Commit 58f6ad12 authored by Andrei Paskevich's avatar Andrei Paskevich
higher-order application syntax in patterns
parent bc1519af
...@@ -460,12 +460,19 @@ list1_pat_sep_comma: ...@@ -460,12 +460,19 @@ list1_pat_sep_comma:
| pattern { [$1] } | pattern { [$1] }
| pattern COMMA list1_pat_sep_comma { $1::$3 } | pattern COMMA list1_pat_sep_comma { $1::$3 }
list1_pat_arg:
| pat_arg { [$1] }
| pat_arg list1_pat_arg { $1::$2 }
pattern: pattern:
| pat_arg { $1 }
| uqualid list1_pat_arg { mk_pat (PPpapp ($1, $2)) }
| pattern AS lident { mk_pat (PPpas ($1,$3)) }
pat_arg:
| UNDERSCORE { mk_pat (PPpwild) } | UNDERSCORE { mk_pat (PPpwild) }
| lident { mk_pat (PPpvar $1) } | lident { mk_pat (PPpvar $1) }
| uqualid { mk_pat (PPpapp ($1, [])) } | uqualid { mk_pat (PPpapp ($1, [])) }
| uqualid LEFTPAR list1_pat_sep_comma RIGHTPAR { mk_pat (PPpapp ($1, $3)) }
| LEFTPAR pattern RIGHTPAR { $2 } | LEFTPAR pattern RIGHTPAR { $2 }
| LEFTPAR RIGHTPAR { mk_pat (PPptuple []) } | LEFTPAR RIGHTPAR { mk_pat (PPptuple []) }
| LEFTPAR pattern COMMA list1_pat_sep_comma RIGHTPAR | LEFTPAR pattern COMMA list1_pat_sep_comma RIGHTPAR
...@@ -12,7 +12,7 @@ theory Length ...@@ -12,7 +12,7 @@ theory Length
logic length(l : 'a list) : int = logic length(l : 'a list) : int =
match l with match l with
| Nil -> 0 | Nil -> 0
| Cons(_, r) -> 1 + length(r) | Cons _ r -> 1 + length(r)
end end
lemma Length_nonnegative : forall l:'a list. length(l) >= 0 lemma Length_nonnegative : forall l:'a list. length(l) >= 0
...@@ -24,7 +24,7 @@ theory Mem ...@@ -24,7 +24,7 @@ theory Mem
logic mem(x: 'a, l : 'a list) = match l with logic mem(x: 'a, l : 'a list) = match l with
| Nil -> false | Nil -> false
| Cons(y, r) -> x = y or mem(x, r) | Cons y r -> x = y or mem(x, r)
end end
end end
...@@ -55,7 +55,7 @@ theory Map ...@@ -55,7 +55,7 @@ theory Map
logic map(l : a list) : b list = logic map(l : a list) : b list =
| Nil -> Nil | Nil -> Nil
| Cons(x, r) -> Cons(f(x), map(r)) | Cons x r -> Cons(f(x), map(r))
end end
end end
Supports Markdown
