Commit 55c1fc02 authored by Andrei Paskevich's avatar Andrei Paskevich
whyml: include pure symbols in the program namespace
Thus, we do not need to look through two different namespaces.
The only difference w.r.t. the core namespace semantics is that
a program symbol (pvsymbol, psymbol, plsymbol, or xsymbol) may
be introduced in the scope of an lsymbol of the same name and
overshadow it in program expressions, though not in specifications.
For example, the following declarations allow to use (!) both in
programs and specifications:
    type ref 'a = {| mutable contents : 'a |}
    function (!) (x: ref 'a) : 'a = x.contents
    let (!) (r: ref 'a) = {} r.contents { result = !r }
Notice, however, that itsymbols cannot overshadow pure tsymbols.
parent a384381e
...@@ -48,32 +48,27 @@ let ns_replace eq chk x vo vn = ...@@ -48,32 +48,27 @@ let ns_replace eq chk x vo vn =
if eq vo vn then vo else if eq vo vn then vo else
raise (ClashSymbol x) raise (ClashSymbol x)
let ns_union eq chk =
Mstr.union (fun x vn vo -> Some (ns_replace eq chk x vo vn))
let rec merge_ns chk ns1 ns2 = let rec merge_ns chk ns1 ns2 =
let join eq x n o = Some (ns_replace eq chk x o n) in
let ns_union eq m1 m2 = Mstr.union (join eq) m1 m2 in
let fusion _ ns1 ns2 = Some (merge_ns chk ns1 ns2) in let fusion _ ns1 ns2 = Some (merge_ns chk ns1 ns2) in
{ ns_ts = ns_union ts_equal chk ns1.ns_ts ns2.ns_ts; { ns_ts = ns_union ts_equal ns1.ns_ts ns2.ns_ts;
ns_ls = ns_union ls_equal chk ns1.ns_ls ns2.ns_ls; ns_ls = ns_union ls_equal ns1.ns_ls ns2.ns_ls;
ns_pr = ns_union pr_equal chk ns1.ns_pr ns2.ns_pr; ns_pr = ns_union pr_equal ns1.ns_pr ns2.ns_pr;
ns_ns = Mstr.union fusion ns1.ns_ns ns2.ns_ns; } ns_ns = Mstr.union fusion ns1.ns_ns ns2.ns_ns; }
let nm_add chk x ns m = Mstr.change (function let add_ns chk x ns m = Mstr.change (function
| None -> Some ns | Some os -> Some (merge_ns chk ns os)
| Some os -> Some (merge_ns chk ns os)) x m | None -> Some ns) x m
let ns_add eq chk x v m = Mstr.change (function let ns_add eq chk x vn m = Mstr.change (function
| None -> Some v | Some vo -> Some (ns_replace eq chk x vo vn)
| Some vo -> Some (ns_replace eq chk x vo v)) x m | None -> Some vn) x m
let ts_add = ns_add ts_equal let add_ts chk x ts ns = { ns with ns_ts = ns_add ts_equal chk x ts ns.ns_ts }
let ls_add = ns_add ls_equal let add_ls chk x ls ns = { ns with ns_ls = ns_add ls_equal chk x ls ns.ns_ls }
let pr_add = ns_add pr_equal let add_pr chk x pf ns = { ns with ns_pr = ns_add pr_equal chk x pf ns.ns_pr }
let add_ns chk x nn ns = { ns with ns_ns = add_ns chk x nn ns.ns_ns }
let add_ts chk x ts ns = { ns with ns_ts = ts_add chk x ts ns.ns_ts }
let add_ls chk x ls ns = { ns with ns_ls = ls_add chk x ls ns.ns_ls }
let add_pr chk x pf ns = { ns with ns_pr = pr_add chk x pf ns.ns_pr }
let add_ns chk x nn ns = { ns with ns_ns = nm_add chk x nn ns.ns_ns }
let rec ns_find get_map ns = function let rec ns_find get_map ns = function
| [] -> assert false | [] -> assert false
...@@ -28,7 +28,7 @@ open Ty ...@@ -28,7 +28,7 @@ open Ty
open Term open Term
open Decl open Decl
type namespace = private { type namespace = {
ns_ts : tysymbol Mstr.t; (* type symbols *) ns_ts : tysymbol Mstr.t; (* type symbols *)
ns_ls : lsymbol Mstr.t; (* logic symbols *) ns_ls : lsymbol Mstr.t; (* logic symbols *)
ns_pr : prsymbol Mstr.t; (* propositions *) ns_pr : prsymbol Mstr.t; (* propositions *)
...@@ -42,66 +42,80 @@ open Mlw_decl ...@@ -42,66 +42,80 @@ open Mlw_decl
3. program decls 3. program decls
type prgsymbol = type type_symbol =
| PT of itysymbol
| TS of tysymbol
type prog_symbol =
| PV of pvsymbol | PV of pvsymbol
| PS of psymbol | PS of psymbol
| PL of plsymbol | PL of plsymbol
| PX of xsymbol | XS of xsymbol
| LS of lsymbol
type namespace = { type namespace = {
ns_it : itysymbol Mstr.t; (* type symbols *) ns_ts : type_symbol Mstr.t; (* type symbols *)
ns_ps : prgsymbol Mstr.t; (* program symbols *) ns_ps : prog_symbol Mstr.t; (* program symbols *)
ns_ns : namespace Mstr.t; (* inner namespaces *) ns_ns : namespace Mstr.t; (* inner namespaces *)
let empty_ns = { let empty_ns = {
ns_it = Mstr.empty; ns_ts = Mstr.empty;
ns_ps = Mstr.empty; ns_ps = Mstr.empty;
ns_ns = Mstr.empty; ns_ns = Mstr.empty;
let ns_replace eq chk x vo vn = let ns_replace sub chk x vo vn =
if not chk then vn else if not chk then vn else
if eq vo vn then vo else if sub vo vn then vn else
let ns_union eq chk = let tsym_sub t1 t2 = match t1,t2 with
Mstr.union (fun x vn vo -> Some (ns_replace eq chk x vo vn)) | PT t1, PT t2 -> its_equal t1 t2
| TS t1, TS t2 -> ts_equal t1 t2
| _, _ -> false
let prg_equal p1 p2 = match p1,p2 with let psym_sub p1 p2 = match p1,p2 with
| PV p1, PV p2 -> pv_equal p1 p2 | PV p1, PV p2 -> pv_equal p1 p2
| PS p1, PS p2 -> ps_equal p1 p2 | PS p1, PS p2 -> ps_equal p1 p2
| PL p1, PL p2 -> pl_equal p1 p2 | PL p1, PL p2 -> pl_equal p1 p2
| PX p1, PX p2 -> xs_equal p1 p2 | XS p1, XS p2 -> xs_equal p1 p2
| LS p1, LS p2 -> ls_equal p1 p2
(* program symbols may overshadow pure symbols *)
| LS _, (PV _|PS _|PL _|XS _) -> true
| _, _ -> false | _, _ -> false
let join sub x n o = Some (ns_replace sub chk x o n) in
let ns_union sub m1 m2 = Mstr.union (join sub) m1 m2 in
{ ns_it = ns_union its_equal chk ns1.ns_it ns2.ns_it; { ns_ts = ns_union tsym_sub ns1.ns_ts ns2.ns_ts;
ns_ps = ns_union prg_equal chk ns1.ns_ps ns2.ns_ps; ns_ps = ns_union psym_sub ns1.ns_ps ns2.ns_ps;
let ns_add eq chk x v m = Mstr.change (function let ns_add sub chk x vn m = Mstr.change (function
| None -> Some v | Some vo -> Some (ns_replace sub chk x vo vn)
let it_add = ns_add its_equal let add_ts chk x ts ns = { ns with ns_ts = ns_add tsym_sub chk x ts ns.ns_ts }
let ps_add = ns_add prg_equal let add_ps chk x pf ns = { ns with ns_ps = ns_add psym_sub chk x pf ns.ns_ps }
let add_it chk x ts ns = { ns with ns_it = it_add chk x ts ns.ns_it } let rec convert_pure_ns ns =
let add_ps chk x pf ns = { ns with ns_ps = ps_add chk x pf ns.ns_ps } { ns_ts = Mstr.map (fun ts -> TS ts) ns.Theory.ns_ts;
let add_ns chk x nn ns = { ns with ns_ns = nm_add chk x nn ns.ns_ns } ns_ps = Mstr.map (fun ls -> LS ls) ns.Theory.ns_ls;
ns_ns = Mstr.map convert_pure_ns ns.Theory.ns_ns; }
| [a] -> Mstr.find a (get_map ns) | [a] -> Mstr.find a (get_map ns)
| a::l -> ns_find get_map (Mstr.find a ns.ns_ns) l | a::l -> ns_find get_map (Mstr.find a ns.ns_ns) l
let ns_find_it = ns_find (fun ns -> ns.ns_it) let ns_find_ts = ns_find (fun ns -> ns.ns_ts)
let ns_find_ps = ns_find (fun ns -> ns.ns_ps) let ns_find_ps = ns_find (fun ns -> ns.ns_ps)
let ns_find_ns = ns_find (fun ns -> ns.ns_ns) let ns_find_ns = ns_find (fun ns -> ns.ns_ns)
...@@ -175,37 +189,28 @@ let close_namespace uc import s = ...@@ -175,37 +189,28 @@ let close_namespace uc import s =
(** Use *) (** Use *)
let add_to_module uc th ns =
match uc.muc_import, uc.muc_export with
| i0 :: sti, e0 :: ste -> { uc with
muc_theory = th;
muc_import = merge_ns false ns i0 :: sti;
muc_export = merge_ns true ns e0 :: ste; }
| _ -> assert false
let use_export uc m = let use_export uc m =
let mth = m.mod_theory in let mth = m.mod_theory in
let id = mth.th_name in let id = mth.th_name in
let uc = let uc =
if not (Sid.mem id uc.muc_used) then if Sid.mem id uc.muc_used then uc else { uc with
{ uc with muc_known = merge_known uc.muc_known m.mod_known;
muc_known = merge_known uc.muc_known m.mod_known; muc_used = Sid.add id uc.muc_used } in
muc_used = Sid.add id uc.muc_used; } let th = Theory.use_export uc.muc_theory mth in
else add_to_module uc th m.mod_export
uc
in
muc_theory = Theory.use_export uc.muc_theory mth;
muc_import = merge_ns false m.mod_export i0 :: sti;
muc_export = merge_ns true m.mod_export e0 :: ste; }
| _ -> assert false
(** Logic decls *) (** Logic decls *)
let add_to_theory f uc x = { uc with muc_theory = f uc.muc_theory x } let add_to_theory f uc x = { uc with muc_theory = f uc.muc_theory x }
let add_decl = add_to_theory Theory.add_decl
let use_export_theory = add_to_theory Theory.use_export
let clone_export_theory uc th i =
{ uc with muc_theory = Theory.clone_export uc.muc_theory th i }
let add_meta uc m al =
{ uc with muc_theory = Theory.add_meta uc.muc_theory m al }
(** Program decls *)
let add_symbol add id v uc = let add_symbol add id v uc =
match uc.muc_import, uc.muc_export with match uc.muc_import, uc.muc_export with
| i0 :: sti, e0 :: ste -> { uc with | i0 :: sti, e0 :: ste -> { uc with
...@@ -213,15 +218,58 @@ let add_symbol add id v uc = ...@@ -213,15 +218,58 @@ let add_symbol add id v uc =
muc_export = add true id.id_string v e0 :: ste } muc_export = add true id.id_string v e0 :: ste }
| _ -> assert false | _ -> assert false
let add_decl uc d =
let add_ts uc ts = add_symbol add_ts ts.ts_name (TS ts) uc in
let add_ls uc ls = add_symbol add_ps ls.ls_name (LS ls) uc in
let add_pj uc pj = Util.option_fold add_ls uc pj in
let add_cs uc (cs,pjl) = List.fold_left add_pj (add_ls uc cs) pjl in
let add_data uc (ts,csl) = List.fold_left add_cs (add_ts uc ts) csl in
let add_logic uc (ls,_) = add_ls uc ls in
let uc = match d.Decl.d_node with
| Decl.Dtype ts -> add_ts uc ts
| Decl.Ddata dl -> List.fold_left add_data uc dl
| Decl.Dparam ls -> add_ls uc ls
| Decl.Dlogic dl -> List.fold_left add_logic uc dl
| Decl.Dind (_,dl) -> List.fold_left add_logic uc dl
| Decl.Dprop _ -> uc
in
add_to_theory Theory.add_decl uc d
let use_export_theory uc th =
let nth = Theory.use_export uc.muc_theory th in
let nns = convert_pure_ns th.th_export in
add_to_module uc nth nns
let clone_export_theory uc th inst =
let nth = Theory.clone_export uc.muc_theory th inst in
let sm = match Theory.get_rev_decls nth with
| { td_node = Clone (_,sm) } :: _ -> sm
| _ -> assert false in
let g_ts _ ts = not (Mts.mem ts inst.inst_ts) in
let g_ls _ ls = not (Mls.mem ls inst.inst_ls) in
let f_ts ts = TS (Mts.find_def ts ts sm.sm_ts) in
let f_ls ls = LS (Mls.find_def ls ls sm.sm_ls) in
let rec f_ns ns = {
ns_ts = Mstr.map f_ts (Mstr.filter g_ts ns.Theory.ns_ts);
ns_ps = Mstr.map f_ls (Mstr.filter g_ls ns.Theory.ns_ls);
ns_ns = Mstr.map f_ns ns.Theory.ns_ns; }
in
add_to_module uc nth (f_ns th.th_export)
let add_type uc its = let add_type uc its =
add_symbol add_it its.its_pure.ts_name its uc add_symbol add_ts its.its_pure.ts_name (PT its) uc
let add_data uc (its,csl) = let add_data uc (its,csl) =
let add_pls uc pls = add_symbol add_ps pls.pl_ls.ls_name (PL pls) uc in let add_pl uc pl = add_symbol add_ps pl.pl_ls.ls_name (PL pl) uc in
let add_proj = option_fold add_pls in let add_pj uc pj = Util.option_fold add_pl uc pj in
let add_constr uc (ps,pjl) = List.fold_left add_proj (add_pls uc ps) pjl in let add_cs uc (cs,pjl) = List.fold_left add_pj (add_pl uc cs) pjl in
let uc = add_symbol add_it its.its_pure.ts_name its uc in let uc = add_symbol add_ts its.its_pure.ts_name (PT its) uc in
if its.its_abst then uc else List.fold_left add_constr uc csl if its.its_abst then uc else List.fold_left add_cs uc csl
let add_let uc = function let add_let uc = function
| LetV pv -> add_symbol add_ps pv.pv_vs.vs_name (PV pv) uc | LetV pv -> add_symbol add_ps pv.pv_vs.vs_name (PV pv) uc
...@@ -231,7 +279,7 @@ let add_rec uc { rec_ps = ps } = ...@@ -231,7 +279,7 @@ let add_rec uc { rec_ps = ps } =
add_symbol add_ps ps.ps_name (PS ps) uc add_symbol add_ps ps.ps_name (PS ps) uc
let add_exn uc xs = let add_exn uc xs =
add_symbol add_ps xs.xs_name (PX xs) uc add_symbol add_ps xs.xs_name (XS xs) uc
let add_pdecl uc d = let add_pdecl uc d =
let uc = { uc with let uc = { uc with
...@@ -257,18 +305,6 @@ let add_pdecl uc d = ...@@ -257,18 +305,6 @@ let add_pdecl uc d =
| PDexn xs -> | PDexn xs ->
add_exn uc xs add_exn uc xs
let add_pdecl_with_tuples uc d =
let ids = Mid.set_diff d.pd_syms uc.muc_known in
let ids = Mid.set_diff ids (Theory.get_known uc.muc_theory) in
let add id s = match is_ts_tuple_id id with
| Some n -> Sint.add n s
| None -> s in
let ixs = Sid.fold add ids Sint.empty in
let add n uc = use_export_theory uc (tuple_theory n) in
add_pdecl (Sint.fold add ixs uc) d
(* create module *) (* create module *)
let th_unit = let th_unit =
...@@ -30,20 +30,25 @@ open Mlw_ty.T ...@@ -30,20 +30,25 @@ open Mlw_ty.T
open Mlw_expr open Mlw_expr
open Mlw_decl open Mlw_decl
| PT of itysymbol
| TS of tysymbol
type prog_symbol =
| LS of lsymbol
val ns_find_it : namespace -> string list -> itysymbol val ns_find_ts : namespace -> string list -> type_symbol
val ns_find_ps : namespace -> string list -> prgsymbol val ns_find_ps : namespace -> string list -> prog_symbol
val ns_find_ns : namespace -> string list -> namespace val ns_find_ns : namespace -> string list -> namespace
(** Module *) (** Module *)
...@@ -460,7 +460,7 @@ let () = Exn_printer.register ...@@ -460,7 +460,7 @@ let () = Exn_printer.register
| Mlw_ty.IllegalAlias _reg -> | Mlw_ty.IllegalAlias _reg ->
fprintf fmt "This application creates an illegal alias" fprintf fmt "This application creates an illegal alias"
| Mlw_expr.HiddenPLS ls -> | Mlw_expr.HiddenPLS ls ->
fprintf fmt "`%a' is a constructor/field of an abstract type \ fprintf fmt "'%a' is a constructor/field of an abstract type \
and cannot be used in a program" print_ls ls; and cannot be used in a program" print_ls ls;
| Mlw_expr.GhostWrite (_e, _reg) -> | Mlw_expr.GhostWrite (_e, _reg) ->
fprintf fmt "This expression stores a ghost value in a non-ghost location" fprintf fmt "This expression stores a ghost value in a non-ghost location"
...@@ -51,7 +51,7 @@ exception UnboundTheory of qualid ...@@ -51,7 +51,7 @@ exception UnboundTheory of qualid
exception UnboundType of string list exception UnboundType of string list
exception UnboundTypeVar of string exception UnboundTypeVar of string
exception UnboundSymbol of string list exception UnboundSymbol of qualid
let error = Loc.error let error = Loc.error
let errorm = Loc.errorm let errorm = Loc.errorm
...@@ -82,10 +82,9 @@ let () = Exn_printer.register (fun fmt e -> match e with ...@@ -82,10 +82,9 @@ let () = Exn_printer.register (fun fmt e -> match e with
(Pp.print_list Pp.dot Pp.pp_print_string) sl (Pp.print_list Pp.dot Pp.pp_print_string) sl
| UnboundTypeVar s -> | UnboundTypeVar s ->
Format.fprintf fmt "unbound type variable '%s" s Format.fprintf fmt "Unbound type variable '%s" s
| UnboundSymbol sl -> | UnboundSymbol q ->
Format.fprintf fmt "Unbound symbol '%a'" Format.fprintf fmt "Unbound symbol '%a'" print_qualid q
(Pp.print_list Pp.dot Format.pp_print_string) sl
| _ -> raise e) | _ -> raise e)
(* TODO: let type_only = Debug.test_flag Typing.debug_type_only in *) (* TODO: let type_only = Debug.test_flag Typing.debug_type_only in *)
...@@ -128,6 +127,23 @@ let flush_tuples uc = ...@@ -128,6 +127,23 @@ let flush_tuples uc =
let add_pdecl_with_tuples uc pd = add_pdecl (flush_tuples uc) pd let add_pdecl_with_tuples uc pd = add_pdecl (flush_tuples uc) pd
let add_decl_with_tuples uc d = add_decl (flush_tuples uc) d let add_decl_with_tuples uc d = add_decl (flush_tuples uc) d
(** Namespace lookup *)
let uc_find_ls uc p =
let x = Typing.string_list_of_qualid [] p in
try ns_find_ls (Theory.get_namespace (get_theory uc)) x
with Not_found -> error ~loc:(qloc p) (UnboundSymbol p)
let uc_find_ts uc p =
try ns_find_ts (get_namespace uc) x
let uc_find_ps uc p =
try ns_find_ps (get_namespace uc) x
(** Typing type expressions *) (** Typing type expressions *)
let rec dity_of_pty ~user denv = function let rec dity_of_pty ~user denv = function
...@@ -135,19 +151,13 @@ let rec dity_of_pty ~user denv = function ...@@ -135,19 +151,13 @@ let rec dity_of_pty ~user denv = function
create_user_type_variable id create_user_type_variable id
| Ptree.PPTtyapp (pl, p) -> | Ptree.PPTtyapp (pl, p) ->
let dl = List.map (dity_of_pty ~user denv) pl in let dl = List.map (dity_of_pty ~user denv) pl in
let x = Typing.string_list_of_qualid [] p in begin match uc_find_ts denv.uc p with
begin | PT ts -> its_app ~user ts dl
try | TS ts -> ts_app ts dl
let its = ns_find_it (get_namespace denv.uc) x in
its_app ~user its dl
with Not_found -> try
let ts = ns_find_ts (Theory.get_namespace (get_theory denv.uc)) x in
ts_app ts dl
with Not_found ->
errorm ~loc:(qloc p) "unbound symbol %a" print_qualid p
end end
| Ptree.PPTtuple pl -> | Ptree.PPTtuple pl ->
ts_app (ts_tuple (List.length pl)) (List.map (dity_of_pty ~user denv) pl) let dl = List.map (dity_of_pty ~user denv) pl in
ts_app (ts_tuple (List.length pl)) dl
(** Typing program expressions *) (** Typing program expressions *)
...@@ -180,33 +190,6 @@ let rec decompose_app args e = match e.Ptree.expr_desc with ...@@ -180,33 +190,6 @@ let rec decompose_app args e = match e.Ptree.expr_desc with
| Eapply (e1, e2) -> decompose_app (e2 :: args) e1 | Eapply (e1, e2) -> decompose_app (e2 :: args) e1
| _ -> e, args | _ -> e, args
(* namespace lookup *)
let uc_find_prgs uc p =
exception LS of lsymbol
let uc_find_ps_or_ls uc p =
try ns_find_ps (get_namespace uc) x with Not_found ->
(* we didn't find p in the module namespace *)
let ls = ns_find_ls (Theory.get_namespace (get_theory uc)) x in
(* and we did find it in the pure theory *)
if Mid.mem ls.ls_name (get_known uc) then
(* but it was defined in a program declaration! *)
error ~loc:(qloc p) (HiddenPLS ls);
(* fine, it's just a pure lsymbol *)
raise (LS ls)
try uc_find_ps_or_ls uc p with LS _ -> raise Not_found
(* record parsing *) (* record parsing *)
let parse_record uc fll = let parse_record uc fll =
...@@ -227,17 +210,14 @@ let parse_record uc fll = ...@@ -227,17 +210,14 @@ let parse_record uc fll =
in in
cs,pjl,flm cs,pjl,flm
let find_field uc (p,e) = try match uc_find_ps uc p with let find_prog_field uc (p,e) = match uc_find_ps uc p with PL pl -> pl, e
| PL pl -> (pl,e) | _ -> errorm ~loc:(qloc p) "'%a' is not a record field" print_qualid p
| _ -> errorm ~loc:(qloc p) "bad record field %a" print_qualid p
with Not_found -> errorm ~loc:(qloc p) "unbound symbol %a" print_qualid p
let find_pure_field uc (p,e) = try uc_find_ls uc p, e let find_pure_field uc (p,e) = uc_find_ls uc p, e
let pure_record uc = function let is_pure_record uc = function
| fl :: _ -> (try ignore (find_prog_field uc fl); false with _ -> true)
| [] -> raise Decl.EmptyRecord | [] -> raise Decl.EmptyRecord
| (p,_)::_ -> (try ignore (uc_find_ps uc p); false with Not_found -> true)
let hidden_pl ~loc pl = let hidden_pl ~loc pl =
{ de_desc = DEglobal_pl pl; { de_desc = DEglobal_pl pl;
...@@ -280,29 +260,25 @@ let add_var id dity denv = ...@@ -280,29 +260,25 @@ let add_var id dity denv =
let locals = Mstr.add id.id (tvars,dity) denv.locals in let locals = Mstr.add id.id (tvars,dity) denv.locals in
{ denv with locals = locals; tvars = tvars } { denv with locals = locals; tvars = tvars }
let specialize_qualid uc p = try match uc_find_ps_or_ls uc p with
