_tv fmt tv =
......@@ -148,7 +148,7 @@ let unambig_fs fs =
| Tyvar u when not (lookup u) -> false
| _ -> ty_all inspect ty
in
option_apply true inspect fs.ls_value
Opt.fold (fun _ -> inspect) true fs.ls_value
(** Patterns, terms, and formulas *)
......@@ -85,7 +85,7 @@ let task_equal t1 t2 = match t1, t2 with
| None, None -> true
| _ -> false
let task_hash t = option_apply 0 (fun t -> task_hd_hash t + 1) t
let task_hash t = Opt.fold (fun _ t -> task_hd_hash t + 1) 0 t
module Hstask = Hashcons.Make (struct
type t = task_hd
......@@ -107,9 +107,9 @@ let mk_task decl prev known clone meta = Some (Hstask.hashcons {
task_tag = Hashweak.dummy_tag;
let task_known = option_apply Mid.empty (fun t -> t.task_known)
let task_clone = option_apply Mid.empty (fun t -> t.task_clone)
let task_meta = option_apply Mmeta.empty (fun t -> t.task_meta)
let task_known = Opt.fold (fun _ t -> t.task_known) Mid.empty
let task_clone = Opt.fold (fun _ t -> t.task_clone) Mid.empty
let task_meta = Opt.fold (fun _ t -> t.task_meta) Mmeta.empty
let find_clone_tds task (th : theory) = cm_find (task_clone task) th
let find_meta_tds task (t : meta) = mm_find (task_meta task) t
......@@ -202,7 +202,7 @@ let add_meta task t al = new_meta task t (create_meta t al)
let split_tdecl names (res,task) td = match td.td_node with
| Decl { d_node = Dprop ((Pgoal|Plemma),pr,f) }
when option_apply true (Spr.mem pr) names ->
when Opt.fold (fun _ -> Spr.mem pr) true names ->
let res = add_prop_decl task Pgoal pr f :: res in
res, flat_tdecl task td
| _ ->
......@@ -392,7 +392,7 @@ module Hsterm = Hashcons.Make (struct
oty_equal t1.t_ty t2.t_ty &&
t_equal_node t1.t_node t2.t_node &&
Slab.equal t1.t_label t2.t_label &&
option_eq Loc.equal t1.t_loc t2.t_loc
Opt.equal Loc.equal t1.t_loc t2.t_loc
let t_hash_bound (v,b,t) =
Hashcons.combine (vs_hash v) (bnd_hash b (t_hash t))
......@@ -881,7 +881,7 @@ let rec t_gen_map fnT fnL m t =
| Tconst _ ->
t
| Tapp (fs, tl) ->
t_app (fnL fs) (List.map fn tl) (option_map fnT t.t_ty)
t_app (fnL fs) (List.map fn tl) (Opt.map fnT t.t_ty)
| Tif (f, t1, t2) ->
t_if (fn f) (fn t1) (fn t2)
| Tlet (t1, (u,b,t2)) ->
......@@ -933,7 +933,7 @@ let t_ty_subst mapT mapV t =
let rec t_gen_fold fnT fnL acc t =
let fn = t_gen_fold fnT fnL in
let acc = option_fold fnT acc t.t_ty in
let acc = Opt.fold fnT acc t.t_ty in
match t.t_node with
| Tconst _ | Tvar _ -> acc
| Tapp (f, tl) -> List.fold_left fn (fnL acc f) tl
......@@ -460,7 +460,7 @@ let rec cl_find_ts cl ts =
if not (Sid.mem ts.ts_name cl.cl_local) then ts
else try Mts.find ts cl.ts_table
with Not_found ->
let td' = option_map (cl_trans_ty cl) ts.ts_def in
let td' = Opt.map (cl_trans_ty cl) ts.ts_def in
let ts' = create_tysymbol (id_clone ts.ts_name) ts.ts_args td' in
cl.ts_table <- Mts.add ts ts' cl.ts_table;
ts'
......@@ -472,7 +472,7 @@ let cl_find_ls cl ls =
else try Mls.find ls cl.ls_table
with Not_found ->
let ta' = List.map (cl_trans_ty cl) ls.ls_args in
let vt' = option_map (cl_trans_ty cl) ls.ls_value in
let vt' = Opt.map (cl_trans_ty cl) ls.ls_value in
let ls' = create_lsymbol (id_clone ls.ls_name) ta' vt' in
cl.ls_table <- Mls.add ls ls' cl.ls_table;
ls'
......@@ -542,7 +542,7 @@ let cl_data cl inst tdl =
cl_find_ls cl ls
in
let add_constr (ls,pl) =
add_ls ls, List.map (option_map add_ls) pl
add_ls ls, List.map (Opt.map add_ls) pl
in
let add_type (ts,csl) =
if Mts.mem ts inst.inst_ts then
......@@ -632,7 +632,7 @@ let clone_theory cl add_td acc th inst =
try Some (mk_tdecl (cl_tdecl cl inst td))
with EmptyDecl -> None
in
option_apply acc (add_td acc) td
Opt.fold add_td acc td
in
let acc = List.fold_left add acc th.th_decls in
let sm = {
......@@ -738,7 +738,7 @@ let clone_meta tdt sm = match tdt.td_node with
(** access to meta *)
let theory_meta = option_apply Mmeta.empty (fun t -> t.task_meta)
let theory_meta = Opt.fold (fun _ t -> t.task_meta) Mmeta.empty
let find_meta_tds th (t : meta) = mm_find (theory_meta th) t
......@@ -152,7 +152,7 @@ let create_tysymbol name args def =
let add s v = Stv.add_new (DuplicateTypeVar v) v s in
let s = List.fold_left add Stv.empty args in
let check v = Stv.mem v s || raise (UnboundTypeVar v) in
ignore (option_map (ty_v_all check) def);
ignore (Opt.map (ty_v_all check) def);
mk_ts name args def
let ty_app s tl =
......@@ -251,17 +251,17 @@ exception UnexpectedProp
let oty_type = function Some ty -> ty | None -> raise UnexpectedProp
let oty_equal = Util.option_eq ty_equal
let oty_hash = Util.option_apply 1 ty_hash
let oty_equal = Opt.equal ty_equal
let oty_hash = Opt.fold (fun _ -> ty_hash) 1
let oty_match m o1 o2 = match o1,o2 with
| Some ty1, Some ty2 -> ty_match m ty1 ty2
| None, None -> m
| _ -> raise UnexpectedProp
let oty_inst m = Util.option_map (ty_inst m)
let oty_freevars = Util.option_fold ty_freevars
let oty_cons = Util.option_fold (fun tl t -> t::tl)
let oty_inst m = Opt.map (ty_inst m)
let oty_freevars = Opt.fold ty_freevars
let oty_cons = Opt.fold (fun tl t -> t::tl)
let ty_equal_check ty1 ty2 =
if not (ty_equal ty1 ty2) then raise (TypeMismatch (ty1, ty2))
......@@ -335,7 +335,7 @@ let detect_exec env main data acc exec_name =
known_version env exec_name;
eprintf "Found prover %s version %s%s@."
data.prover_name ver
(def_option
(Opt.get_def
". This version of the prover is known to have problems."
data.message);
acc
......@@ -362,7 +362,7 @@ let detect_exec env main data acc exec_name =
if good || old then begin
(def_option (if old then
(Opt.get_def (if old then
" (it is an old version that is less tested than \
the current one)." else ", Ok.")
data.message);
......@@ -198,7 +198,7 @@ let call_on_file ~command ?(timelimit=0) ?(memlimit=0)
(try List.assoc n exitcodes with Not_found -> grep out regexps)
in
Debug.dprintf debug "Call_provers: prover output:@\n%s@." out;
let time = Util.def_option time (grep_time out timeregexps) in
let time = Opt.get_def time (grep_time out timeregexps) in
let ans = match ans with
| HighFailure when !on_timelimit && timelimit > 0
&& time >= (0.9 *. float timelimit) -> Timeout
......@@ -304,9 +304,9 @@ let prove_task_prepared
~command ?timelimit ?memlimit ?old ?inplace drv task =
let buf = Buffer.create 1024 in
let fmt = formatter_of_buffer buf in
let old_channel = option_map open_in old in
let old_channel = Opt.map open_in old in
print_task_prepared ?old:old_channel drv fmt task; pp_print_flush fmt ();
option_iter close_in old_channel;
Opt.iter close_in old_channel;
let filename = match old, inplace with
| Some fn, Some true -> fn
| _ ->
......@@ -512,8 +512,8 @@ let mk_filter_prover ?version ?altern name =
| Some "" -> invalid_arg "mk_filter_prover: version can't be an empty string"
| _ -> () end;
{ filter_name = mk_regexp name;
filter_version = option_map mk_regexp version;
filter_altern = option_map mk_regexp altern;
filter_version = Opt.map mk_regexp version;
filter_altern = Opt.map mk_regexp altern;
let print_filter_prover fmt fp =
......@@ -540,8 +540,8 @@ let parse_filter_prover s =
let filter_prover fp p =
let check s schema = Str.string_match schema.reg s 0 in
check p.prover_name fp.filter_name
&& option_apply true (check p.prover_version) fp.filter_version
&& option_apply true (check p.prover_altern) fp.filter_altern
&& Opt.fold (fun _ -> check p.prover_version) true fp.filter_version
&& Opt.fold (fun _ -> check p.prover_altern) true fp.filter_altern
let filter_provers whyconf fp =
try
......@@ -647,7 +647,7 @@ let set_main config main =
let set_provers config ?shortcuts provers =
let shortcuts = def_option config.prover_shortcuts shortcuts in
let shortcuts = Opt.get_def config.prover_shortcuts shortcuts in
{config with
config = set_provers_shortcuts config.config shortcuts provers;
provers = provers;
......@@ -60,9 +60,9 @@ let spec = Arg.align [
Arg.String (fun s -> input_files := s :: !input_files),
"<f> add file f to the project (ignored if it is already there)") ;
("-v",
Arg.Set opt_version,
" print version information") ;
......@@ -94,8 +94,8 @@ let () = Gconfig.read_config !opt_config !opt_extra
let () = C.load_plugins (get_main ())
let () =
if Debug.Opt.option_list () then exit 0
if Debug.Args.option_list () then exit 0
let () =
if !opt_list_formats then begin
......@@ -1668,7 +1668,7 @@ let color_loc ~color loc =
let rec color_locs ~color f =
let b = ref false in
Util.option_iter (fun loc -> color_loc ~color loc; b := true) f.Term.t_loc;
Opt.iter (fun loc -> color_loc ~color loc; b := true) f.Term.t_loc;
Term.t_fold (fun b loc -> color_locs ~color loc || b) !b f
(* FIXME: we shouldn't open binders _every_time_ we redraw screen!!!
......@@ -1698,7 +1698,7 @@ let scroll_to_source_goal g =
{ Theory.td_node =
Theory.Decl { Decl.d_node = Decl.Dprop (Decl.Pgoal, _, f)}}} ->
if not (color_t_locs f) then
Util.option_iter (color_loc ~color:goal_tag) id.Ident.id_loc
Opt.iter (color_loc ~color:goal_tag) id.Ident.id_loc
| _ ->
assert false
......@@ -85,12 +85,12 @@ let spec = Arg.align [
"--convert-unknown-provers", Arg.Set opt_convert_unknown_provers,
" try to find compatible provers for all unknown provers";
Debug.Opt.desc_shortcut "parse_only" "--parse-only" " Stop after parsing";
Debug.Args.desc_shortcut "parse_only" "--parse-only" " Stop after parsing";
"type_only" "--type-only" " Stop after type checking";
......@@ -140,8 +140,8 @@ let env = Env.create_env loadpath
let () = Whyconf.load_plugins (Whyconf.get_main config)
let () =
module O =
struct
......@@ -190,14 +190,14 @@ let option_list = Arg.align [
" List known input formats";
"--list-metas", Arg.Set opt_list_metas,
" List known metas";
"--token-count", Arg.Set opt_token_count,
" Only lexing, and give numbers of tokens in spec vs in program";
"--print-libdir", Arg.Set opt_print_libdir,
" Print location of binary components (plugins, etc)";
"--print-datadir", Arg.Set opt_print_datadir,
......@@ -227,7 +227,7 @@ let () = try
(** listings*)
......@@ -280,7 +280,7 @@ let () = try
printf "@[<hov 2>Known metas:@\n%a@]@\n@."
(Pp.print_list Pp.newline2 print) (List.sort cmp (Theory.list_metas ()))
end;
......@@ -480,7 +480,7 @@ let do_theory env drv fname tname th glist =
eprintf "Cannot realize individual goals.@.";
exit 1
end else begin
let drv = Util.of_option drv in
let drv = Opt.get drv in
let task = Task.use_export None th in
do_tasks env drv fname tname th task
......@@ -492,7 +492,7 @@ let do_theory env drv fname tname th glist =
in
Decl.Spr.add pr acc
in
let prs = Queue.fold add Decl.Spr.empty glist in
let sel = if Decl.Spr.is_empty prs then None else Some prs in
let tasks = List.rev (split_theory th sel !opt_task) in
